Author Topic: What did you do to your bike today ?  (Read 3315851 times)
Offline Tintop
« Reply #12525 on: November 07, 2012, 02:24:28 PM »
The problem with alloy is that it 'work hardens' with vibration.  That makes it brittle, and causes it to fail.  Steel just takes much longer to reach that point.  The manufacturers use steel because it's cheaper, and easier to work with, ie better profit. ;)  The cooler on my sidecar is mounted in cups, because of the vibration it's subject too.  It actually floats in the cups and is not 'fixed' in anyway.  The cups are steel, but not because I think that's better, just that I already had them.  If I had had to make them, they would be alloy.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #12526 on: November 07, 2012, 03:03:19 PM »
When you say "it floats" , does it have rubber inserts or mounts, just curious, i have no trouble with Aluminum mounts, after having a couple of them fracture and fail i just rubber mount everything, i suppose it also depends on the quality {grade} of the alloy being used as well... ;)
Offline Jerry E.
« Reply #12527 on: November 07, 2012, 04:08:55 PM »
Thanks, I'll try rubber mounting the bracket, too. Can't hurt, should help.
"Why jump from perfectly good airplanes? Because the door opens."
Offline Tintop
« Reply #12528 on: November 07, 2012, 06:53:55 PM »
There is a piece of inner tube inside each 'cup'.  Also a rubber washer between the cups and the frame were the bolts go through.  Seems to work well, as the cooler and mounts came through the crash completely undamaged. ;)
77 CB550 Cafe build
« Reply #12529 on: November 07, 2012, 06:56:37 PM »
Considering that you came through that crash unscathed i am assuming you were rubber mounted as well.... ;D ;D :o
Offline Tintop
« Reply #12530 on: November 07, 2012, 07:33:09 PM »
I bounce, and slide well, learn that getting dumped off horses ;D ;D ;D ;D
77 CB550 Cafe build
« Reply #12531 on: November 07, 2012, 11:10:09 PM »
i want my ashes sprinkled through carbs during a carb sync!
I want mine dropped in the oil tank of a sandcast collector just before a long ride............ ;D
I was planning on half burying you face down and using the bit sticking out as a bike stand - so you be useful when I work on bikes even after you are gone.
Ha ha, er, I got nothing............. ;D
« Reply #12532 on: November 08, 2012, 01:03:27 PM »
postponed the 'winterizing'
Offline george
  • Back To My Roots !
  • K8 The Project
« Reply #12533 on: November 08, 2012, 05:53:30 PM »
Put 200 miles on the K8 with my bud Ned on his Buell. The K8 mis behaved the whole time, head shakin, oil leakin , cutting out at anything over 6k. But a great ride none the less , we spent most of the time on county roads , and only about 30mi. on the dreaded freeways !! Actually a very awesome cruise !!
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #12534 on: November 08, 2012, 06:06:08 PM »
Warmed it up this evening, leaving for Valdosta tomorrow!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Magilla
  • My bike: 1976 CB750F
« Reply #12535 on: November 08, 2012, 06:34:42 PM »
Talk to me about this bike.  Is it meant to carry a wheelchair?  There is obviously a ton of work done here.  What was it designed to do?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #12536 on: November 08, 2012, 06:41:12 PM »
Are you kidding? That is an awesome race hack.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #12537 on: November 09, 2012, 03:49:01 AM »
Replaced my black fork ears with shiny chrome ones. Another small step.
Offline Tintop
« Reply #12538 on: November 09, 2012, 04:29:53 AM »
Magilla, read all about it here - http://forums.sohc4.net/index.php?topic=102875.0
tintop
77 CB550 Cafe build
Offline Bailgang
  • Scott
  • Indiana
« Reply #12539 on: November 09, 2012, 07:24:42 AM »
Same here, it's supposed to get in the high 60's this weekend here so my 550's coming back out.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Felix
« Reply #12540 on: November 09, 2012, 09:21:10 AM »
I haven't done anything to my bike, but I DID pass my driving test! I can finally ride around legally! All I have to do now is finish my bike. :D
Honda CB500F '72 in progress
Offline mono
  • Definitely no
« Reply #12541 on: November 09, 2012, 12:49:43 PM »
Congrats, Felix!
- i've spent the last few days vinegar soaking nuts and bolts from my 2 project bikes, getting them all shiny again.   prepped the triples for spraypainting this weekend since it'll be warm enough to do this out in the garage (as opposed to the basement ;D ).  also cleaned and adjusted the points on the 550 in preparation for some serious riding this weekend since we're getting what will probably be our last warm temps for a few months.
« Reply #12542 on: November 09, 2012, 04:15:11 PM »
Good for you, Felix!
I fixed the deer damage and took her out. It felt good to be back on the road.
Offline heffay
« Reply #12543 on: November 09, 2012, 07:33:51 PM »
I nearly just died laughing when I read this, then showed my wife the bike... she said that looks very   special.  I may have died laughing after that.
Offline scunny
  • don't call me expert
« Reply #12544 on: November 10, 2012, 02:23:36 AM »
gave the throttle a couple of spirited twists, hit the starter, wound the idle screw up to a comfortable idle. put my riding gear on and rode of into a mavellous day. life is good, I love my bike.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #12545 on: November 10, 2012, 04:15:46 AM »
I'm pissed off that I work up this morning intending to replace my fork seals and it's now 7pm, and I haven't changed them yet.
I did take my front wheel off, then took it over to the bike shop to get the tire swapped from one rim to the other, then replaced the discs, reinstalled the wheel in the forks, dumped some cooling system flush stuff in the radiator, took it for a ride for 30 minutes, brought it home, dumped the coolant (which still looked great after 14 years, amazing!) refilled the system with new coolant, (in a fetching shade of orange) dumped the oil (horribly black and manky, ooooher......) and filter, removed the clutch cover, polished it on my buffer, re-routed and lubed the clutch cable, cleaned the oil filter canister, installed the new oil filter, filled it with Castrol GTX (because I already had some in my garage) installed a new air filter, installed new spark plugs, removed the carbs, stripped and cleaned them, reinstalled the carbs, reinstalled the tank and seat, installed my new mirrors, removed the horrible foam hand grips and replaced them with new Honda grips, then fell over with exhaustion. Good thing is, I fired it up and it's running really well, and no leaks!
I'm still pissed off that I haven't replaced my fork seals though, hopefully the weather will be nice again tomorrow, and I'll get them done, hook up the other front caliper, bleed the brakes, and go for a fcuking ride!
« Reply #12546 on: November 10, 2012, 04:56:48 AM »
Busy,busy busy now guit loafing around drinking fine grade Scotch and get them dam# fork seals in Terry.    ;D
« Reply #12547 on: November 10, 2012, 09:52:59 AM »
coffee+hacksaw+dremel= modified speedo drive plate for dual disc setup in the making
its a sunny fall day. as soon as it gets above 40f.....im going riding.
maduncle
« Reply #12548 on: November 10, 2012, 01:00:19 PM »
I don't have eight arms like my mentor Terry - so I only sat down at my bench with eleven lengths of wire in different colours, and build myself a whole new wiring harness, complete with new connectors.
Makes me a little bit accomplished.
« Reply #12549 on: November 10, 2012, 02:19:33 PM »
Pics, or it didn't happen, Grasshopper! ;D
