Author Topic: What did you do to your bike today ?  (Read 3194705 times)
0 Members and 7 Guests are viewing this topic.
Offline nilsey
« Reply #16025 on: November 30, 2013, 04:36:10 pm »
Haha -- that is pretty much exactly what i am doing. swapping out teh drag bars for renthal ultra low superbike bars off of amazon.....
I'm about to put it all back together but i decided to wait and research different aftermarket switches. I'll be running the wires outside the bars -- i had them inside the bars before but it wasn't worth the trouble IMO. however, i guess running the controls outside the bars will require some dremeling of teh stock controls, whic i am hesitant to do.
Any ideas on slicker control switches appreciated.
Today was a beautiful day in the 40's. I got my new Renthal ultra-low handlebars in so I figured out how to switch everything over. I was also able to fix my headlight switch (i now have low and high again) and figured out that my turn switch seems to be going further to each side than it is supposed to, thus only giving me solid turn signal lights at the full extension. When it is up to 90% slid, they blink correctly. That motogadget M-unit and buttons sure are looking better and better.
Those handlebars make such a HUGE difference. I feel like I have so much more control now. I also installed a Ram mounts cell phone holder, which I highly recommend.
Here is a pic to show that it did happen
Bike looks great, I think I am going to pick up those bars myself, give them a shot. Are they pre-drilled?
Your TS switch isn't going past where it belongs it is dirty. That "sweet spot" you find is a hallmark of a dirty TS slider. Clean it up with a light abrasive, very light as you don't want to remove material at all. Grease super light with dielectric, practically none really. The switch will work like new
Careful pulling it apart, you have a spring with a ball there but it isn't too complicated, definitely much trickier switches out there
I will have another go at it this afternoon really taking it apart and cleaning it. A little bit of acetone should help clean it up as well as a nylon grunge brush. I also want to change the spark plugs, but I had to pick up a long skinny 18mm socket.
I think I'm also going to go to goodwill / salvation army to look at some leather jackets that I can remake into a seat cover.
As for the Renthals, They are constructed differently than most bars I have seen. The inner diameter is quite a bit smaller than most, and it isn't hollow all the way through. there is some sort of blockage somewhere inside the bars. It could be near the ends, or structurally all the way through. They aren't pre-drilled; I personally want to eventually run all the wire through the bars, but right now getting to ride it is more important. I'll do some aesthetics stuff (like the seat, and painting the airbox and if I'm a really good, maybe getting the comstars powder coated.) when we are completely frozen out
1976 CB550K: stock airbox, cb650 cam swap, 4x2 exhaust, dual disc brake conversion.
1974 BMW R90/6
Offline bjbuchanan
« Reply #16026 on: November 30, 2013, 05:08:21 pm »
Fired up my rebuilt engine (again) finally. The weather has really been against me lately, out there trying to put together a top end on a windy 16 degree day, then days of bad rain. The thought of one day having a garage keeps me going
It doesn't seem to be leaking, is smoking in seemingly all the right ways and isn't making scary noises. I'm gonna make a run tonight to try to break it in a little
Nice to hear about another "shade tree" mechanic. I'm trying to fit a 450 and a 750 engine in the same parking space as their respective frames as I have no where else to work on them in my apartment complex.
Thanks, good luck!
My only saving graces are a girlfriend who loves me and an 85 yr old landlord who is deaf lol
Offline johnnyvince
« Reply #16027 on: November 30, 2013, 07:00:01 pm »
I know it's not a SOHC4, but I'm sneaking in a photo of my wife's '70 CB350, with my '72 CB750. Just cleaned them up today, and started tearing down the 750 for a winter rebuild.
« Reply #16028 on: November 30, 2013, 08:38:58 pm »
Well it's half of an SOHC4 mate, and it looks very nice. Cheers, Terry. ;D
Offline edwardmorris
  • Youngish
« Reply #16029 on: November 30, 2013, 10:40:33 pm »
Desperate time, desperate measures. Knocked loose the front axle finally, now on to drilling and removing the retainers, then hunting down those SKF replacements.
Offline jerry h
« Reply #16030 on: November 30, 2013, 11:32:27 pm »
Uncovered my bike, looked at it, covered it back up.  I hate freaking winter. >:(
« Reply #16031 on: December 01, 2013, 02:18:32 am »
Well I decided to fill Mike's freshly painted K2 cases with good internals to replace his collection of worn out, siezed and broken parts that were living in them when he brought them over. I had to replace the crank and conrods, shifter drum, all 3 selectors, 2 gearbox bearings, plus new main bearings, cam chain, primary chains, and engine seals.
I've still got to get it bored for an 836cc Wiseco kit and paint the cylinders and head, but it's getting there. I do like the Duplicolor satin ceramic engine enamel, it goes on really nicely, and after baking it at 250 deg F for a few hours, it shouldn't come off too easily either. Cheers, Terry. ;D
Offline dhall57
« Reply #16032 on: December 01, 2013, 03:18:00 am »
Good looking CB350 Johnny. A good bike for you wife too. Always liked those. I was going to get one in 1973 when I got my driver lic. but I heard that Honda was coming out with a completely new, redesigned and larger version of this bike. So I waited and got the first 1974 CB360 the local dealer got in. These bikes get bad reviews for the most part, but never had any trouble with mine other than letting my best friend borrow it and him bringing it back wrecked >:( even though its been 40 years it still pisses me off when I think about it.
« Last Edit: December 01, 2013, 03:24:05 am by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline johnnyvince
« Reply #16033 on: December 01, 2013, 05:12:29 am »
Thanks, Terry...the wife's 350 is a blast.  I think someone over at the SOHC2 forum was telling her that the wing emblems on the tank are good for a few more HP.  ;)
Offline WhyNot2
  • I'm finally an
« Reply #16034 on: December 01, 2013, 09:29:29 am »
finally played with the headlight circuit, figured out the brown/red wire was the one that provides power to it. and not the brown/white.
wired it directly, now I can ride again.........geeeeezzzzzzz.....can't believe I've been fighting this for the last 2 months.....
But, I will order a new wire harness (cause i'm lazy, and the harness is (imo) fairly cheap) and i guess when I get the harley back i'll tear into the 750, replace seals that are leaking, play with carb.......paint the tins on the 350, and hopefully have them both ready for the spring/summer time.
« Reply #16035 on: December 01, 2013, 02:14:32 pm »
Back from vacation in Sunny Florida and went for a ride on the K8.....
Also worked on the Z1 today, got the new #1 & 2 mounted up...
Offline MoMo
  • Ride like you're invisible
« Reply #16036 on: December 01, 2013, 02:21:45 pm »
Nice pipes Stev-o, on the Kawi that is...Larry
« Reply #16037 on: December 01, 2013, 02:32:47 pm »
Zed's looking great Steve.... ;)
« Reply #16038 on: December 01, 2013, 02:42:49 pm »
Thanks, but pretty sweet pipes on the K8 too!
Thanks Mick, excited to get it back on the road, ya know...
Offline goldarrow
  • one day, i'll be an
« Reply #16039 on: December 01, 2013, 02:47:52 pm »
Stevo, nice pipes and great job on the bike!
There's a 77 kz1000 in my area for $1k, but no room or cash :(
CB550 K0
« Reply #16040 on: December 01, 2013, 02:53:57 pm »
Thanks Gold dude.  The Kaw 1000's are not collectible, need to stick to the 900's, or even more so, the Kaw two strokes [H1 & H2].
« Reply #16041 on: December 01, 2013, 04:26:28 pm »
Very good looking machines, Stev-o!
Since we are in mid 40ties now, I am riding again, about 50 miles a day just to stay happy.
Today I realized I did not use 2nd once, the #2 is slipping and I got into a habit using 3rd instead, LOL.  You can train even an old dog. :)
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #16042 on: December 01, 2013, 05:36:52 pm »
Good info on the Kaw's Steve-O, my buddy has a Kaw 1000LTD and he thinks it's the cats a$$! I light the candles up on the K3 today for the first time in a month of hibernation. #1 wasn't digging it's spark plug...so it now has a new one and is purring perfectly... 8)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Vicman
« Reply #16043 on: December 01, 2013, 06:16:01 pm »
LOL, I have to do the same thing on mine. The messed up part is when I get on my KZ I forget and skip 2 on that one as well.
I got the turn signals to light up on the 71 but no blinky action. I think a new winker is in the cards. :-\
Fluent in three languages, English, sarcasm, and profanity.
Offline MarshallCS
  • The Audio Ninja
  • The things I can control are in control
« Reply #16044 on: December 01, 2013, 06:37:23 pm »
I would love to get a set of motogadget switches to use, but it would get pretty expensive to do so.
I tried to take apart the stock left control, but the screw holding the turn signal switch was really tight, and I didn't want to strip the screw. I cleaned it as best I could, but with no success. It looks like to me that the springs are too compressed, but it would require disassembly to stretch them back out.
I also really want to find some replacement levers for the clutch and the brake; it feels like a large stretch for me to grab them. From what I've read, I can't just purchase something like the CRG roll-a-click levers that have an adjustable throw.
Also debating some heated grips. My hands have been freezing and I'd really like to keep riding as long as possible. Just bought some Alpinestar SP-2 gloves (tried on about 50 gloves to find a good fit) and the just let too much of the wind through, and I can't really afford to buy another set of gloves at the moment.
Maybe I'm just a bit dejected at the moment. Rode the other day and didn't feel comfortable at all, even though the previous ride was fantastic.
First and Only Bike
1978 Honda CB750F Supersport
Offline Carver
« Reply #16045 on: December 01, 2013, 08:05:15 pm »
Resolved to do a lot today, then found out someone stole the mother effing pallet i got to put my engines on while i work on them that piece of crap  >:( :'( so I just coated the 450's bolts in liquid wrench and pulled the exhaust/carbs off the 750.
Cb 750 k3
Cb 450 dohc k4
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #16046 on: December 02, 2013, 05:45:24 am »
Old MAC 4-1 canister muffler is being chopped so I can use the mid-pipe to attach to the new Cone Eng 18" reverse cone. My father teaches a metal working course at the highschool, so he has some great tools to be used. Should be test fitting this weekend.
--Evan
1975 CB750K "Rhonda"
« Reply #16047 on: December 02, 2013, 01:18:57 pm »
disagree...certainly more collectible than a k7/k8 or any 550.  There were some limited production ones too, that are quite valuable such as the mk II and the Z1R.
Offline RodPlunger
  • Annoying New Guy...
  • The road goes on forever....
« Reply #16048 on: December 02, 2013, 05:00:22 pm »
Took the bike out for it's second ride... Got out near a friends house, started running really rough, wasn't sure what was up. Pushed it to his place, pulled the plugs thinking they might be fouled... After a long while, I realized I had just run out of gas. Ha ha. Well, it's better than finding out I had other problems. I just need to fix the gears in my head....
1977 CB550F Supersport
"We want to be free.
We want to be free to do what we want to do.
We want to be free to ride.
We want to be free to ride our machines without being hassled by The Man...
And we want to get loaded!
Offline vigiltln
« Reply #16049 on: December 02, 2013, 08:19:36 pm »
Removed swing arm and sent to Hondaman for rebuild. Installed Hondaman ignition.
