Author Topic: What did you do to your bike today ?  (Read 3272630 times)
Offline Dimitri13
  • 1974 CB550K
« Reply #10175 on: May 05, 2012, 05:14:24 AM »
Yeah, I was referring to the jetting tips list. I know it's not so cut and dry, but getting a starting point would be great. Either 105 or 115 mains... Should I just get a set of 105, 110, and 115s? They seem cheap enough..
I do wear a full face, but why do you ask? I don't quite follow :P
« Last Edit: May 05, 2012, 05:16:42 AM by Dimitri13 »
Offline CycleRanger
  • No comment about being an
« Reply #10176 on: May 05, 2012, 09:18:34 PM »
Ordered some new 120 main and new slow jets for the K5.
Offline onagd
« Reply #10177 on: May 06, 2012, 01:44:20 AM »
took the wheels to a local guy here in Auckland New Zealand who is going to re lace th wheels with original spokes. (Just dont have the time or knowledge to do this myself)
1973 CB350F
1975 CB400F
1998 GL1500
Offline Lil Red
« Reply #10178 on: May 06, 2012, 09:33:33 AM »
Took the Mrs to a Vintage Japanese club gathering...Nahhhh...it wont rain....turned into a monsoon...60 miles or so...forgot to turn the fuel on on the way out of the gathering..thought I had sucumbed to the dreaded sohc rain ignition gremlin...but NO....turned the fuel on, never missed a beat the entire 60 miles in a serious heavy down pour on the interstate...not bad for a bike with 28+ years on the ignition leads coils wiring etc...which I've never even touched...got alot of attention at the show too...was the only 400f there...Go Lil RED!!!...
Offline CycleRanger
« Reply #10179 on: May 06, 2012, 09:43:59 AM »
Took the Mrs to a Vintage Japanese club gathering...Nahhhh...it wont rain....turned into a monsoon...60 miles or so...forgot to turn the fuel on on the way out of the gathering..thought I had succumbed to the dreaded sohc rain ignition gremlin...but NO....turned the fuel on, never missed a beat the entire 60 miles in a serious heavy down pour on the interstate...not bad for a bike with 28+ years on the ignition leads coils wiring etc...which I've never even touched...got alot of attention at the show too...was the only 400f there...Go Lil RED!!!...
Nice fairing!
Offline wardenerd
  • '77 550F '81 650C
« Reply #10180 on: May 06, 2012, 09:50:21 AM »
finished the tank trim and mounting emblems after painting yesterday.shined up the gas cap all on the 650C.
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #10181 on: May 06, 2012, 01:50:46 PM »
Went from this:
To this:
Offline DJ_AX
« Reply #10182 on: May 06, 2012, 02:15:22 PM »
Fired up the 750 and rode it through the park... felt weird... I rarely ride without a destination. But I did have to get gas.
And ordered up a cart full of parts for the 550 :-)
Offline CBNJ74
  • Sweep the leg!
« Reply #10183 on: May 06, 2012, 02:17:10 PM »
Tank and sidecovers came back from paint this week. Started putting the old girl back together.
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
Offline brandEn
« Reply #10184 on: May 06, 2012, 02:30:14 PM »
CLEAN restore. Looks great!
Offline Brown Bomber
« Reply #10185 on: May 06, 2012, 03:21:38 PM »
The paint looks great!
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
Offline lucky
« Reply #10186 on: May 06, 2012, 03:34:01 PM »
I took an extra CB750 shift case cover that I had and cut the extra off to make it have a more competition look to it. I will post a photo.
Stock side cover photo at the top.
middle photo, finished shift case cover.
My start on my modified case cover.
« Last Edit: May 06, 2012, 04:09:14 PM by lucky »
Offline Accolay
« Reply #10187 on: May 06, 2012, 04:56:31 PM »
Went from this:
To this:
Looks great...but how did you fit the brake caliper B and piston in your carbs?  ;D
1977 CB550F
Offline Rhummy
« Reply #10188 on: May 06, 2012, 04:58:08 PM »
had to readust back wheel for chain tension.  I did get some nice parts.  Original Honda seat and a left side cover for $80.  Plus a nice 80 mile ride out of it.
New seat is stylin compared to the old King and Queen one.  ;D
1977 CB550f
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #10189 on: May 06, 2012, 07:38:49 PM »
Took the plugs out for a check,clean, and regap check, adjusted carbs 2 & 3, and of course went out for a test run to 100MPH!  ;D ;D ;D
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline the technological J
  • deliciouso!
« Reply #10190 on: May 06, 2012, 07:57:08 PM »
i would love to see other angles of this
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Dimitri13
  • 1974 CB550K
« Reply #10191 on: May 06, 2012, 08:12:38 PM »
Uh oh.. I was flogging it down a hill and somehow missed between 2nd and 3rd, revved up from redline to over 12k.. Now one cylinder isn't firing. I hope I didn't bend any valves or blow up a spark plug. This just happened about 15 minutes ago so it's still too hot to look into.
Any guesses?
« Reply #10192 on: May 06, 2012, 08:32:58 PM »
Back in the garage to play!
Fit new plug wires. Finished the install of the stainless braided oil lines now that I had both o-rings and new hardware. Installed the battery and turned the key - we have light, horn and turn signals. Rebuilt the rear caliper. Installed a NOS rear master. Installed the rear wheel. Hooked up the brake system.
Let's take a peek at what it's going to look like
Need to install the chain, clean and install the Kerker and start playing with the CR31 carbs real soon. Gotta start working more at the job now and less at the bike boohooo :'(
« Reply #10193 on: May 06, 2012, 08:34:37 PM »
Any guesses?
Been there, done that on 1st to 2nd. Floated valve, broke valve, BIG hole in piston, locked up big time, destroyed engine. Hope your's is minor. That is what got me into "fixing" these things  ;D The one of the right just went into it.
« Last Edit: May 06, 2012, 08:40:34 PM by Jerry Rxman Griffin »
Offline shinyribs
« Reply #10194 on: May 06, 2012, 09:03:39 PM »
I got my All Balls kit sorted out and my new progressive springs in the forks. The result is not subtle! Those progressives really work! It's amazing what 36 years worth of technology can do!...then I rode the snot out of it for about 5 hours. I got rained on a little,but still had a blast!8)
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #10195 on: May 06, 2012, 09:32:07 PM »
Damn Jerry  :o That sh1t looks HOT!  I like those rear spoked F wheels.  I see BOTM in your future ;)
Offline Ira
« Reply #10196 on: May 06, 2012, 09:47:44 PM »
I installed a steering dampener and worked on dialing in my fork oil level. Added a half ounce to each side and was pleased with the results.
So far my front end has:
-Progressive springs
-new oil/seals
-All Balls steerer bearings
-Avon rubber
-GSXR steering dampener
Left on my list:
-New wheel bearings
-Fork brace
Any other handling upgrades I should be thinking about?
Offline Dimitri13
  • 1974 CB550K
« Reply #10197 on: May 07, 2012, 12:25:00 AM »
Any guesses?
Thankfully it's not that severe. Engine still turns and runs. At first I thought it was just a main jet that got clogged up or something, so I took my carbs off and gave it a good cleaning. Went for a test ride and it ran decent (although it was shooting out flames and popping a bit at idle because I went from 45 slows to 38 slows). At some point during the ride, this happened. I don't know when, because I looked down at a stop light and discovered my engine soaked in oil.
I stopped at the local drug store and assessed the situation. Since I was able to get there from that stop light, I assumed I could get home (about three minutes ride), and I did. Thankfully no oil made it on to my rear tire and I didn't eat it.
Looks like I'm down for a few weeks while I get the minimum amount of parts (tappet cover, adjusting screw, and nut), then tear the head apart and go from there...
« Last Edit: May 07, 2012, 01:00:15 AM by Dimitri13 »
Offline lucky
« Reply #10198 on: May 07, 2012, 07:22:16 AM »
Any guesses?
C'mom now !!! that holed piston shown is an EXTREME and rare case!!!
Trying to scare someone to death are we???
Offline lucky
« Reply #10199 on: May 07, 2012, 07:24:41 AM »
I will have to finish it before I can post those photos.
