Author Topic: What did you do to your bike today ?  (Read 3265590 times)
0 Members and 9 Guests are viewing this topic.
« Reply #10250 on: May 11, 2012, 04:55:28 PM »
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #10251 on: May 11, 2012, 06:30:50 PM »
ordered new shoes for her
I put EBC shoes on the rear of my K3 and they DO make a difference in stopping power. IMO
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline the technological J
  • deliciouso!
« Reply #10252 on: May 11, 2012, 08:58:31 PM »
picked her back up from the mechanic and she was fixed.. didn't have to use a helicoil just tapped the current threads out and put me in some new plugs.. I should be ready to go for the rest of the 2012 World Tour Relay Rally. it only cost 81.00 so that isn't too bad since I didn't buy a tap tool.. and if I am more careful with the spark plugs I wont need one of those again.. :)
i was always taught to only put spark plugs in by hand... then tighten them down with a wrench
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline lucky
« Reply #10253 on: May 11, 2012, 09:03:08 PM »
Exactly.....
Offline Spanner 1
« Reply #10254 on: May 11, 2012, 09:46:09 PM »
Again, epic ride Coke on a 350.... I've been warned before of ease of cross-threading a plug on a hot motor, thankfully hasn't happened to me yet when doing a 'plug chop'.... best of luck with the rest of your Relay ride and hope to see you again  ;)
Offline DJ_AX
« Reply #10255 on: May 11, 2012, 10:17:54 PM »
Swapped out the flat spotted ball bearings for some AllBalls tapered bearings in the steering stem on the 550... Nice and smooth now :)
Offline Dimitri13
  • 1974 CB550K
« Reply #10256 on: May 12, 2012, 01:27:59 AM »
My replacement tappet screw, nut, and cover came in. Got it all together. The adjuster screw went in pretty stiff. All the other ones can be screwed in by hand, but this one is pretty tight. Is that normal, and the other ones worn out?
Went to replace the locknut on the one that got torn up. Apparently it's not an M6x1.00. It seems more like an M6x.7/.75/.8, whatever the fine thread is. And all the places that are open til 10 don't have them. Now I have to pray City Mill has it, and rush in the morning to get it running, so I can ride it to work.
Offline Emokid
  • Easy you say ? Now where's the fun in that ?
« Reply #10257 on: May 12, 2012, 11:11:10 AM »
Seat , oh yeah :)
-76 550f ,transforming into the 798 "Nazgul" cafe
http://forums.sohc4.net/index.php?topic=97563.0
Offline Really?
« Reply #10258 on: May 12, 2012, 11:36:14 AM »
I know that tappet screw is a fine thread.  Could not find a fine threaded one at Ace in Fredricksburg.  I shot it through the tappet cover during the rally on the road.  Had to drive it into Fredrcksburg that way.  Got lucky and found a used one in a box at Scootique of Fredricksburg.  It came from some old Kawasaki top end rebuild they did.  The cover came off a rusted out old Honda out in the back.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline CycleRanger
  • No comment about being an
« Reply #10259 on: May 12, 2012, 11:46:55 AM »
Double checked the tappets, cam chain tension, and the carb sync on the K5.
They were all good.
Still have a bit of clutch chatter. Meh.
Got the XL250s inspected.
« Reply #10260 on: May 12, 2012, 03:35:38 PM »
Took advantage of the beautiful day to ride to the local lake. A lot of rain lately and the level is up. I believe I can get my boat out now, the floating dock had been sitting on mud since last fall.
Offline IndyFour
« Reply #10261 on: May 12, 2012, 03:58:47 PM »
Took the 550 for a nice ride.  Pulled the clutch and felt it give a bit.  Stopped to take a look and discovered that my clutch cable was about to fail at the handle.  This is a newer motionpro replacement that i put on a yr or so ago just to avoid such a failure of the old one.  Limped hm.  It finally broke about a mile from home, so i navigated through town in such a way that i could avoid a total stop.
Luckily i kept the old one as it was in decent shape, just old.  Any other recomended brands other than motionpro?  Think i will avoid them after this.
Sent from my ADR6350 using Tapatalk 2
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
« Reply #10262 on: May 12, 2012, 04:53:33 PM »
Geez that's no good mate? I've used Motionpro clutch cables on my K1 for the last 7 years and recently put one on my Suzuki GS1000 with no issues, maybe you just got a bad one? Cheers, Terry. ;D
Offline dhall57
« Reply #10263 on: May 12, 2012, 04:59:21 PM »
just took a quick spin on my K6. Man I like this bike!!!
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Spokes
« Reply #10264 on: May 12, 2012, 05:05:02 PM »
got my carbs adjusted, freed up two frozen brake calipers using the grease gun method (thank you so much, this worked awesome!) put it all back together and fired up my 550 for the first time. Sounds great and got me excited. Took her for a little trip up the road to clean it out...dang this is fun :)
1978 CB550K
2001 Ninja EX250R
Offline bubbafun101
    • My K3
Offline Eydugstr
« Reply #10266 on: May 12, 2012, 05:38:48 PM »
Installed a frame adapter from Carpy's.
Offline nccb
  • 1974 CB750 Four
« Reply #10267 on: May 12, 2012, 06:45:23 PM »
took my bike on a long highway drive to a friends.  First time i've been on it besides two short bursts but the bike seemed to love running in the slightly higher rpm's.  Wonderful riding and riding on the highway isn't as bad as I thought it would be.
Offline Dimitri13
  • 1974 CB550K
« Reply #10268 on: May 12, 2012, 07:20:46 PM »
Yeah, I figured. I'm just glad it wasn't some crazy special thread or anything. Got it running and everything this morning. Ended up not riding it to work. It had a really hard time starting, and when it did, throttle between closed and 1/4 was very weak. Seems like I need to bump up to my 42 slows and see how it goes.
  • deliciouso!
« Reply #10269 on: May 12, 2012, 07:28:33 PM »
the powerband is up there in the rpms... rev her as high as you can... to the redline that is.... 750 is plenty of power for any situation.. i think its rediculous for some of these bikes to need more power
94 ST1100..Gone
Offline Dimitri13
  • 1974 CB550K
« Reply #10270 on: May 12, 2012, 09:39:55 PM »
Just got done with my carbs. Changed to 42/115 from 45(then 38)/120. Feels SO much better. The 115 is definitely it. The 42 is still a bit rich, but it's dramatically better than 38 (actually runs), and noticeable better than 45. I still need to get my mid-pipe made, and once I do, I'll try going for 40/115 first.
« Reply #10271 on: May 12, 2012, 10:42:48 PM »
Put the master link in my new chain - what a battle without the proper tool to get the side plate on! Adjusted the chain and installed the chain guard. Tightened up a number of bolts. Replaced the 2 oval head screws for my rear turn signals. Got most of the final routing of wires done and installed my shifter cover and front sprocket cover. Installed and trimmed cotter pins. Final install on shift lever and rear brake lever. Took a good look at it then went to my basement and got my new CR31's and new boots out to install tomorrow.
Offline Dimitri13
  • 1974 CB550K
« Reply #10272 on: May 12, 2012, 10:45:17 PM »
jealous :P
Where'd you get the CRs and how much did you pay? What intake are you using?
« Reply #10273 on: May 13, 2012, 03:21:18 AM »
I've been slowly working on my BMW R100RS in order to get it back on the road. On Friday it had it's Roadworthy inspection and (pretty much) passed with flying colors! Not registered yet, but I borrowed a "Trade plate" from a friend who owns a bike shop, and took it for as ride over to visit Brian. (Bear)
It was the first decent "around town" ride I've taken it on, and it highlighted one real PITA, the shifter linkage. I had the same problem with my previous R100RS, the shifter linkage is just a bent piece of wire, and is sloppier than a 10 dollar hooker. I missed gears, crunched gears, found false neautrals, you name it, I still had a great ride, but it took the edge off my riding experience.
The weather was awful today, and being Mothers Day in Oz, I didn't have a whole lot of time to play with my bikes, so I decided to sort the linkage.
I rummaged around and found a pair of 6mm rose joints.
I couldn't remove the footpeg mounting bolt, it's a capscrew, but the internal hex was buggered, so I had to drill the head off it.
Once I had the footpeg/shifter mechanism off, I drilled and tapped the linkages for 6mm screws.
The weather really was terrible, and my work space was limited to "between downpours".
So I amused myself by grinding tracts of skin from my appendages. Where did I put those gloves?
Anyway, it all worked out, and I'm happy with the finished product, both aesthetically and mechanically.
I took it for a ride in the rain, and the shifting difference was incredible! It "snicks" into gear with no slop, shifts very positively and overall, just feels great. I didn't miss a gear, the lever was just where I wanted it, so I'm a happy camper! Cheers, Terry. ;D
maduncle
« Reply #10274 on: May 13, 2012, 03:48:34 AM »
Well done Terry - you could almost sell them as an after market improvement kit.
What did I do to any of my bikes today?
Not f*%king much - as it pissed down rain here in Thornbury, but I did buy myself a locker for my shed to keep my riding gear in.
