Author Topic: What did you do to your bike today ?  (Read 3965839 times)
0 Members and 25 Guests are viewing this topic.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17400 on: April 29, 2014, 04:57:27 AM »
Put my new LED lights and flasher on today. Front right low light (blue/white wire) when the headlight is on is not lighting up, and it didn't for the incandescent, either (I think). Going to chase this one down...
I wonder if it could be a ground connection for that light ?
I went out the other day and it worked fine this time. I am going to pop the headlight off again and double check all connections, just to be sure.
--Evan
1975 CB750K "Rhonda"
Offline thrutheframe
« Reply #17401 on: April 30, 2014, 04:39:07 AM »
Built this:
For this:
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
« Reply #17402 on: April 30, 2014, 04:41:37 AM »
I need some rubber sheets to insulate my ignition wires.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
« Reply #17403 on: April 30, 2014, 04:47:26 AM »
Needed a couple of fresh 14L A2 batteries for the 750's. Might be selling a few also so new battery is a good selling point. Went on the Advanced Auto website and got a coupon code and bought two batteries online with Paypal to pick up for $33.00 each. Pretty cheap as Wally World batts are now up around $45.00. May need a few more  ;)
« Reply #17404 on: April 30, 2014, 04:51:40 AM »
Might be selling a few...
What? Eric might be selling??  Is Hell freezing over?!!
« Reply #17405 on: April 30, 2014, 04:55:27 AM »
It is freezing as we speak, meeting a guy at 11:00 AM this morning to give him a sneak peek at the first batch. Not getting rid of any of the good stuff though !!
Offline tennesseebreeze
  • Better to be lucky than smart.
« Reply #17406 on: April 30, 2014, 06:29:10 AM »
Smoothed the air intake ports in the cylinder head. Ordered valve guides. Discovered pitting in a couple valve seats.
'79 CB750F, '73 CB500K2, '78 CB400A, '71 CL100
Offline ChrisP.
  • Hold my drink and watch this...
« Reply #17407 on: April 30, 2014, 06:35:55 AM »
Rode my bike so hard the shifter fell off! :o
Chris P
1973 Honda CB750K3
« Reply #17408 on: April 30, 2014, 06:40:49 AM »
What?  no way.  Did the bolt fall out?
Offline ChrisP.
« Reply #17409 on: April 30, 2014, 06:49:18 AM »
Nope. I guess it just wasn't tightened enough. I probably should take a moment to go through the bike (like I should have before I rode it the fist time) and make sure everything is buttoned up, for the sake of safety. It was a pretty weird experience; I was going through the gears and went to shift into 3rd and didn't feel the shift lever! Luckily I was only about 300 feet from where I lost it. I can only imagine losing it last Saturday night when I went with some friends out in the countryside about 30 mins away! :o
Chris P
1973 Honda CB750K3
« Reply #17410 on: April 30, 2014, 07:04:01 AM »
You found it? Lucky.
« Reply #17411 on: April 30, 2014, 07:08:35 AM »
Yeah, do a "nut and bolt" before your next ride. Dont ever trust the PO...ha!
Offline ChrisP.
« Reply #17412 on: April 30, 2014, 07:11:04 AM »
Ha! I know better. Was just too eager
Chris P
1973 Honda CB750K3
« Reply #17413 on: April 30, 2014, 07:11:37 AM »
LOL, that's a first.  Glad you found it.
Offline ChrisP.
« Reply #17414 on: April 30, 2014, 08:09:19 AM »
You mean to tell me I'm the first to lose my shifter lever or the first to find it?!
Thanks! I'm glad I found it too and had just the needed 10mm to tighten it up!
Chris P
1973 Honda CB750K3
« Reply #17415 on: April 30, 2014, 08:20:54 AM »
First to loose it I think  ;D
All in good spirit man, I had to tighten mine on a bike before, but never had it come off on it's own.
It takes time to build the trust for the bike :)
Offline evanphi
  • Apparently I'm an
« Reply #17416 on: April 30, 2014, 09:18:30 AM »
Now I'm paranoid my shifter is going to fall off! :D
--Evan
« Reply #17417 on: April 30, 2014, 09:28:57 AM »
The elusive clutch cam lifter came in the mail yesterday.
Buttoned up the clutch and finished it off with a shiny NOS chromed cover  8)
Offline Tews19
  • I am no
« Reply #17418 on: April 30, 2014, 01:16:42 PM »
Picked up my 550 cases from the shop... Had it degreased and cleaned. Ordered new pucks and an entire gasket kit for the engine...
Now I need to find a flywheel puller for my 550....
1970 Honda CB750 survivor.
Offline evanphi
  • Apparently I'm an
« Reply #17419 on: April 30, 2014, 06:25:48 PM »
Changed my oil and filter. Put in 3L of Castrol 10W40. Mmmmm... Dinosaurs. Of course, like most, I am missing the big washer between the spring and filter. Oh well. My freshly painted (but already peeling. Damnit) header got a nice oil bath when I removed the filter housing. Lesson learned... remove exhaust first next time.
Sprayed her down with a #$%*ty pressure washer from WallyWorld, trying to get brake dust and oil crud off the rear wheel... which broke and stayed ON after five minutes of use. Just used a hose afterwards. That thing is going in the garbage! Manual scrubbing with a wire brush it is!
Rode her like stink to my parent's place so my dad could see the new setup. He wants to get a Honda Shadow.
--Evan
Offline ryanj
« Reply #17420 on: April 30, 2014, 11:05:01 PM »
Today I was finally able to start working on the '76 550F I picked up almost 2 months ago.  I ran the switch wiring through the handlebars (which was only kind of hateful) and took off the carbs to clean them.  Since it was partly disassembled when I got it, I've never heard the bike run so I figured I'd start with clean carbs and go from there.  They weren't *too* bad and now they're spotless although I was kinda pissed to discover all the brass has been replaced by Keyster parts.  I was really hoping, after reading everything on here, that the original needles and stock jets, etc. would be in there.  Hopefully they're not too awful and I can get it up and running and properly dialed in.
1976 CB550F
Offline krusty
« Reply #17421 on: April 30, 2014, 11:57:06 PM »
I had to drop off four Honda S600 hub caps at the platers so I decided to take the FJ1200. Asked the wife if she wanted to come too as she hasn't been on the bike in over six months due to having hip replacement surgery in February. I knew that the FJ's battery (Motobat) was on its way out but I had charged it up last weekend and thought it should be ok - it wasn't. Took the hub caps in to the plater and when we went to leave the FJ wouldn't start. Got the missus to give me a push along the street and on about the 4th attempt to bump start it fired up.
Decided on the trip home to call in to my local reliable bike shop, Sportcycles, and pick up a new battery. Kept the motor running while there and also ordered a new Metzler Marathon for the front and booked it in for its annual roadworthy. On the way home we pulled up at an intersection and I stalled it. Bugger. Pushed it off to the side of the road, got the tool kit out and swapped in the new battery, the missus passing me the tools as needed. Should have changed it back at the shop - doh.
Happy to say that her new hip was just fine after climbing on and off the bike and pushing it down the road. We have a 200k VJMC club ride coming up on Sunday so looks like she's fit to go.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #17422 on: May 01, 2014, 12:55:08 AM »
G'Day Krusty, good to see other FJ1200 pilots out there, I love my 1TX. Bike batteries don't like sitting for long spells, so I've invested in several trickle chargers over the last few years, and so far I haven't had a battery die in the last 7 years. (My 2007 Triumph Rocket III's original battery is still in excellent shape even though it sat unused for 2 years before I hooked it up to the charger)
As I've said, I've tried a few chargers, from 35 dollar cheapies right up to the 300 dollar BMW charger that the Triumph is plugged into, but the best by far are the two Optimate 4 chargers that "recondition" batteries and are able to recharge them, even after they discharge to the point where a regular charger won't put a charge back into them.
When I bought my 1TX the seller told me that the battery in it was stuffed, so I took it out and hooked it up to the Optimate4, and it charged it right up, and 6 months in, it's still holding it's charge. My old ride-on mower has been sitting for a year outside without getting a run, so last weekend I hooked it up to the Optimate, and even though that battery is 8 years old and had 0 volts according to my multimeter, it's now holding 13.8 volts.
If you haven't thrown your old Motobatt out yet, you might be able to throw a charge back into it, and keep your other bike batteries well maintained too. Cheers, Terry. ;D
http://www.ebay.com.au/sch/i.html/_W0QQ_sopZ12?_nkw=optimate%204%20battery%20charger&_fromfsb=0&_trksid=m270.l1313
« Reply #17423 on: May 01, 2014, 12:59:11 AM »
Ooher, and you've got an S600 as well? I had one back in the 1970's, and my cuz has a nice one still. (albeit with a Corolla engine and drive train) My sister had an S800 convertable too, they were a wicked little car! Cheers, Terry. ;D
Offline krusty
« Reply #17424 on: May 01, 2014, 01:43:11 AM »
Wife and I love the 3XW FJ, it's a 95 model, we've ridden it to VJMC rallies in QLD, Great Ocean Road and out west NSW, etc., BTW what's good for cleaning off millions of bugs after riding by all those canola crops you've got down there? Those bugs pissed me off, oops, wrong thread. Anyway, it never misses a beat. It's my second FJ, the first was an 88. I'm a bit slack when it comes to maintaining batteries as we like to go away on holidays a couple of times a year for 3 or 4 weeks at a time and I don't bother to leave it on a charger. As well as the FJ (on full reg) I've got 4  bikes on club plates. I'm gradually swapping them all to Motobats. I'll check out the Optimates.
The S600 belongs to a mate, he's a young bloke but he's probably the best bike and car restorer I know (I've been a VJMC concours judge in the past).
The 3XW
and the S600
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
