Author Topic: What did you do to your bike today ?  (Read 3268771 times)
« Reply #12750 on: December 12, 2012, 10:29:41 AM »
"Windshield", or "Wimp-shield"? ;D
Offline DJ_AX
« Reply #12751 on: December 12, 2012, 11:52:47 AM »
Offline Really?
« Reply #12752 on: December 12, 2012, 01:37:08 PM »
I looked at one of them at a distance while I was vaping in the garage.  Then i went in the house to go watch some tv.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline fourk
« Reply #12753 on: December 12, 2012, 01:46:06 PM »
searched the web looking for cam holder caps, bought a cam & holder off ebay. cant seem to find any caps. thinking of parting it out & buying one i can find parts for
« Reply #12754 on: December 12, 2012, 01:53:35 PM »
Why would you think you could find cam holder caps separate from the holder? They are matched sets.
You'll be hardpressed to find a model with the cache of a CB750 and easier access to parts. IMO
Offline mjstone
  • I'm definitly not a
« Reply #12755 on: December 12, 2012, 06:47:45 PM »
... easy TON up at 25 degrees Fahrenheit this morning...  I like my windshield :)
Great to hear I'm not the only loon out there!  It was 22F here this morning, but you won't find me doin' a TON at those temps.  I keep it down and watch for ICE!  Did get a little worried when the big flakes of snow started to come down in the middle of my morning run.  The roads started to turn white.  By the time I parked the bus, they were all clear.
MJ
PS.
Windshields are nice, but fairings are better, especially if they have lowers!
« Last Edit: December 12, 2012, 06:50:47 PM by mjstone »
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline hoodellyhoo
  • CB350F
« Reply #12756 on: December 12, 2012, 07:25:43 PM »
I lifted up the cover to have a look at the 350 and her dismantled engine. I've been daydreeming about how nice it would be to take a picture of my two bikes together.I finish school in one week and the sooner I get a job the sooner I can throw a little money at it and get it back together and ride it again!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #12757 on: December 13, 2012, 04:00:49 AM »
sssshhhhh... that would leave more parts available for us.... ssshhhh  ;)  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
oldbob
« Reply #12758 on: December 13, 2012, 01:37:49 PM »
I brought the 400 into the basement. During the winter, I'll get the frame powder-coated. I'll also clean up the motor's cooling fins and re-check the float heights.
Offline bjbuchanan
« Reply #12759 on: December 13, 2012, 08:21:40 PM »
I made magic happen with some DCC universal coils and made my own kinda ducktail seat using a stock seatpan and two layers of yoga mat. the stock seatpan has a nice shape on a 750 once its covered. Also started setting up for a small cat eye tail light to go along with it.
If anybody is interested I could always post pics
« Reply #12760 on: December 13, 2012, 08:38:10 PM »
Pulled the latest project bike, Planet Blue K5, out of storage. Original paint. great Kerker, nice chrome rims.
Installed a freshly charged battery and cranked it over.
Started right up but only running on 3 cyl. Did not have time to look into issue.
There was a big box on the porch when I got home, knew it was the seat I bought from Madmtn. Thanks again Wilbur...
« Reply #12761 on: December 13, 2012, 10:11:57 PM »
That one will clean up well Stevo  ;)
« Reply #12762 on: December 14, 2012, 12:21:06 AM »
Ha ha, doesn't look like too much of a "project" there Steve, put the seat on, clean your carbs (It'll be dirty jets in #3 carb, I'm betting) install a new tail light lens, and take that nice survivor for a ride! (you're a lucky bastard, over here a "project bike" is a bare frame that's been broken in half, with most of the tabs missing........) ;D
Offline MoMo
  • Ride like you're invisible
« Reply #12763 on: December 14, 2012, 01:38:38 AM »
Nice "project" bike you got Stev-o.  Looks like an easy flip for profit 8)  Have fun and good luck with it...Larry
Offline Tews19
  • I am no
« Reply #12764 on: December 14, 2012, 02:29:38 AM »
Damn she really looks purty after a bath!
1970 Honda CB750 survivor.
oldbob
« Reply #12765 on: December 14, 2012, 01:24:46 PM »
I began disassembling the bike prior to having the frame sandblasted and powder-coated. Just in case anyone wants to know (I would have), the battery/air box on a CB400F comes out through the rear of the frame.
Bob
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12766 on: December 14, 2012, 02:34:42 PM »
Swapped 120 mains into the K6 in place of the 105's..should match the HM300's well, and fix that popping on decel ;)
Also pulled the throttle cable off the Bonneville bike for a replacement...getting closer ;D ;D ;)
« Reply #12767 on: December 15, 2012, 04:16:00 AM »
You should never throw anything out. That's why my garage is such a mess, but occasionally, that can work for you. The front end on my CX500 sags terribly, the 32 year old fork springs are stuffed, but good new springs are around 100 bucks per pair, plus half of that again for shipping. I went for a dig around my garage though, and found a NOS of Progressive "Magnum" springs for something of the same era, Kawasaki KZ400, from memory. The side by side pic shows that the OEM Honda springs are 40mm shorter, but have a 94mm "Preload spring" added.
I machined up some hollow preload spacers from 20mm alloy bar. Anybody who's tried to stiffen their front forks with preload spacers will know what a PITA it is trying to balance a threaded cap on top of a spacer on top of a spring and then try to push the whole lot home while turning the spanner, trying the hell not to cross thread the fine thread on the top fork plug, which in my case, is alloy.
The top plug that I'm using is hollow, so I machined one end to fit snugly in the cap, and the other to fit snugly in the spring, and it worked great, nothing went flying, and I've still got both eyes and all my teeth. Also, because the new springs are 40mm longer much thicker than the OEM items, I reduced the length of the pre-load section to just 35mm, and when I screwed the new caps in, there was no sag in the forks at all. Bonus!
Now comes the fun part. When i was a wee lad back in the 1980's, air forks and air shocks were cool. Some manufacturers (Honda included) installed air forks and air shocks onto anything from cruisers, to tourers, to sportsbikes, and you could buy an aircap kit for your bike, if you were unfortunate enough not to have them already fitted from the factory.
The best kind were those that are linked, preferably with a goofy gauge to look at so you can check your air pressure (usually around 10 psi) and watch the needle go up and down as you brake and accellerate. Great stuff. Oh, and the reason for having them, was to take the sag outta ya forks too. In this case I didn't need them as my new "magnum" springs and preload spacers were more than adequate, but my old OEM fork caps were looking pretty crappy, so I was able to kill two stones with one bird, so to speak. With the kit installed, it's all fairly unobtrusive, but it does look "trick" in a 1980's kind of way.
Surprisingly, after I got back from a 4 hour ride, the gauge hadn't lost any air!
So now I've got a nice taught front end. Hmmnnn, I must install the new fender I bought, the original one is letting the side down somewhat!
Of course, when i took it for my ride it performed faultlessly, but as is always the case, I really notiiced the shortfalls of the rear shocks. The only ones I could find in my garage are the almost new ones I took off my Triumph Rocket III when I wasted 700 bucks on some progressive 440's, but they're just a tad too wide, so I'll have to keep looking.
Maybe a set of Golwing air shocks would be nice? Of course, if I could find some sweet Fournales air shocks of the era, I'd be in shock absorber heaven! Cheers, Terry. ;D
Offline tango911
« Reply #12768 on: December 15, 2012, 11:00:12 AM »
cafe was leaking oil like crazy,  tore down, replaced gaskets, etc....   and painted.   fun fun  :/   not all in one day of course.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
« Reply #12769 on: December 15, 2012, 02:45:57 PM »
Nice! Is that a K engine in that F2 chassis? I like the pipe too, where'd that come from? Cheers, Terry. ;D
Offline fire113
« Reply #12770 on: December 15, 2012, 02:58:06 PM »
...tried to find some cb750 parts here in  mexico, no way!
Offline Dimitri13
  • 1974 CB550K
« Reply #12771 on: December 15, 2012, 03:24:06 PM »
Stupid me, I totally forgot about boxing up my head/jugs and swingarm. Heading out to the garage now to do so. Gotta get the last of the gunk off then it's going in a box in a box.
« Reply #12772 on: December 15, 2012, 03:32:22 PM »
Cleaned the carbs on the Planet Blue K5. It was #2 Terry, not #3. Also did some cosmetic restoration, personally I don't care for rattle canned black engine covers...
Had some spares laying around and swapped em out....
Then started her up and took a test ride down to the local park. Beautiful day.....
Offline Tews19
  • I am no
« Reply #12773 on: December 15, 2012, 03:56:25 PM »
How did she ride? That one is almost to nice not to be ridden daily! Great buy!
« Reply #12774 on: December 15, 2012, 04:04:49 PM »
Ok, at best, but def got better after a few miles.  Head pipes are a little blue, may be lean, may need to rejet. idles fine.
CR - did You recently put 130's in yours?
