Author Topic: What did you do to your bike today ?  (Read 3255863 times)
Offline JamesM
« Reply #11475 on: August 10, 2012, 04:59:57 PM »
Put my new tires on, put my freshly shaved seat on. (Shaved a few inches of foam out of the rear to make it sit even) Put my speedo on the bracket I modified yesterday. And mocked up my new taillight on a GS550 front fender that I'll be cutting up and putting on tomorrow.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline Dimitri13
  • 1974 CB550K
« Reply #11476 on: August 11, 2012, 01:45:44 AM »
Clean, lube and adjust chain (that's why God made rainy days) ;)
Same, except it wasn't raining and it was 10pm.
Just getting ready for some dyno pulls tomorrow.
« Reply #11477 on: August 11, 2012, 02:28:20 AM »
dont forget to let us know the dyno read out.
Offline Dimitri13
  • 1974 CB550K
« Reply #11478 on: August 11, 2012, 02:58:33 AM »
Haha of course, I wouldn't leave ya'll hanging. I KNOW the low end will be complete #$%*, because my points need replacing and there's something wrong with advance, but the upper end feels nice and strong.
« Reply #11479 on: August 11, 2012, 03:04:42 AM »
if you want to up the numbers try a fred flinstone and paddle the rollers along with your bare feet.
Offline fire113
« Reply #11480 on: August 11, 2012, 04:00:30 AM »
...took off the oil pan, killed one bolt did, new o-rings under the pump, took off that distance pieces (20cm) from the fork and polished a little bit the frame.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #11481 on: August 11, 2012, 07:10:05 AM »
Went from "Blue Bummer errrt I mean Bomber" to the "Black Dahlia." Rattlecan job for a 400 dollar bike. Going to put on a sporty tank, but for now I saved thr flames on the tank. Also took the paint off what ended up being nice chrome.
From this:
To this:
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline namesEric
    • Bike
« Reply #11482 on: August 11, 2012, 10:53:11 AM »
Ran sea foam through the fuel and oil. Went for a short ride then change the oil and spark plugs.
Bike: 1974 Honda CB550
Offline Tree
  • CB750K5
« Reply #11483 on: August 11, 2012, 04:17:39 PM »
Rainy Day  - Did the 3,000 Mile Tune up, replaced the plugs / Sync'ed the carbs.  By the way, anyone know if there is actually a carb. sync tolerance spec? I settled for readings between 24 and 25 on the gauges, (not sure what units the gauges are in).   How close are you generally able to get them?
« Reply #11484 on: August 11, 2012, 04:42:56 PM »
Looks good mate, although I liked the blue too. Are they forward pegs you've mounted in front of the engine? They'd be hard to use with those low bars, wouldn't they? Cheers, Terry. ;D
Offline veloracermike
« Reply #11485 on: August 11, 2012, 04:45:56 PM »
I added baffles to my open pipes.  It solved two problems. First the bike was just obnoxious to the point that I couldn't even idle through my neighborhood without bothering my neighbors.  Second it solved my jetting problem just off of idle. Bike runs great now.
Offline Trevor from Warragul
« Reply #11486 on: August 11, 2012, 05:41:48 PM »
Deathtrap
« Last Edit: August 11, 2012, 05:44:03 PM by morini »
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline Dimitri13
  • 1974 CB550K
« Reply #11487 on: August 11, 2012, 06:01:42 PM »
Looks incredibly low. You don't bottom out the rear? Only lowered an inch in the front it seems..? Or is that an inch and a half, I can't tell from this angle?
« Reply #11488 on: August 12, 2012, 02:18:09 AM »
Deathtrap
Is there a law against unintentional vehicular suicide? Oh well, if nothing else, the owner might win a Darwin award.............;D
Offline hondaface75
« Reply #11489 on: August 12, 2012, 05:06:22 AM »
Deathtrap
Is that brake rotor painted black?
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #11490 on: August 12, 2012, 05:11:30 AM »
Terry,
There just pegs, not controls. Its a thick steelbar that attaches to the frame. Id love forward controls, but too mich $$$. Its not too bad with low bars but I enjoyed it on the interstate.
Gus, Austin, MN.
« Reply #11491 on: August 12, 2012, 05:17:12 AM »
Deathtrap
Yeah, but no biggie when there's no caliper attached.............  ::)
Offline fire113
« Reply #11492 on: August 12, 2012, 06:22:17 AM »
...drove the K1 ~200km and was able to get the broken key out of the lock.
« Reply #11493 on: August 12, 2012, 06:54:41 AM »
Hey Fire. What year is the engine you were just working on ? Noticed the extra 8 bolts  that hold the round rocker shafts from spinning in the cam towers used on the later engines.
Offline JamesM
« Reply #11494 on: August 12, 2012, 07:08:05 AM »
Deathtrap
Dimitri- It's lowered 4 1/2" in the front, and 2 1/2" in the rear. Springs are cut 3" with spacers added, and then brought the tubes through the trees another 1 1/2".
Yes the rotor got some over spray on it when painting the wheel, which will come right off when the caliper goes back on. Waiting for my new line.
It's not nearly as low as a lot of bikes on the road, so I fail to see how it's a 'death trap.' It handles really well and still goes over huge bumps/pot holes just fine.
Over the winter it will be getting a hardtail and coming down another ~2" in the back. Will be able to get rid of the ratty seat, and gross pipes too. Everything will get stripped and painted for real.
I've ridden the "deathtrap" a good 1,000 miles that low so far and everything has been fine. Even on #$%*ty Pennsylvania roads.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ef977ka3q201rg9v4e19bigec3&/topic,60973.0.html
« Reply #11495 on: August 12, 2012, 07:59:21 AM »
great name for a build thread.....DEATH TRAP....
i hate all this v-w.... vords
Offline fire113
« Reply #11496 on: August 12, 2012, 10:54:52 AM »
Hi ekpent,
...I is a K0 engine, I thought the same as I took off the valve cover! may be they changed/swapped  the cam towers.
That Bike is one of the very last K0, have to look in the papers but I think it was ~120 numbers before K1 starts.
« Last Edit: August 12, 2012, 11:01:13 AM by fire113 »
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #11497 on: August 12, 2012, 11:03:47 AM »
I put a brand spankin' new cotter pin through the rear axel castle nut...it's the little things that count ;)
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
« Reply #11498 on: August 12, 2012, 11:22:52 AM »
Rode the twisties on Cow Creek Road
And trying to decide what I will do with this 550F I picked up the other day. Came with a sidecar and spared titled frame too.
What wheels are these? More pics, go here...
http://forums.sohc4.net/index.php?topic=111295.0
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #11499 on: August 12, 2012, 11:36:52 AM »
>>PERK<< Sidecar?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
