Author Topic: What did you do to your bike today ?  (Read 3157735 times)
0 Members and 19 Guests are viewing this topic.
Offline ozpacman
« Reply #17950 on: June 29, 2014, 11:09:45 pm »
Not today but over the course of the weekend I did a bit of work on the 'new' K7:
Strip, clean and reassemble front brake caliper. Replace brake fluid and bleed.
Remove front brake lever, clean lever & housing, grease & reassemble.
Remove rear wheel, strip & clean brake shoes, grease brake cam & pivots etc and reassemble.
Check front and rear wheel bearings
Repair & refit 'Honda' emblem on chrome panel below headlight.
Repair crack in side cover.
More precautionary maintenance  to come prior to registration.
Russ.
« Reply #17951 on: June 30, 2014, 01:13:52 am »
I keep a set of those snap in blade fuse holders. Like a self splice. Put wires in, close top and insert fuse....ride home. (Carry a cell phone)
Last time my bike broke down it was because the throttle cable snapped. Pushed to my father in laws house and he said " why didn't you just use the clutch and ride it here" as I huffed and I puffed. Oh yeah........
Couldn't you have just wound the idle up to say 3K RPM and used the clutch like your father-in-law suggested Joe? I've broken a couple of clutch cables and ridden home, but that is a real PITA........ ;D
Offline WhyNot2
  • I'm finally an
« Reply #17952 on: June 30, 2014, 06:48:29 am »
Finally got the oil lines changed and all buttoned back up.
That hose in the back of the tank was a booger to get back on.
Can't believe I lost the bolt to my brake pedal, has to be somewhere's in the garage, I must have kick it under the bench.
No biggie, I have lots of hardware.
Offline mcswny
« Reply #17953 on: June 30, 2014, 01:25:49 pm »
Could you have used the return throttle cable as well and just be careful to close the throttle manually (just trying to keep my options open if this ever happens to me)?
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline bjbuchanan
« Reply #17954 on: June 30, 2014, 02:01:41 pm »
You can try fiddling with the cables but the easiest is to crank open the idle knob till about 3500 and live with it
Offline Tintop
« Reply #17955 on: June 30, 2014, 05:51:29 pm »
Nothing with the 550, but did get to be the monkey testing a new P2 sidecar with the builder.  Pictures later in my sidecar thread.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline vince.whirlwind
« Reply #17956 on: June 30, 2014, 06:46:10 pm »
Replaced the seal at the shift lever shaft.
Found out why the headlamp won't come on.
Realized my front fender isn't stock.
Oiled the chain.
« Reply #17957 on: June 30, 2014, 10:12:24 pm »
Well done Vince, and welcome to the site. Cheers, Terry. ;D
AJK
« Reply #17958 on: July 01, 2014, 06:09:51 am »
Continuing with my swingarm...  As a carry over from here
http://forums.sohc4.net/index.php?topic=61168.msg1556816#msg1556816
I ended up installing some new swing arm bushes (part # 52174-362-000). I wanted the bronze ones but shipping costs were excessive, so i found a stock set for quite a bit cheaper. Everything is now feeling snug.
I should have it primered and painted in the next week or so.
fast forward to here http://forums.sohc4.net/index.php?topic=61168.msg1571816#msg1571816
« Last Edit: July 05, 2014, 08:01:35 pm by AJK »
Offline Schnell
« Reply #17959 on: July 01, 2014, 06:26:41 am »
The throttle cable on my old VW beetle broke once, and this is how I made it home.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #17960 on: July 01, 2014, 08:01:34 am »
Ha, throttle cable.  I rode 150 km the marionette way, yanking on the throttle line when my cable broke.  It takes a while to adapt, but it will get you home if needed.  But it was a single carb CZ 250, not a 4 inline.
Offline Tintop
« Reply #17961 on: July 01, 2014, 10:52:42 am »
When mine broke at the carb on my Beetle I used a shoelace to join them.  Was late for school and sent to the office.  When I explained & showed them the shoe without lace I was let off. ;D
77 CB550 Cafe build
Offline mcswny
« Reply #17962 on: July 01, 2014, 03:47:08 pm »
^Amazing
1972 CB750 K2
1975 XL250
198 XR80
« Reply #17963 on: July 01, 2014, 04:40:42 pm »
I had an old Suzuki 125 when I was a kid and remember breaking a throttle cable . He lived out in the boonies on a large farm and I was only going to be there for a few days with the bike. I hooked/rigged up the cable up to the front brake lever and rode it that way till it and I got back home. Got a surprise though the first time I hit a corn stalk with that lever without a solid finger behind it  ;)  ;D
« Last Edit: July 02, 2014, 06:43:51 am by ekpent »
Offline Tews19
  • I am no
« Reply #17964 on: July 01, 2014, 08:10:03 pm »
Took the K1 out for a ride before sunset. Took this quick pic with the new seat.
1970 Honda CB750 survivor.
« Reply #17965 on: July 02, 2014, 01:40:38 am »
That looks great mate, that's the one from Britain, yeah? Cheers, Terry. ;D
Offline Tews19
  • I am no
« Reply #17966 on: July 02, 2014, 03:42:15 am »
Yes it is Terry. The seat is kind of stiff but should soften over time.
AJK
« Reply #17967 on: July 02, 2014, 05:26:36 am »
A continuation from ...
http://forums.sohc4.net/index.php?topic=61168.msg1571398#msg1571398
I ended up doing another pass of phosphoric acid, then soapy rinse, followed with a soak in the sun for a couple of hours, then a pass of wax and grease remover before applying 3 coats of primer. I'll let the solvents ooze out over the next few days in the sun, then block it down a little before giving it some coats of gloss black.
Fast forward to here ...
http://forums.sohc4.net/index.php?topic=61168.msg1573104#msg1573104
« Last Edit: July 05, 2014, 01:28:07 am by AJK »
Offline Tempast
« Reply #17968 on: July 02, 2014, 09:37:30 pm »
Found a set of superbike height bars that were pitted and rusty. Wire wheeled them until they looked like stainless steel and they'll probably be a lot more comfortable than the stock bars I have. Too high for me.
Also got my DCC 12" shorty muffler. No more POS from a diesel light tower... Yeah lets not talk about that...
« Reply #17969 on: July 03, 2014, 08:19:00 am »
My engine got additional zinc.
I read this thread where half recommended doze was used.
http://forums.sohc4.net/index.php?topic=138592.msg1565987#msg1565987
I bought different brand of additive in a local US car-part-restorer-builder.
Edelbrock Zinc Additive for 6 quarts/liter oil. Content 12oz (35,5cl) I'll use it for 3 treatments. (3x3,5L oil)
I used 12cl (2x6cl)
Removed 2dl oil, added 6cl Edelbrock Zinc Additive. Started engine, added additional 6cl after a few minutes idling, revving +2000rpm. Let it run a few minutes more. (Used oil: Castrol Act-Evo 4T 20W-50)
I hope my clutch will work smoother and no more stucked plates which is new for me, never back in the days. OK cam with rockers will be something to check at next time opening the head cover.
Find NOS Castrol GTX 20W-50 from early 80's might be a good idea. A barrel of ~200L somewhere...?
« Last Edit: July 03, 2014, 08:20:36 am by PeWe »
Offline Jerilee
« Reply #17970 on: July 03, 2014, 08:49:25 am »
I got the VIN plate off in reasonable shape before the heat got to me. Maybe I should have let the sun kill the grass instead of mowing first?  8)
Anyway with that off I can strip the frame bare and clean it up for PC, etc.
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
« Reply #17971 on: July 03, 2014, 08:56:19 am »
I went for a 100 mile toot Sunday and noticed quite a bit of oil on the right side of my 750 when I got home. after cleaning it up it appeared to be one of the oil hose crimped ends. Removed the 41 year old hose and replaced with another 42 year old and all is good.  ;D
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17972 on: July 04, 2014, 02:57:38 am »
Swapped out  the PO-installed 110 mains for KeiHin 120s, which is what my 7As should have had all along. On my way to get the jets, I did a plug chop, plugs at WOT were whiter than me, ahaha.
Also checked needles, they are in stock middle position.
Fired the bike up once to make sure everything was in order, and seemed to start easier at least. Hurricane coming tomorrow so no riding for a day or two.
--Evan
1975 CB750K "Rhonda"
Offline Eydugstr
« Reply #17973 on: July 04, 2014, 03:55:27 pm »
Still not 100% there, but making progress.
« Reply #17974 on: July 04, 2014, 08:26:06 pm »
I used 12cl (2x6cl)
I'd never use the old GTX in a CB750 mate, the "Friction Modifiers" would make your clutch slip horribly. I've never wasted money on motorcycle oil either, back in the day I used "Mobil Super Drop" car oil in my CB750's, my first GL1000 and my Kawasaki Z900, and it was excellent. Nowadays I use the cheapest car oil I can find, it's still way better than the best oil available back then. Cheers, Terry. ;D
