Author Topic: What did you do to your bike today ?  (Read 3264426 times)
Offline Norniron400f
« Reply #16275 on: December 27, 2013, 03:37:37 PM »
I stripped my carbs.replaced the 98 main jets for the original 75's and moved the clip up to the top groove.im running pods so i'l give it a go.i just hope raising the clip richens the mixture.
Offline krusty
« Reply #16276 on: December 27, 2013, 04:33:41 PM »
My '77 DT175E has been leaking oil from the change shaft for a while so decided to replace it. Then took it for a run checking out a few of my geocaches. All good, no more oil on the shed floor.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline edwardmorris
  • Youngish
« Reply #16277 on: December 27, 2013, 05:24:53 PM »
Made time to tear down the engine head, nothing but a series of failures, missing dowel, torn seal, possibly bent valves or bad guides (2 of them). Not a good day...
Offline fire113
« Reply #16278 on: December 28, 2013, 01:49:57 PM »
...drove ~850KM to get the K1 that I bought myself for Christmas  ;D
« Reply #16279 on: December 28, 2013, 05:36:41 PM »
Looking good Georg! ;D
  • Youngish
« Reply #16280 on: December 28, 2013, 05:54:09 PM »
Shifter assembly is out, hoping to get the cases split before bed.
Offline Vicman
« Reply #16281 on: December 28, 2013, 06:12:45 PM »
Got really  cold after getting really wet. I think I'm gonna put that front fender back on if I'm going to keep riding in this crappy weather.
Fluent in three languages, English, sarcasm, and profanity.
« Reply #16282 on: December 28, 2013, 06:30:36 PM »
+1....worth the trip.  How'd you find this one?
« Reply #16283 on: December 28, 2013, 08:53:42 PM »
Primered my 750K8 frame after hours and hours of degreasing, pressure washing, paint stripping, more pressure washing, sanding, pressure washing again, and acetone baths.....and I received my new $25 valve spring compressor.
  • Youngish
« Reply #16284 on: December 28, 2013, 08:59:17 PM »
Very different looking from all the ones I've seen. I settled for this one
Dial once and squeeze, made quick work of the 8 valves I recently removed.
« Reply #16285 on: December 29, 2013, 08:08:07 AM »
I used a hammer, a rare earth magnet and a tall socket to remove my retainers  ;D
this is just for putting them back on...
« Reply #16286 on: December 29, 2013, 09:16:26 AM »
Good gift from Santa!
Nice rear tire! Metzeler ME99 no longer available....
Offline fire113
« Reply #16287 on: December 29, 2013, 10:17:05 AM »
...did the electric but NO SPARK  :P as I removed the cover I saw why  ::)
EXTRAPRESENT  ;D Thought that only the fork is K0 but Santa put a HM300 on it  ;D
but with HM341 ends caps ?!?!?
Moved the racer and the K1 and a lot of parts in an extra room and put a RAASK foot peg set @ the racer.
Now I need some food and beer ;)
Have a good one...Georg
Offline johnnyvince
« Reply #16288 on: December 29, 2013, 10:49:06 AM »
Bought a super-cheap impact socket set from Northern Tool+Equipment, that looks fine for motorcycle wrenching. http://www.northerntool.com/shop/tools/product_200485060_200485060
Equipped with the bigger sockets I've been lacking, I was able to finish bagging and tagging all of the old parts on my K2.
I've currently got a hi-fi speaker project taking up much of the basement, so I've got to spend a week or two wrapping that one up, before there's enough room for the bike. Meanwhile, my online shopping cart overfloweth...  ;D
  • Youngish
« Reply #16289 on: December 29, 2013, 11:58:37 AM »
Got all the bolts off the crankcase but it refuses to split open. Suggestions/advice welcome on my build thread in my sig.
Offline bjbuchanan
« Reply #16290 on: December 29, 2013, 09:52:47 PM »
Make sure you got off all topside bolts, including those under the starter. Then get a flat head screwdriver and man up
« Reply #16291 on: December 30, 2013, 02:16:29 AM »
Well I woke up this morning (which is always a great way to start the day, or perhaps, a blues song) and wasn't sure what I wanted to do. The sun was shining, it was around 75 degrees, and I needed to do some bike stuff.
I had to do some banking, so after that I dropped into Ace Motorcycles to bum a cup of joe and a cigarette off Jeff, and he pointed me at my next project bike, a 1987 Yamaha FZR1000. I've wanted once since new, but they were always pretty thin on the ground here, so hopefully the owner will accept my offer, and it'll be in my garage soon.
Speaking of my garage, sadly there's not enough room for another bike, so I'll need to move one on. My 1987 FJ1200 is a great bike, but if any has to go it'll be it, so I need to do some work on it to make it sell-able. It's in generally good order, but the previous owner admitted that he'd done no maintenance in 5 years, and only did a couple of thousand miles in that time so the battery was clagged, the front brake discs are screwed along with the pads and fluid, it needs an oil and filter change, a seat cover, and few other bits to bring it back up.
Once I got home I started with replacing the discs. The original discs were lightweight ventilated things, and wore out in 30,000 miles. The ones I replaced them with are solid ones from our Chinese friends via eBay, they were cheap, but they look the goods, so hopefully they'll be OK.
The good thing about being on vacation is that I don't have to rush, so I'll leave the brake pad replacement until tomorrow as I want to give the calipers a good clean first. I washed up and fired up the barbecue, and cooked the last of the Christmas meat. All the steaks had gone, but there were burgers, snags and hamsteaks, and washed down with lots of beer, a fine repast. Cheers, Terry. ;D
Offline dhall57
« Reply #16292 on: December 30, 2013, 03:24:14 AM »
Enjoy your time off Terry ;) If your like me the vacation days always seem to fly by and before you know it your back at the job.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #16293 on: December 30, 2013, 06:09:53 AM »
Man I can hear the heart valves slamming shut clear over here!  ;)
« Reply #16294 on: December 30, 2013, 06:54:33 AM »
+1...Holt #$%*e Terry, that's your lunch??
Offline dhall57
« Reply #16295 on: December 30, 2013, 07:05:19 AM »
Looks good, but I would say that's not one of your heart healthy meals Terry ???
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Bankerdanny
  • Endeavor to persevere
« Reply #16296 on: December 30, 2013, 07:29:38 AM »
Now THAT is a meal! Bravo.
« Reply #16297 on: December 30, 2013, 02:52:07 PM »
Thanks guys, I'd say that my eyes are bigger than my stomach, but that's not true, but even though I'd skipped lunch I couldn't get it all down, but I did give it a big try. It's 10am as I type this, and surprisingly, even though I haven't had breakfast yet, I'm not actually hungry.......... ;D
  • Youngish
« Reply #16298 on: December 30, 2013, 02:53:54 PM »
Gordon kit installed on frame, kickstand modified to add 2".
Offline Ichiban 4
  • "Ichi"
« Reply #16299 on: December 30, 2013, 04:03:19 PM »
Yeah..well..I was thinking the same thing when seeing that pic of Terry's "repast" Ron.  Curious mix of hedonistic envy..and knowing my docs would have a conniption-fit if I ate that myself. "However"..I do sneak-in a good "barby" meal myself..maybe once or twice a year..and when the wife isn't checking too close.
Long gone are the days for me when could eat..drink..smoke with abandon.  But Terry's still a young bloke..I figure..compared to some of the rest of us.
Hey Terry..just marry a Japanese.  Then..all the fish..rice and veges (yeah..lots of veges)..seem to satisfy not only the wife..but docs as well.  Took a little getting used to (for basic meat and potatoes type guy)..but actually enjoy eating like that nowadays. Guess you there in Oz also have a pretty good selection of fish..vege..et al that you do on the barby..eh Terry?
Anyway..Happy New Year guys.  Made myself hungry here talking about it..
Al / Ichi
Al Summers
Present: '77 550K
