Author Topic: What did you do to your bike today ?  (Read 3255650 times)
Offline Tews19
  • I am no
« Reply #11450 on: August 07, 2012, 03:15:13 PM »
There should be a "What did you not do to your Bike" thread, due to forum members not sending the parts they were selling.
I know it's all my fault........"I should not have yanked all the parts off, not knowing if the all balls head bearings I honestly thought that I was buying, were not in my hand."
However, I guess I'll have to chalk it up as a bad experience.
Guess, I'll have to contact paypal, and find some other place to order them.............
Sheeeeeat!!!!!
What happened?
1970 Honda CB750 survivor.
Offline WhyNot2
  • I'm finally an
« Reply #11451 on: August 07, 2012, 03:55:44 PM »
Don't know.......he offered, I excepted, he posted sold and pm'ed me that he would not be able to ship till saturday, is that ok. I responded, sure. That was on the 19th of July..........Texas is'nt that far from Georgia...........have'nt had responses to my pm, and emails........I'm hoping I'm not jumping the gun here, but......just saying.....could at least let me know something. I probably over anticipated and tore my bike down already, something I should have remembered from 20 years in the Army. Never anticipate the command.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #11452 on: August 07, 2012, 04:28:27 PM »
Ouch, lester. Good thing you caught it and knew to drop the emulsion tubes. Those things are nasty. Is that from ONLY running a tank of contaminated fuel, or were they never cleaned beforE?
They were never out but the bike was running fine before.   ::) I think the rusty colour at the top is my doing and the lighter stuff is old.
« Reply #11453 on: August 07, 2012, 07:46:25 PM »
Woke up early this AM to get FIx a FLat. WIll wait to see if it works after work.
No no no!
Offline Tews19
  • I am no
« Reply #11454 on: August 07, 2012, 08:57:57 PM »
No no no!
HA the story evolved. Safe and sound though!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #11455 on: August 07, 2012, 09:07:46 PM »
assembled the airbox on the 550. Rode the S90 and got through all of the gears for the first time.
Offline namesEric
    • Bike
« Reply #11456 on: August 07, 2012, 09:24:25 PM »
Broke the negative battery terminal off trying to jump start it.
Bike: 1974 Honda CB550
Offline xnewmanx
« Reply #11457 on: August 07, 2012, 09:25:04 PM »
built a suicide clutch and jockey shifter from scratch.
Offline fire113
« Reply #11458 on: August 08, 2012, 12:33:04 PM »
...found strange things under the valve cover, PO inserted bolts instead of screws, 3 valves are pitted,PO killed one bolt and glued the o-ring under the cam towers. Was fighting with the broken bolt, welded a nut on the broken top but it only came out 2-3mm and broke again  :( Will see tomorrow how to get the rest out.
  • 1977 CB550F2
« Reply #11459 on: August 08, 2012, 02:15:57 PM »
I meant the carbs were cleaned before but the emulsions were not as I didn't know how to remove them..
Offline lucky
« Reply #11460 on: August 08, 2012, 11:18:52 PM »
...cleaned the polished valve cover from the polish rests.
Looks beautiful. Now go wash that raccoon face. Lol..lol  ;D
Offline fire113
« Reply #11461 on: August 09, 2012, 09:59:56 AM »
...was able to get that broken bolt out, took a little bit more time but the thread is ok  ;D
Did new tower seals and o-rings under the cam towers.
  • 1977 CB550F2
« Reply #11462 on: August 09, 2012, 11:37:28 AM »
How have you managed to clean all that swarf up?
Offline Elan
    • Vital Motor Parts
« Reply #11463 on: August 09, 2012, 01:10:35 PM »
finally rode mine after rebuild! Now if I can just manage to "go easy on it" for the break in period... ::)
the skinny:
836cc
webcam41
ported head w/ oversized intake valves
pamco kit with high output coils
thanks to Mrieck for making this happen!
76 750k
Offline fire113
« Reply #11464 on: August 09, 2012, 01:12:30 PM »
...compressed air and break cleaner
Offline sirdaft1
« Reply #11465 on: August 09, 2012, 08:12:03 PM »
Fresh rubber arrived today. Some Dunlop K70's... the PO installed some fatty tires, so these are a bit skinnier.
Offline fire113
« Reply #11466 on: August 10, 2012, 10:41:27 AM »
...completed the engine
« Reply #11467 on: August 10, 2012, 11:02:17 AM »
Fire113: You may find that those valve covers will foul the petcock and the frame rails on the intake side. I'd leave them off till you get the engine in just to make sure. I had to use the stockers on the intake side.
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #11468 on: August 10, 2012, 11:55:22 AM »
Clean, lube and adjust chain (that's why God made rainy days) ;)
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline hymodyne
« Reply #11469 on: August 10, 2012, 12:05:46 PM »
Finally found a 650 tach drive on ebay. Installed it this morning, with a 750 tach.
James
Offline DJ_AX
« Reply #11470 on: August 10, 2012, 12:42:44 PM »
Put the windshield and trunk on the 550... ready to ride across the state to meet GZ! :)
« Reply #11471 on: August 10, 2012, 12:46:42 PM »
gorgeous day to be riding in the PNW.
made it home back to work in record time over lunch   ;D
Offline fire113
« Reply #11472 on: August 10, 2012, 02:11:49 PM »
Hi MCRider,
...yes I know  ;D
My plan was to put on the polished original stuff BUT the engine is looking sooooooooo ugly and a fresh polished valve cover with a #$%*ing rattle can paint job would be a little bit too much ;)
Offline HonderCB
« Reply #11473 on: August 10, 2012, 03:33:48 PM »
Hi MCRider,
...yes I know  ;D
MY father-in-law just gave me a set of those and they do fit on mine, but i think the petcock is back just a scoche farther on the SS tank.
As for what did i do to my bike today?
new points condensers and carburetor tuning...fun stuff
77' CB750F
81' CB650C - SOLD
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #11474 on: August 10, 2012, 03:42:46 PM »
picked up a project bike the other day, a 73 cb350f w/27K miles.  needs a full mechanical and cosmetic freshening up, she can be saved however.  still preoccupied with the "vision thing" and not sure exactly where i'm going with this one.  been checking the bikes in the inspiration gallery here, and will probably let the bike steer me in the right direction.
am just now diving in and sorting out overall condition.  sat for 10+ years in a cellar, then shed, then this PO bought it with "plans" but stalled 2 years ago.  amazingly, all the electrics work except one blinker.  all the bullet connections look nice too, thank heavens.  will still pull each apart and lube w/dielectric grease at some point.  robbed a battery and spun her over to check compression -- is terrible (all at 80psi) but may come up when i finally get her going.
came with new ss spokes for front/rear, service manual on CD, 4 Sudco complete carb rebuild kits and a full engine gasket kit.  $200.
i'll get her running and, if shifting is ok, back in the shop for a strip down to the frame.  oh, boy here we go!   ;)
searching for a dr350se
