Author Topic: What did you do to your bike today ?  (Read 3891073 times)
0 Members and 21 Guests are viewing this topic.
« Reply #17500 on: May 07, 2014, 03:29:16 AM »
I got the turbo back on the road! ;D Bill
The turbo increase the heat? You must use synthetic oil, right?
My engine is running rather hot (230F) and I'm investigating the market for oil that can cope with the higher temp and eventual oil cooler.
My car ran very hot in the turbo, cooler with Milltek sport cat and exhaust. Synthetic a must there.
« Reply #17501 on: May 07, 2014, 07:57:39 AM »
Recently got my everyday rider started for the first time and went to give it a shakedown run and heat it up for a oil change. Got back and the ignition would not turn the engine off, then when shut down the headlight would not go off. Couple other electrical glitches also. WTF ? Disconnected the battery and pulled the sidecover and sure enough the bottom spade on the headlight (middle) fuse had broke as was completing a rogue circuit. Time to dig in the parts bin  ;) those spade conversions sound like a good idea.
  Happier note a friend and shop mate stopped down with his new toy, a 1965 Chevelle and we went out and lit up his new rear tires a bit. :)
  Good ole Sean Barney also hit the shop on his now nice running F3 and we shot the bull and had a couple cocktails till kind of late in the evening. Good to see you again Sean.
« Last Edit: May 07, 2014, 08:04:40 AM by ekpent »
Offline MoMo
  • Ride like you're invisible
« Reply #17502 on: May 07, 2014, 08:30:26 AM »
Out of 40 bazillion bikes you have an everyday rider Eric? ::)...Larry
Offline Bankerdanny
  • Endeavor to persevere
« Reply #17503 on: May 07, 2014, 09:55:11 AM »
Bought a replacement fuel petcock bung. Some MFPO cut off the perfectly good one on the otherwise very nice tank that came with my '77 basket case. I was going to track down a replacement tank, but I should be able to have this welded on for a nominal amount, certainly less than the cost a replacement tank. I will still need a petcock, but it's a standard 3/8" internal thread and petcocks for that size run about $15 on eBay.
Inch by inch I make progress.
http://www.ebay.com/itm/191149859144
Offline maduncle
  • Don't confuse me with a
« Reply #17504 on: May 07, 2014, 09:05:43 PM »
Dropped the bomber off at Ace motorcycles in West Heidelberg and tried to nick Terry's newly laced wheels whilst Jeff's back was turned.
Hopefully Jeff at Ace can iron out the rough spots in the engine performance, the bike started a bit rough this morning as per usual, doesn't like high revs but still pulled pretty well and rode okay for the ten minute across town trip.
CB750K2 (only slightly modified)
« Reply #17505 on: May 08, 2014, 01:23:59 AM »
G'Day Cliff, I'm glad you like the wheels, I better go get them before they disappear! Hey have you had any problems with those Mikuni's icing up? I've got a set that Murray sent me for a CB750, but it ran like crap with them, so I took them off and put the OEM ones back on and it ran heaps better. I've told Jeff if he needs any gaskets for your 450 I've got some here, if you don't have any? Cheers, Terry. ;D
Offline maduncle
« Reply #17506 on: May 08, 2014, 04:07:41 AM »
Yep - you better grab those wheels Terry, they sure look nice.
I gave jeff a spare set of cams, a new set of cam followers, an oil seal set and a complete gasket set - I have quite a few spares now, and I am going to buy those two bikes in parts on eBay at the moment.
I have not had any specific issues with the Mikuni VM32's on the CB450, unless they are the reason for the poor performance at the moment! Jeff will tell me.
I have a set of CR's for the Hansen CR450 road racer I am building, so I will be able to compare the carbs.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #17507 on: May 08, 2014, 06:00:31 AM »
Ran the ol gal hard all the way into work, 32 miles. Running about 5K on the tach, purring like a sleeping cat.  ;)
My speedometer is acting kind of freaky for some reason.
Between 70 to 80 the needle will jump a bit ~ 5 mph up or down. Is the ol speedo on it's way out? I did lubed the cable last season.
What gives guys?  :-[
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Bankerdanny
« Reply #17508 on: May 08, 2014, 07:20:21 AM »
Last season was last season. Pull the cable, clean it well and give it a fresh coat of grease.
« Reply #17509 on: May 08, 2014, 07:26:23 AM »
5mph is not bad, but if it really bugs you, this thread has all the info you need to know   http://forums.sohc4.net/index.php?topic=78890.0
« Reply #17510 on: May 08, 2014, 11:43:01 AM »
Continued with my old oil cooler project from the middle of the 80's. Glued hole in adapter and removed paint from cooler.
Hopefully mount it this weekend.
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #17511 on: May 08, 2014, 02:17:17 PM »
It was a perfect day.  I put the battery back in my CB500, opened the petcock, choke on, run switch to off, full throttle, let it crank for 5 seconds, run switch to on, pressed the start button again and  she came back to life.  Such a wonderful machine!!  A little air in the tires and off we went.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline Jerilee
« Reply #17512 on: May 08, 2014, 02:55:55 PM »
I started a 'list to sell' box of parts from the bike and moved the frames out of the back so I could get to them, then I put the summer tires on the VW and painted some parts I saw rusting, took a long break to houseclean and then filled the shed back up with the crap I'd moved to get at the tires/bike frames.
Before I called it a night for supper I removed the rear axel from the wheel hub and plopped the rear break assembly in the 'sell it' box.
Oh, and I purchased a used seat and tail off eBay, should be here next week.
Not much, but better than nothing :P
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17513 on: May 08, 2014, 05:38:08 PM »
Switched to 20W50 Castrol motorcycle oil from 10W40.
Adjusted clutch.
These two things seem to have solved my issue with a nasty Grind/clunk into 2nd gear. (See here: http://forums.sohc4.net/index.php?topic=137208)
Added two washers to the airbox bolts. I had a wacky gap all around the box allowing too much air in because they were bottoming out. This fix enrichened my mixture enough that I had to turn my air screws 1/4 turn out to get rid of the boggyness and threatening to die when blipping the throttle. (See here: http://forums.sohc4.net/index.php?topic=137209 Thanks iron_worker!)
« Last Edit: May 09, 2014, 02:42:27 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
« Reply #17514 on: May 08, 2014, 08:41:24 PM »
Almost seems like an air gap leak would lean out the mixture ??
Offline evanphi
  • Apparently I'm an
« Reply #17515 on: May 09, 2014, 02:41:42 AM »
Yes it was quite lean before so I had to really close off my pilot screws. Now with the air box properly sealed, there is less air going through and my mixture was too rich, so I backed the screws out a 1/4 turn to add more air or the mix.
Edit: I added a word to clarify my original post.
« Last Edit: May 09, 2014, 02:43:16 AM by evanphi »
--Evan
elizabethgypsy
« Reply #17516 on: May 09, 2014, 08:45:49 AM »
Did my first oil change today on my little '73 CB350F! Only issue was, once I got the oil filter housing off, the center bolt was stuck, couldn't get the filter out. It wasn't desperately in need of a change, so I figure it's ok to do next time. Any suggestions on how to get it unstuck once it's off? Didn't want to damage the threads on the inside of the hollow bolt by clamping it and wrenching away..
« Reply #17517 on: May 09, 2014, 09:19:25 AM »
Lay it across a couple two by fours with the bolt head in the gap and gently tap it out with a rubber mallet. There is a rubber o-ring that must be hanging it up. The filter though should slide right off that bolt pretty easily. Best to get that apart to make sure the spring and washer etc is orientated correctly if they are like the 750's. Never know with a PO.
elizabethgypsy
« Reply #17518 on: May 09, 2014, 04:56:13 PM »
[/quote]
Fantastic idea, I will try that - thank you! I believe the spring set up is similar to the 750's (there's a lot more reading online regarding the 750's than the 350f..) - once the housing was off there was a hollow long washer type piece of metal that was around the hollow part of the bolt, seemed to keep the filter pushed down against the spring, which was under the filter from what I could feel. Will post again if I have issues.
Love having the knowledge available in these groups!
« Reply #17519 on: May 09, 2014, 04:57:40 PM »
I've never tried Eric's method and I'm sure it works fine, but what I usually do is warm the engine up to operating temp, then use a 12mm socket on a "T Bar" (you may need a couple of pieces of pipe to extend the handles and add to the leverage) and turn that sucker out.
If you can't, and end up butchering the head of the bolt don't despair, cut the head off with an angle grinder and slide the filter canister assembly off, and the bolt will just turn out as there's now no pressure on it.
Buy a new centre bolt (eBay, JC Whitney, David Silver Spares, Yamiya etc) with a 17mm head for around $12.00, and it won't be a problem removing it next time. Cheers, Terry. ;D
elizabethgypsy
« Reply #17520 on: May 09, 2014, 05:08:14 PM »
Good to know the bolts are easily replaceable, it put up a bit of a fight coming off but good ol ratchet with enough leverage ended up working after letting it warm up. Learning how to wrench with a bike this old.. it's delightful being able to find almost everything I've needed so far.
« Reply #17521 on: May 09, 2014, 05:51:45 PM »
So just to make sure you had the housing already unbolted from the engine case and on the bench but just could not get the bolt out of the housing ? Don't want to give you bad advise.  Usually the big problem on newly acquired machines is getting the bolt loose when first trying to just remove the housing. With new gaskets etc they do not need to be strong armed super hard.
Offline mrbreeze
  • Not your average
« Reply #17522 on: May 09, 2014, 07:23:06 PM »
The important thing here is that the new bolt has a 17mm head which will give you better leverage to remove. Always use a 6pt. socket or wrench.
MEMBER # 257
elizabethgypsy
« Reply #17523 on: May 09, 2014, 11:04:41 PM »
Correct, housing off after a good little workout, but the bolt didn't want out of the housing after coming off the engine case. Contemplated trying to pry the filter out with a long flat head, but thought it might be unwise in the event I just broke it, while stuck.
Offline krusty
« Reply #17524 on: May 10, 2014, 12:20:01 AM »
This reminds me that its about time I did a change on my 350F. The bolt only screws into the case not the housing. It should just tap out, it could be just sticking on the O ring. Or is my memory getting a bit dim here?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
