Author Topic: What did you do to your bike today ?  (Read 3265368 times)
« Reply #16125 on: December 13, 2013, 01:20:54 PM »
Looked at mine longingly as I moved the snow blower up to the front of the garage.  >:(
That concept is so foreign to me... I'm drinking around 3 to 5 liters of water a day to try beat the humidity..... :o
Offline Davez134
« Reply #16126 on: December 13, 2013, 01:42:50 PM »
What's a liter? ;) ;D
« Reply #16127 on: December 13, 2013, 02:04:02 PM »
There's close to 4 liters to a gallon.... ;) ;D
« Reply #16128 on: December 13, 2013, 03:06:34 PM »
Another one "ran when parked" will go pick it up later this afternoon.
Gold dude.....you sure have aged!
Offline goldarrow
  • one day, i'll be an
« Reply #16129 on: December 13, 2013, 03:48:52 PM »
And I turned white, LOL
Original owner since new, who didn't take care of the bike
CB550 K0
« Reply #16130 on: December 13, 2013, 03:56:44 PM »
HA!   Looks like a sweet bike though, nice find.
Offline Powderman
« Reply #16131 on: December 13, 2013, 04:47:47 PM »
It's an "other bike" but I had a tab welded on my XR Sportster today for mounting the fairing. Then I was done I rolled it next door to the owners race car shop to put it on an accurate set of scales. I was quite surprised to see what I thought was a 360lb  bike (weighed it 10 years ago at 360 before some substantial modifications since then) actually weighed in at 332lbs.
The 3 numbers are 111lbs front, 64lbs on the kickstand and 156lbs rear.
« Last Edit: December 13, 2013, 04:49:48 PM by Powderman »
Offline edwardmorris
  • Youngish
« Reply #16132 on: December 13, 2013, 08:13:26 PM »
Endured the ordeal that is removing wheel bearings, all five of them.
Offline fire113
« Reply #16133 on: December 14, 2013, 06:32:08 AM »
...finished the K0 gauges
« Reply #16134 on: December 14, 2013, 07:28:05 AM »
Beautiful!   What are you doing with all these gauges?
« Reply #16135 on: December 14, 2013, 08:40:34 AM »
I found the perfect bike for my Batcave!  [Thx to Mike Kato]
What do you think, should I get it??  awesome muffler...
Offline fire113
« Reply #16136 on: December 14, 2013, 09:10:16 AM »
...I bought this set for my next K0 project, only a few parts needed to complete it  ;)
Offline goldarrow
« Reply #16137 on: December 14, 2013, 09:15:12 AM »
Go get it stevo!  I have a matching pair if vintage converse batman shoes you can have to ride the bike!
CB550 K0
« Reply #16138 on: December 14, 2013, 09:37:05 AM »
I've got to have those shoes, Gold dude, name your price!  Off to go look for matching Batgloves....
Offline Bankerdanny
  • Endeavor to persevere
« Reply #16139 on: December 14, 2013, 10:12:45 AM »
Hells yea!
« Reply #16140 on: December 14, 2013, 01:22:07 PM »
Finished installed the new 4-4 exhaust on the Z1 and took it for a spin!
Offline MoMo
  • Ride like you're invisible
« Reply #16141 on: December 14, 2013, 01:29:30 PM »
Looks great, thought it was 26 down there...Larry
« Reply #16142 on: December 14, 2013, 01:34:15 PM »
It was last week, 50 degrees out now, still a little chilly on the bike at 80!
Offline Carver
« Reply #16143 on: December 14, 2013, 01:53:54 PM »
got a bolt out that iv'e been doing battle with for a couple of days. Finishing up trying to get everything on the 750 removed so the engine can get popped out.
Question, for the 836 kit does anything need to be modified? or is it just plug and play with the pistons?
Cb 750 k3
Cb 450 dohc k4
Offline goldarrow
« Reply #16144 on: December 14, 2013, 02:24:12 PM »
http://bit.ly/18Mph6c
That's if I could find them in the bottom of my treasures closet!
CB550 K0
Offline Powderman
« Reply #16146 on: December 14, 2013, 04:51:10 PM »
Looking fantastic Steve, now get that sucker painted, that horrible paint scheme offends me so! ;D
« Reply #16147 on: December 14, 2013, 05:50:09 PM »
Your 836 question is open for a lot of debate. A lot depends on your intentions with it and how much you want to spend. Some porting would really wake it up. Maybe beef up the top end if your really going to run it hard. New rubber cam chain goodies would be nice. The list could get very long. Simple piston swap will work also for a little more oomph. Are you using one of the low compression cheap E-bay kits. If so make sure the rings fit nice on the piston grooves first and check the gaps. Heck enough stuff for a whole thread i'm sure from the folks..
« Reply #16148 on: December 14, 2013, 05:53:51 PM »
Correct Ekpent. Depends on intent. How much work to be done otherwise. How much $$.
I've had an 836 with virtually no other changes. Nice difference to stock. Not enough difference to stress anything else.
836 with a pipe and head. Much nicer difference. Etc.
Offline Carver
« Reply #16149 on: December 14, 2013, 07:05:45 PM »
Well my intention is to make the 750 my "rider". The 450 just does not cut it on the interstate. It keeps up fine but an hour in and my whole body is numb and it gets really wound up, like 7000-8000 rpm cruising. Its going to go on out of state trips so I would like a little more oomph for interstate riding passing at high speeds etc (anyone who's been on i-75 FL or ATL knows what I mean.) and so I could keep the rev's down a little. Not trying to make it a works engine or anything. Just figured since the kits were cheap on ebay and I'm already gunna have the engine out, why not give it a go eh?
Cb 750 k3
Cb 450 dohc k4
