Author Topic: What did you do to your bike today ?  (Read 3251214 times)
Offline KayOne
« Reply #16425 on: January 08, 2014, 03:09:42 PM »
Sent my 750 K1 tins in for paint. I'm real nervous about it as I usually do most of my own work. Painter has been spraying bikes since 1969. Painting it the original Candy Gold. I may have the bike ready in early June after a 2.5 year build. Here's hoping it turns out!
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
« Reply #16426 on: January 08, 2014, 04:02:55 PM »
...was searching parts for the K0 engine, was thinking about to make this engine real fast but I am not 100% sure :-\
That's a nice looking head you've got there Georg, I've got a K0 cylinder block that's been bored to 836 and a set of Wiseco pistons coming out, and even though I was going to keep the bike fairly original no-one will see the bigger pistons, so they'll probably just assume that the legends about K0's are all true, and they are faster than the later models......... ;D
Offline Jayelwin
« Reply #16427 on: January 08, 2014, 04:09:47 PM »
WORK?!?  No work here.  I'm a lazy fkr.  ;D  My wife already had the dye.  I actually didnt spend a dime on this....but a bottle of RIT might run you $4  ;D
Maybe a 10 minute soak in RIT, and then another 15 with a 320 grit sanding buff attached to my dremel. Done.
Stainless?  $50+? I dunno  :-\
Mine are ugly. I'm gonna try this.
Sent from my iPad using Tapatalk HD
Offline Runuv
« Reply #16428 on: January 08, 2014, 06:37:07 PM »
I received my exhaust from DSS today, didnt take long to get here. I'm going to wait for the weather to warm up then install it on my CB400F.
Almost there!
Offline maduncle
  • Don't confuse me with a
« Reply #16429 on: January 09, 2014, 11:02:07 PM »
I bought an exhaust today - finally found a good set of Hooker headers with muffler for a CB450.
Plus I got a pair of Ceriani 35mm forks in the mail, and a pair of 74mm pistons for the CB450 - a good day.
CB750K2 (only slightly modified)
Offline Destruckto440
« Reply #16430 on: January 10, 2014, 01:55:08 AM »
Fixed leak on #4 carb bowl (cheap over sized o rings). Re-sync carbs and check timing.  Then went to dmv to get title and tag. I cant wait to ride tomorrow...
1978 CB550K
« Reply #16431 on: January 10, 2014, 03:31:40 AM »
Made sure the tarp is on for the freezing rain today.
Offline jonda500
« Reply #16432 on: January 10, 2014, 03:33:23 AM »
unscrewed all the plug caps off my 550F, checked the resistance - they were all just under 5Kohms (then checked all 11 other plug caps in my possesion- all 5K cept the one new one -10K) dunno what I had set wrong on my analogue multi meter last time I measured these but I'm happy with the readings today! Then I checked the coil wires for continuity 1-4 and 2-3 they passed(both 15Kohms)
A starter clutch thread:
Offline jUNKER
« Reply #16433 on: January 10, 2014, 05:10:28 PM »
Finally got all the parts needed and phillps heads out of the cover. Got the kicker on and ready to take apart clutch while the cover is off.
Offline Jerry E.
« Reply #16434 on: January 11, 2014, 08:20:04 PM »
Installed my new "shorty" rear shocks, on my K3. Really lowered  it, combined with new -1" front forks. looks good.
"Why jump from perfectly good airplanes? Because the door opens."
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #16435 on: January 11, 2014, 09:51:56 PM »
I used my bike as support for some crown molding I was cutting. I thought to take a pic. Chop saw was on a table where the bed was about the same height as the top of the tank. Don't worry, I had a sweatshirt on top.
« Reply #16436 on: January 11, 2014, 10:01:45 PM »
Yesterday I stripped the front end off the '77 GL1000 roller that's been sitting here for over a year sans engine, with the intent of using it on my CB750. Luckily for me, the GL forks have Progressive springs in them, but the old alloy air caps were pretty badly weathered.
I hunted around my garage and found a NOS of S&W Air caps for some unknown forks with the right thread, but the threaded portion was around 6mm too short, and even though I could screw them in a couple of turns, it wasn't enough.
I chucked the fork tubes in my lathe and machined off 6mm from the top of each tube, and Voila! The caps are a good fit.
Before:
After:
The're not the best forks I've seen, but after I cleaned them up with some 800 grit wet and dry paper and WD40, I removed any rust and high spots (someone had clamped them in a vise and gouged them in their 37 year history) and they should work fine. Good news is that they're both straight.
I also stripped the paint off the calipers and triples, and I'll give them a coat of paint tomorrow. Cheers, Terry. ;D
Offline edwardmorris
  • Youngish
« Reply #16437 on: January 11, 2014, 10:17:04 PM »
Scraped off yet another gasket, this is getting old
Offline Jerilee
« Reply #16438 on: January 12, 2014, 12:24:37 PM »
Finally ordered the last of the used caliper/brackets I needed for upgrading the '77 to a dual piston style calipers. Purchases have been slow because of finances and progress has been slow because of the COLD AS FREAK WEATHER! Between snow, ice, cold -repeat, I haven't set a hand on the bike in a month or three.
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline fire113
« Reply #16439 on: January 12, 2014, 12:30:09 PM »
...scored some NOS CB750 parts but I missed the K0 Sandcast speedo  :'(
« Reply #16440 on: January 12, 2014, 01:57:01 PM »
Battery tray, center stand, swingarm stripped and ready for paint.
Triples installed on frame w all balls kit.
Vapor rebreather emptied of mayo. Cleaned and rebuilt.
Misc nuts and bolts, brackets, engine mounts.....treated in PrepNEtch.
5 min is all most parts need.  Love this stuff!!!
« Reply #16441 on: January 12, 2014, 02:40:27 PM »
I'd never heard of it so I checked it out online, Prep N Etch is phosphoric acid, and is great for removing rust from steel, I use in gas tanks before I seal them, it's great for cleaning up chrome etc. Just be careful leaving any cast iron or "potmetal" (petcocks, blinker bodies etc) in it, it'll dissolve them very quickly.
I left a set of 836cc cylinder sleeves in a bucket of phosphoric acid overnight, and next morning they were just a stain in the bottom of the bucket, and another time I put a tank in a tub of the stuff and my petcock disappeared, all that was left was the copper tube.......... ;D
« Reply #16442 on: January 12, 2014, 06:20:12 PM »
Rode for a few hours. Changed oil and filter. Polished some chrome.
1978 CB550K
« Reply #16443 on: January 12, 2014, 06:59:05 PM »
Terry.  This stuff works wonders on tank interiors when light rust has taken over. Too long and you might spring a leak. Leaves a light grey phosphorus coating.
And yes, 5 min at full strength was all that was needed to remove years of corrosion.
No scrubbing needed  ;D
« Reply #16444 on: January 12, 2014, 07:54:38 PM »
Thanks mate, I'm using some now to remove the rust from my GL1000 lower triple and gauge bracket. Cheers, Terry. ;D
Offline Ace
« Reply #16445 on: January 13, 2014, 06:12:34 AM »
Replaced starter clutch as it was stuffed. Managed to torque the rotor bolt with help from next door and got both alternator and gear shift cover back on. Tomorrow's job it to put the cam and towers in and hopefully button up the top.
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
  • Youngish
« Reply #16446 on: January 13, 2014, 12:40:34 PM »
Removed some of the excessive carbon build up on the replacement head last night, hoping to finish it soon. Between work, home and bike, I'm losing track of time. Then I saw this and cheered up
T-Mobile Motorkáři: Srážka s prasetem
Offline mrbreeze
  • Not your average
« Reply #16447 on: January 13, 2014, 12:54:54 PM »
 ;D....ha!
MEMBER # 257
« Reply #16448 on: January 13, 2014, 12:56:50 PM »
hahahahaha!
thanks!
« Reply #16449 on: January 13, 2014, 12:59:20 PM »
Tell you what:
- that scooter is called piggy, because it looks like one
- it was made in Czechoslovakia
- they speak Czech in the commercial
- I worked for that company in Prague - T-Mobile -  before moving to USA
Thanks for sharing!
« Last Edit: January 13, 2014, 01:01:27 PM by 70CB750 »
