Author Topic: What did you do to your bike today ?  (Read 3192865 times)
Offline ev0lve
« Reply #18525 on: September 16, 2014, 07:08:13 am »
Today I procured a place to work on the bike I bought 2 months ago for cheap(ish) given that these are made of all gold now - this is what was in my head as I got the keys...
http://www.youtube.com/watch?v=zBDGSajMvLs
Cripes - that's stealing my thunder a bit. How do you embed Youtube nowadays?
Might as well drop some pics of the machine
75K, GL1000 front end, frame's been cut, mechanically a bit of a wreck. All in all I'd rather have the stolen one back BUT... beggars, choosers, so on.
Just post the full link for the YouTube video.
For wrath! For ruin!
Sorcery!
Offline ev0lve
« Reply #18526 on: September 16, 2014, 07:23:00 am »
What is wrong with it?  Looks bit rough, but worked on.
It likes to leak oil out of the alternator once it's warm and on the kickstand - there's a very fine JBWeld repair where some PO tossed a chain - carbs send gas the wrong way - PO claims it "might" have an 836 kit in it - generally I just don't trust it - stuff like that :)
« Reply #18527 on: September 16, 2014, 07:53:33 am »
That stolen bike never did turn up, did it?  bummer.
your dual disc documentary on that one helped a lot of people here, including me.  good luck with this one.
Offline ev0lve
« Reply #18528 on: September 16, 2014, 08:05:39 am »
Nope. Never did. Not a trace. Still chapped about it too, surprisingly.
Glad someone else was able to use that info though!
Offline drewfunk
« Reply #18529 on: September 16, 2014, 10:26:51 am »
Installing a Carpy 4 into 1, this thing is a #$%* to wrestle on, but it does look awesome. Unfortunately i forgot about new exhaust gaskets and it leaked horrible, had to throw the old Kerker back on until i get the gaskets.
« Reply #18530 on: September 16, 2014, 10:40:33 am »
looks good DF....just be sure to do an oil & filter change before you get the carpy buttoned back on  ;) :P
Offline drewfunk
« Reply #18531 on: September 16, 2014, 11:09:15 am »
Already done  ;D
Offline fire113
« Reply #18532 on: September 16, 2014, 01:06:31 pm »
...K0 fork arrived, don't know what the PO did but he did it the wrong way  :-X
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=2a675nioclinie41otamdige13&/topic,60973.0.html
« Reply #18533 on: September 17, 2014, 07:43:14 am »
that seal are "hammered" good dovn.....hope it not have scared the hard crome...fools work...
i hate all this v-w.... vords
« Reply #18534 on: September 17, 2014, 07:45:16 am »
Looks like little handy top the oil plug on top. ;D
Offline strynboen
« Reply #18535 on: September 17, 2014, 08:22:19 am »
not even sentered in mittel..think there has be air lines fitted...
Offline bjbuchanan
« Reply #18536 on: September 17, 2014, 08:47:12 am »
My guess is a diy air line setup that the PO abandoned. Probably couldn't get it to work well if at all
Offline fire113
« Reply #18537 on: September 17, 2014, 02:26:57 pm »
...it is for a quick fork oil change but that's not the problem. The PO killed the fork seal's !
Offline edwardmorris
  • Youngish
« Reply #18538 on: September 17, 2014, 06:52:11 pm »
Cleaned up some rubbers
« Reply #18539 on: September 18, 2014, 04:24:36 am »
Glad you posted a pic, would hate to think you are re-using those things   ;D ;D
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #18540 on: September 18, 2014, 04:52:39 am »
I think my head gasket is shot... I've been getting more oil on the jug's top fins enough to cause a little puddle when on the side stand.
Looks like an engine removal is my future this winter...
Or, better yet...
Is 754's weldless frame kit a good product? Can I cut the frame with the engine still in?
« Last Edit: September 18, 2014, 04:59:28 am by evanphi »
--Evan
1975 CB750K "Rhonda"
  • Youngish
« Reply #18541 on: September 18, 2014, 08:51:40 am »
If you're referring to my post, then yes, I'd have hated reusing these too. This is what they looked like
Offline bjbuchanan
« Reply #18542 on: September 18, 2014, 09:05:58 am »
Or, better yet...
It could also be your pucks. They leak like nothing else, a real pain. It does look like the head gasket area, it could be both.
Either way once you get down there any of those leaks will be getting fixed up anyway
« Reply #18543 on: September 18, 2014, 09:37:47 am »
I was thinking of a different kind of rubber, maybe made by a company called Trojan.
Offline bjbuchanan
« Reply #18544 on: September 18, 2014, 10:03:20 am »
Who uses those, pshhh
Offline evanphi
  • Apparently I'm an
« Reply #18545 on: September 18, 2014, 11:11:05 am »
Or, better yet...
I already know the pucks are a problem. They are leaking out the 2/3 spark plug area. They've been like that since I got the bike, but just a gentle film on the upper fins.
This is a new leak that started last week, and is much more of a dripping leak. It has soaked my kick starter rubber and pools in the area around the oil pressure switch.
I've also noticed that idle is funny since the leak started. Bounces between 700-1000RPM, dial up to 1100 (prev good setting), rev to be sure... back down to 700-1000 again. Hmph. Good thing winter is coming so I can get to this project.
« Last Edit: September 18, 2014, 11:41:29 am by evanphi »
--Evan
Markcb750
« Reply #18546 on: September 18, 2014, 12:40:19 pm »
Are you sure something simple like the tach connection is not leaking?  Oil from it can drip down make it look like a head gasket.
I have a tip in the tricks & tips section that tells you how I keep my K6 from constantly developing tach seal leaks.
Offline evanphi
  • Apparently I'm an
« Reply #18547 on: September 18, 2014, 04:29:34 pm »
Not the tach drive. That is plugged. Not using original tach.
--Evan
Nic
« Reply #18548 on: September 18, 2014, 05:24:15 pm »
Kit is good and yes you can cut with the engine in. I have one and it's a goodun, makes taking the top end off a breeze. If you go that route you can do the head gasket and all else with the engine still in the frame, I reckon scrapping the gasket off the barrels will be a PITA though, it's a PITA enough with the barrels on the bench.
Offline fire113
« Reply #18549 on: September 19, 2014, 05:40:44 am »
...start sanding down the K0 fork legs and prepare for polishing.
