Logo merchandise is available at the SOHC/4 Shop
also the wire out of sandwich bag ties work
also the wire out of sandwich bag ties work ( uk guys will know what i mean) mick.
...used the wire from a brush technique tonight...I have to say it works...not sure about a the drill thing though...where do u find a chuck that small?
A welding tip cleaner set works great also. You can purchase them at any welding supply store.
Honda makes a set of jet cleaners sized by the jet number. This way, you don't have to worry about accidentally enlarging the jet. I prefer these over the welding tip cleaners, as the tip cleaners have serrated portions that can damage the calibrated orifices in the jets. The Honda Part # is 07JPZ-001010B. Any dealer should be able to get them.
I use old guitar strings. I learned that trick here. If you dont have old ones, you can buy individuals for about a buck, .009, .010, .011, .012, whatever size you want.
