Author Topic: What did you do to your bike today ?  (Read 3148252 times)
0 Members and 10 Guests are viewing this topic.
Offline MoMo
  • Ride like you're invisible
« Reply #10850 on: June 19, 2012, 07:15:24 pm »
Longshanks, do a  search on Magura.  I bought a new set on Ebay for 16 shipped....Larry
Offline Burgess17
« Reply #10851 on: June 19, 2012, 07:21:30 pm »
I ordered pod filters and thought about paint for the tank :)
Offline Accolay
« Reply #10852 on: June 19, 2012, 10:18:51 pm »
Buttoning the carbs back to the rack when this piece snapped...
It should look like this:
Sigh.
I had one that was broken too. If you like you can easily make one out of some thin stainless steel or aluminum sheet. I got the metal at a local hobby store, but I have also seen a metal display for projects at Ace Hardware- they even have some small brass sheet if you want to get fancy :) Take one of the remaining intact ones and trace it out with an awl of something sharp onto the new metal and drill the holes before you cut it out.
1977 CB550F
« Reply #10853 on: June 20, 2012, 01:28:22 am »
Bought one!  K1? built 7/70. Custom exhaust!
And this K1 came with it! Future cafe?
And also this K2!! Nice 341's.
All these came out of NY. Special thanks to Chewbacca [Kyle] for checking 'em out for me. [Gave him a little beer money!]
And if thats not enough, was browsing CL during lunch, and found this K6 and bought it too! Yes, I'm crazy but have 4 more projects to keep me busy til 2020!
Fantastic pick up Steve, I wish I had enough room to buy four bikes at a time, I'm jealous! Cheers, Terry. ;D
maduncle
« Reply #10854 on: June 20, 2012, 02:40:39 am »
C'mon Terry - you could fit another four bikes in the Tardis with the four complete bikes in there and the other fourteen in pieces!
Offline Radam
  • taco racer
« Reply #10855 on: June 20, 2012, 02:54:07 am »
Terry, you could just build a greenhouse.  ;D
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10856 on: June 20, 2012, 03:50:28 am »
And they call me a hoarder!  ;D Nice score. ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #10857 on: June 20, 2012, 04:00:46 am »
Ha ha, I keep looking at my back yard and think what a waste all that space is, the kids are grown up, the dog is dead, the cats can go where they like, so it's not as if there's any logical reason why I couldn't put up another garage?
I think it'd be nice to have one garage for parts, another for a workshop, and another to park the finished bikes in, and with all those garages, mowing the remaining 4 square feet of lawn would be a snap! ;D
« Reply #10858 on: June 20, 2012, 05:09:05 am »
I may need a greenhouse. But the wife would use it for plants, so no way!
Offline JamesM
« Reply #10859 on: June 20, 2012, 05:13:02 am »
Sigh.
i run without those,its to help the load on those damper springs,you can get away without them no problem.
Awesome, that's a relief. Thanks for the info man.
Accolay--- that's what I plan on doing, just won't have time until the end of the week and want to ride this puppy today.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
maduncle
« Reply #10860 on: June 20, 2012, 05:50:14 am »
But you would still use your ride on mower wouldn't you?
Offline CycleRanger
  • No comment about being an
« Reply #10861 on: June 20, 2012, 06:50:57 am »
I rode my bike for the first time since getting it back together.  It was for about 15min then it rained.  Wiped it down and here are some crummy cell phone pics
Very purty! :) :)
Offline Soulsk8r
« Reply #10862 on: June 20, 2012, 07:41:50 am »
still reassembling after my fork boot replacement project.
i've got the forks, caliper, wheel and fender back on.  everything appears to have gone on just fine, and axle is evenly spaced between the forks as it was before.  the wheel rotates, but not freely.  you can hear the rotor dragging on the pads when you spin the wheel and, using the pressure of my hand, i can pull the caliper out slightly to a position that does allow the wheel to spin freely.  the caliper adjustment screw is in the exact spot i found it -- six threads showing. wondering if there something i've overlooked in the re-installation?
last night i loosened everything up (lower fork pinch bolts, caliper and fender nuts/bolts, and the end caps that hold the wheel on the forks) and pushed down on the forks a couple times while the wheel was on a block of wood to seat everything -- i did feel and hear something settle -- then snugged it all down again.  the wheel spins more freely, but the disc is still dragging on the pads.
will try again to figure it all out tonight.  :)
Newbie rider, newbie vintage bike owner - Honda CB750K1.
Offline Accolay
« Reply #10863 on: June 20, 2012, 08:01:45 am »
Sigh.
What can I say? Great minds think alike :D I hear you on riding it. Worst thing in the world is to only have one bike that doesn't work (while you hear other motorcycles in the distance).
1977 CB550F
Offline veloracermike
« Reply #10864 on: June 20, 2012, 08:03:35 am »
This is a great guide to adjusting the front brake:
  Turn the adjuster screw until it draws the "B" pad (the "passive" pad that does not have the moving piston behind it) to within  5thou of the disc. Yes use a feeler gauge. Lock it in place with the nut. Now pump the brake until it is tight, then release. If the A pad is withdrawing properly, and the Master Cylinder is allowing it to withdraw as it should, you'll be able to measure your 5 thou clearance on the B pad once again. Smoothly, with no hitches.
Offline Soulsk8r
« Reply #10865 on: June 20, 2012, 08:07:49 am »
thanks!  guess i'm on my way to Sears tonight to get a feeler gauge.
Offline Tews19
  • I am no
« Reply #10866 on: June 20, 2012, 10:51:58 am »
Plus one.. I will do this tonight
1970 Honda CB750 survivor.
Offline DJ_AX
« Reply #10867 on: June 20, 2012, 10:58:34 am »
Got another fresh tire delivered! ... for the back of the 750...
So happy to not have to drop off the wheel... wait... tell 'em to re-do it right... wait... etc.
I love my tire irons :)
I'll try not to wear this tire out so quickly... ... NAAaaaaaaaaa :)
Offline gnarlycharlie4u
  • Far from being an
« Reply #10868 on: June 20, 2012, 11:57:19 am »
Offline longshanks
« Reply #10869 on: June 20, 2012, 01:29:33 pm »
nice! where'd you score the gum grips? I can't find them anywhere! :(
http://www.ebay.com/sch/japanesechopper/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
I am looking for the Gran Turismo style ones. They are bulged in the center of the grip instead of a straight across barrel.
cb450 K5
« Reply #10870 on: June 20, 2012, 01:37:02 pm »
There is a shop here in Austin that carries Posh products, they have them but they are freakin' expensive, 50 bucks if I remember right.  If you want I can swing buy and pick some up for you.
Offline longshanks
« Reply #10871 on: June 20, 2012, 02:11:40 pm »
Thanks, that's super nice of you. Let me consider that since they're so expensive  :o
cb450 K5
« Reply #10872 on: June 20, 2012, 03:48:10 pm »
Mike - what shop in Austin?  The last couple sets of grips I've purchased from Cycle Gear on 183. Didn't think they had a great selection.
Offline JamesM
« Reply #10873 on: June 20, 2012, 04:07:05 pm »
Okay--
Got the carbs back on my bike today, turn the fuel on and no leaks! Go for a ride, come back and I'm leaking out of the #1, and #3 float bowls. But no gas is coming out of the overflow tubes. I just had all four off the rack, dunked them, cleaned them, and installed all new hardware, and gaskets in them.
What could my problem be?
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
« Reply #10874 on: June 20, 2012, 05:25:44 pm »
Revival.  They are on the expensive side but they do get some cool stuff from Japan.
