Author Topic: What did you do to your bike today ?  (Read 3148446 times)
0 Members and 7 Guests are viewing this topic.
Offline DJ_AX
« Reply #10650 on: June 05, 2012, 10:37:30 am »
Sanded and painted the pipes again. Much smoother, and with flat rather than semi-gloss (oops). Much nicer now :)
Offline Blitzburgh207
« Reply #10651 on: June 05, 2012, 12:08:25 pm »
Bought some Tarozzis  8) I bought the kit for a k0-k6 even though I have a k8 because buying all the linkage individually would have cost as much if not more.  So I guess I'll see if theres any way the clamps can be fit (doubt it) and if not, whatev, I'll sell the k clamps to someone w/ some universals and figure another way to mount them (I liked that bike stem trick).  ;)
1978 CB750 K8
Offline timrichter9
« Reply #10652 on: June 05, 2012, 09:10:51 pm »
Ordered a clutch cable.
-- 76 CB550F SS
Offline Boulevard_beck
« Reply #10653 on: June 05, 2012, 10:54:45 pm »
Built my own 2 into 1 diode to get the left and right blinkers to trigger one indicator light. Spoiler alert: I just soldered two diodes together and it worked perfectly.
Offline Tews19
  • I am no
« Reply #10654 on: June 06, 2012, 05:40:32 am »
Had to adjust my chain. I adjusted it the previously day. Heard a louder then usual noise from the engine. Felt my chain and it was tight as hell. Went home adjusted it. Seemed fine until I went up the street. Came home and it was tight again. Adjusted this time, kept it loose and this time it didn't tighten by itself.
1970 Honda CB750 survivor.
Offline dhall57
« Reply #10655 on: June 06, 2012, 05:43:35 am »
Tews, sounds like its time for a new chain and sprockets.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Tews19
  • I am no
« Reply #10656 on: June 06, 2012, 06:05:09 am »
I was thinking that as well but low mileage bike. Any suggestions what type and where to purchase?
Offline WhyNot2
  • I'm finally an
« Reply #10657 on: June 06, 2012, 06:07:11 am »
Well, I got an email back from the ppeps I ordered my chain from and its on back order, so looks like a couple more weeks w/o a rear wheel on the K5.
« Last Edit: June 06, 2012, 11:08:03 am by budlite282 »
« Reply #10658 on: June 06, 2012, 06:14:33 am »
Couple of things: mileage v age. If the chain is really old, it will suffer from internal corsion of the pins where they fit into the rollers, especially if its a standard non-oring chain. So just a little bit of running will make it wear really fast. No way around it, regardless of mileage. If the wear is uneven, then you'll have spots where the chain appears properly tensioned, then turn it thru a ways and it tightens up.
Remember alos to adjust it with weight on the bike. The wheel moves thru an arc as it goes up and down. You wnat to adjust it at the point where it is the furthest from the engine. This would be straight back and to get that you need weight on the bike.
Offline dhall57
« Reply #10659 on: June 06, 2012, 07:08:53 am »
For my 750K6 I got the sprockets from Z1 Enterprizes 18/48 and a #530 Diamond chain from Diamond Powersports 102 links I believe. A lot of people say you should drop down to a 17 tooth frt. sprocket, but I stayed with the factory set up.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline 03rangerxlt
« Reply #10660 on: June 06, 2012, 09:09:14 am »
I managed to get the handlebars all set up.
Next to tackle is the wiring.
1972 Honda CB500 Cafe "The War Eagle"
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #10661 on: June 06, 2012, 10:32:03 am »
Got my OEM heat sheilds on last night. Man I like how saxy the OEM pipes are. Final part needed on the "unrestored" K3. Has some patina to it, but don't we all after 40years?!?!
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #10662 on: June 06, 2012, 08:02:13 pm »
 TODAY ? not a damng thing but did get the baggs on thus far
« Last Edit: June 06, 2012, 08:04:39 pm by piute »
Ride to live Live for Jesus
1977 750 F2
Offline Sparked
  • Cheaper then therapy
« Reply #10663 on: June 06, 2012, 08:37:41 pm »
Brought it home again and have it running with the transplanted engine I found last year. Not 100% yet but she sure starts easy.
Sent from my Atari
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline george
  • Back To My Roots !
  • K8 The Project
« Reply #10664 on: June 06, 2012, 11:58:56 pm »
Switched the K8 from 630 to 530  17/46 gearing. World of difference as far as noise and clunking, seems peppier, maybe because its so much smoother , and it just looks better !
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
« Reply #10665 on: June 07, 2012, 05:20:01 am »
I've been looking into that lately...  I want to do it but can't find sprockets?  Where did you get yours?
1978 CB750 K8
« Reply #10666 on: June 07, 2012, 05:49:52 am »
I got mine sprockets from Bike Bandit.
Offline ravexcafe
« Reply #10667 on: June 07, 2012, 07:50:10 am »
Rode it to work, second time out on it since I got it running well!  Still cuts out at higher rpm, still have filters tho, going to order a stock air box off of ebay today!  1976 750k
Offline brandEn
« Reply #10668 on: June 07, 2012, 08:25:15 am »
looks good! What headlight ears and headlight bucket is that?
Offline Tintop
« Reply #10669 on: June 07, 2012, 09:18:42 am »
The higher rpm cutout will either be ignition break down (most likely), or fuel.  PODs won't be the problem.  They create problems with idle & low / part throttle operation.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline george
  • K8 The Project
« Reply #10670 on: June 07, 2012, 09:30:49 am »
http://www.ebay.com/itm/330449530095?_trksid=p3984.m1439.l2649&item=330449530095&viewitem=&sspagename=STRK:MEWNX:IT&vxp=mtr
Shipped in 3 days, JT sprokets, bikemaster o ring chain, I did remove 2 links
« Reply #10671 on: June 07, 2012, 10:09:45 am »
Dope.  Did it come w/ that rear sprocket in your picture?  The one on ebay looks like a universal or something.  I have a k4 one laying around - is that what you did?  Thanks!
1978 CB750 K8
Offline george
  • K8 The Project
« Reply #10672 on: June 07, 2012, 10:20:08 am »
Came with 17/46 JT Sprokets and a Bikemaster 530 o ring chain. 102 link , I removed 2 links.
« Reply #10673 on: June 07, 2012, 11:08:07 am »
#$%*in right!  8)  I'm ordering that right now! haha
1978 CB750 K8
72500john
« Reply #10674 on: June 07, 2012, 03:55:42 pm »
finished installing new coils on the bike. runs great!
