Author Topic: What did you do to your bike today ?  (Read 3639699 times)
Offline Really?
« Reply #1525 on: March 28, 2010, 08:44:47 PM »
Cleaned the carbs.  Mounted the o-rings and carb boots.  Mounted the carb rack on them and then mounted the carb box - got it all hooked up.  Also put the condenser thing on.
Ordered a new fuse box.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #1526 on: March 28, 2010, 08:47:38 PM »
Welding like a mad scientist on some holes of a stock CL360 exhaust system. Minus any science or real intelligence of course.
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #1527 on: March 28, 2010, 09:19:45 PM »
Terry, if its drawn & rolled ,  like plate,  it is called billet..
 Large pieces that look like logs of aluminum, are called billets and are placed after preheating (or heated in the machine) to make extrusions...
 I am not sure what refined casting alloys in larger form are called..
 Keep making stuff, its fun, isnt it..
Offline mcpuffett
« Reply #1528 on: March 29, 2010, 02:21:42 AM »
Had a ride on saturday to Barrow in Furness in Cumbria with some members of the Kettle Club to Crooks Suzuki (they are a similar equivalent to Suzuki owners as Dave Silvers is to Honda owners) 8), met up with the owner Martin Crooks & his team put one of the club members bikes in the showroom as its a one off called the Incredible Kettle, and we had a ride to Lake Coniston in the Lake District  8)
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #1529 on: March 29, 2010, 06:11:56 AM »
well, yesterday...
i rode it for the first time since i got the new tank and adjusted the valves and it runs like a top. better than it ever has since ive owned it.
this week i'll get my tail light/turn sigs and update the tag and im on the road....
Offline fire113
« Reply #1530 on: March 29, 2010, 08:50:31 AM »
...bore and hone is finished  8)
Bought new valve guides and I will insert them tomorrow.
Offline moham
  • .fnord.
« Reply #1531 on: March 29, 2010, 01:07:21 PM »
Took the hybreed out yesterday. Fired right up. After making a few adjustments, got it out on the road and tooled around a bit. Got it to 95mph before my courage took leave.
Something about getting a bike you've built yourself up to those speeds that'll make you think twice, and then grin pretty wide when the wheels don't fall off and your ass doesn't catch fire...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Frankenkit
  • Industrial Strength
« Reply #1532 on: March 29, 2010, 01:08:33 PM »
+1!
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline joehardy
« Reply #1533 on: March 29, 2010, 02:37:47 PM »
I realized I put the shift fork shaft in backwards (it's got a hole in one end to receive the retainer) on my CB750- this after I re-assembled the case and installed it back on the bike. I was able to get it to come out a bit by shifting gears and rotating the drive shaft so I decided I would give it a go. I put it in neutral and then pulled it out slowly to the sound of the shifter forks dropping a bit, tink, tink, tink. Wondered if it would go back in. Flipped it around and pushed it back in, feeling a bit of resistance as it aligned with each fork finally hitting the back of the case. Wiggled the drive shaft a bit and it pushed into that hole as well.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #1534 on: March 29, 2010, 03:07:00 PM »
i pulled the rear fender and mounted the new led tail/brake/turn signal assembly onto the rear of the airtech seat. it really DOES look better like this. i will be trimming and reshaping the fender to go back on though.
Mark Twain - Notebook, 1894
« Reply #1535 on: March 29, 2010, 03:13:54 PM »
Well done Joe, I did the same thing in 1982 when I rebuilt my first K1, but didn't have the balls to try what you did, so I drilled a hole in the other end of the shaft for the shifter tang, and rode it like that for another 4 years. I wonder where that bike is now? Cheers, Terry. ;D
« Reply #1536 on: March 29, 2010, 03:19:49 PM »
Terry,
That is a real beauty!  I could sit and stare at that bike for hours.  From what kind of bike did you get those gauges?
Kirk
Ha ha, thanks for that mate, I do stare at it for hours! The gauges are just fleabay accessory ones, but they're made in Japan and are quite accurate. Only problem is that the odometer has a mind of it's own, and my 50 mile ride on Sunday flipped the odo over like 5000 miles? I'll either need to buy a new one, or maybe paint a decimal point on the lens? ;D
Last night I got home from physiotherapy (buggered back from parachuting) mowed the lawn and POR-15'd my K6 tank, so when I get home in two weeks (I'm off to Tasmania today for an Army job) the tank will be ready to paint. Ooher, I better order some new sidecovers and badges too! ;D
Offline Kinch
« Reply #1537 on: March 29, 2010, 03:58:44 PM »
Within the last week:
In a testament to always tightening everything back up even if you're "coming right back to it", I checked some wiring but neglected to tighten down my left side-cover screws because I wanted to cover the wires back up but would "come back to it" to check a couple more things.
Well I didn't get back to it and forgot so when I rode to work the next day I saw something fly by out of the corner of my eye which, of course was my (up until then) unmarred left side-cover jettisoning from my bike and catching air across the 163 at 70mph.
I cursed myself up and down the rest of the way to work and then started to weigh options for replacing the stock side-cover...all of which were inferior and very overpriced.
The more I thought about it and the angrier I got at myself I figured risking my life to recover the thing may not be such a bad idea.
Took a spin by the place where I lost it the next day and to my suprise it was sitting against the divider and didn't look shattered. Not only that but it was right at the start of a good 1/4 mile where the shoulder was a big as a lane.
Looped back, pulled off the shoulder, stuck the think in my leather and was back to freeway speed in a matter of seconds. Pulled it out when I got home and it's all intact, just scuffed up. Happy days!
1975 CB750 K5
1980 GS850L
« Reply #1538 on: March 29, 2010, 03:58:45 PM »
Hi Terry, this guy has the exact same pipes as you and he is running an oil cooler....Just thought i would show you, this bike is in Queensland.
Offline petercb750
« Reply #1539 on: March 29, 2010, 04:32:46 PM »
I just dribbled........ :-[
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline Really?
« Reply #1540 on: March 29, 2010, 04:34:07 PM »
Cleaned the K&N filter twice.  Letting dry now so I can oil it.  It is about time - it has been 16 years.
Offline Fabricator
    • crmfabrication.com
« Reply #1541 on: March 29, 2010, 04:40:55 PM »
Today I finished a simple cleaning of the float needles and jets, re-installed the works, and went for a ride...  I took pictures afterward, as I had repainted it a couple weeks ago.  I recently had the header ceramic coated, and fabbed up a little glass-pack muffler from some scrap 316 and 304 tubing in the shop.  It sounds nasty when you "let it eat"    8)
Fabricator
"When in doubt, gas it. This; to be honest, doesn't always solve the problem, but at least it ends the suspense." (Mark Gardiner from "Riding Man.")
Life is too short to dance with ugly girls.....
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #1542 on: March 29, 2010, 04:45:34 PM »
Fabricator
I like that color!  I don't know why.  ;D
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline bucky katt
    • facebook
« Reply #1543 on: March 29, 2010, 04:50:05 PM »
Fabricator
what would you charge me to build a muffler just like that one to fit on a 2 1/2" outlet header? that looks badass
Offline Fabricator
« Reply #1544 on: March 29, 2010, 05:00:36 PM »
I have made up 10 cans already.  I swaged them for a tight fit over a 2.5" outlet, but had to split mine and put a high-strength clamp on, as my header was a bit beat up.  That said, the muffler, and a clamp for $125.  If you bring your bike, I will make you a hanger that uses the p-peg bolt like mine, "on the house".   If not, you will need to figure that on your own.  These things are all stainless, including the core FWIW.
Fabricator
On edit: The main body of these mufflers is 3" od, and 11" long.  Overall is 14 1/2".  Currently the internal perforated core is about 9" long, and 1 1/2" ID all the way through.  Other lengths can be made to suit.
« Last Edit: March 29, 2010, 05:10:22 PM by Fabricator »
Offline myhondas
  • Not really such a
« Reply #1545 on: March 29, 2010, 06:22:27 PM »
Nice work ! ::) ;D
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline Frankenkit
« Reply #1546 on: March 29, 2010, 06:25:31 PM »
rode to school... made up mind to re-sno-seal my jacket and gloves after they absorbed 500% of their weight in water. ::)
1973 CL350- Lola?
Stuff for sale
Offline bucky katt
    • facebook
« Reply #1547 on: March 29, 2010, 06:27:42 PM »
i also had to retard the timing a touch, i was getting a touch of detonation at low rpms and high load, all is well now
CaliCafe
« Reply #1548 on: March 29, 2010, 06:51:31 PM »
I made the first steps in my project.  Pulled off everything except the wheels and engine.  Now I am running through all the wiring and inspecting it.
Offline bird
« Reply #1549 on: March 29, 2010, 07:56:25 PM »
Mick – What's the story with the that Seeley Honda in Brisbane? Haven't seen that bike around before. Trying to guess if that's the owner and tuner, and if so, which bike shop.
Cheers mate. ^^ bird. brissie.
