Author Topic: K8 forks on K2 frame...will they?  (Read 630 times)
Offline ksbrenn
« on: November 06, 2009, 10:12:30 AM »
I have a K8 in decent shape with no title
I can buy a K2 frame with title but no forks.
Will they go together without modifying the stem bolt
 to put these parts together for one complete bike with title?
« Last Edit: November 06, 2009, 12:57:28 PM by ksbrenn »
Offline Old Scrambler
Re: K8 forks on K2 frame...will they?
« Reply #1 on: November 06, 2009, 05:07:55 PM »
I have a K3 that came to me as a rolling project.  It has K8 forks and wheel and rolls just fine.  I believe the frames are the same.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Inigo Montoya
« Reply #2 on: November 06, 2009, 05:10:05 PM »
The frames are different at the neck but the fork tubes are the same size so you can easily put the k8 forks in the k2 tree.
« Reply #3 on: November 06, 2009, 07:55:28 PM »
The K8 front end less trees will fit the K2 trees, its a good mod as fork legs are longer,  and tubes are hardchromed.
 If you swap complete front end with K2 tank, forks WILL HIT @ full lock.
