Support the site. Your contributions keep this site running.
had them on other bikes, they work well on the road where when you hit sharp bumps normal forks have hydraulic lockon the other hand, the return damping mechanism of the honda forks that works with a heavy washer as a one way valve is not affected by the emulators. I might give them a try but on the track sharp bumps are not the issue, i am looking for better controlled return damping
Good point TG. I bought some replacement fork tubes from Forks by Frank for my race bike. They seem very good quality except for the "foot valve" inside near the base of the tubes. Franks installed an aluminum ring which doesn't much match the Honda piece, and will certainly affect damping. I was planning to use emulators but not sure if this aluminum ring may be a problem.
TG -are you happy with your RD350 fork ?I have a pair of ceriani 35mm (from a lavada 750)I´t´s a nice looking fork and easy to fit a drumbrakeIs there any mods Recommendations ?I have a Paioli yokes with a 4cm offset -is that a good idea ?Peter
Turbo, you should check all fork tube, you could straighten that one..
