Author Topic: What did you do to your bike today ?  (Read 3194056 times)
0 Members and 8 Guests are viewing this topic.
KiefRichards
« Reply #18900 on: December 01, 2014, 10:24:12 pm »
Driled my spare rotor
« Reply #18901 on: December 04, 2014, 04:43:57 pm »
Replaced the tail light on the H1.  The brake lights never worked since I got it and the wiring was in poor cond, bought a tail light from a guy on the Kaw triples forum.  Roads are wet from rain so no test ride today, but will tomorrow...
Offline MoMo
  • Ride like you're invisible
« Reply #18902 on: December 04, 2014, 07:26:11 pm »
Alabama antique Stev-o?...Larry
« Reply #18903 on: December 04, 2014, 07:33:21 pm »
Just bolted that on for the test rides that I've taken it on. Havent registered it yet...but will get a TX antique plate on there soon.
KiefRichards
« Reply #18904 on: December 05, 2014, 10:35:40 am »
Not sure about Texas, but that's a felony in California...
Friend of mine was convicted of that, (it's considered fraud, here) 10 years ago, in his early 20s. He still can't get decent employment...
« Reply #18905 on: December 05, 2014, 12:30:49 pm »
Felony seems pretty harsh, guess I better check Michigan's laws   8)  Would hate to have to get rid of my guns.
« Last Edit: December 05, 2014, 12:32:53 pm by ekpent »
Offline 750cafe
« Reply #18906 on: December 05, 2014, 12:35:55 pm »
Isn't just about anything a felony in the dysfunctional country of Californistan?
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline calj737
  • I refuse...
« Reply #18907 on: December 05, 2014, 12:45:16 pm »
Only if you're an Ameican citizen
Offline MoMo
« Reply #18908 on: December 05, 2014, 01:42:50 pm »
I think California should be jackhammered off around the perimeter of the state  and set adrift,  could be its own country then
Offline Bankerdanny
  • Endeavor to persevere
« Reply #18909 on: December 05, 2014, 01:49:02 pm »
I drove the bike yesterday. I've never driven it that late in season before, 29:th of October. +10 to +5 degrees C.
Today raised the needles in my carbs 2 steps richer, clip in lowest groove when carbs still run lean at 4000-5000 rpm.
Needles are tricky. Engine run fine for 30 minutes, then starting to run lean when warm. I finally found out that the needles is the only thing able to cause that, thicker when warm. Lets see if highest position is enough or if i need to buy new carb stuff again. Needles this time with thinner tapering around 1/4 throttle lift or 20-25mm down the needle.
A month later you may have already solved this, but are your choke butterflies fully opening? It also seems to me like you need a slightly richer juet rather than a needle. I get why you are thinking taper, but at lower speeds its the idle air screw and the slow jets that control most of the mixture. At greater throttle openings it switches to the main jet. If you are getting lean in the 4-5k RPM's then I think the issue is too lean of a main jet.
Offline InAquaVeritas
« Reply #18910 on: December 05, 2014, 02:20:08 pm »
Started working through my engine internals, looking for stuff to be replaced and trying to figure out a problem with my neutral and 3rd gear...
Also running into some small issues I can't seem to figure out. I have one weird, double, riveted clutch plate and one with slanted grooves. Trying to determine wether or not parts have worn down or if it is normal wear and tear.
My micrometer and slider gauge are my best friends right now!
I'm making an army bag into a waterproof seat cover and had to drill out a whole bunch of rivets for that.
« Last Edit: December 05, 2014, 02:23:22 pm by InAquaVeritas »
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
« Reply #18911 on: December 05, 2014, 02:34:29 pm »
"Learn to swim. See you down in Arizona Bay"
- Maynard James Keenan
« Reply #18912 on: December 05, 2014, 04:27:44 pm »
Guess I aint movin to Cali, I dont want to be no Felon.
« Reply #18913 on: December 05, 2014, 05:54:41 pm »
Eric, in Michigan you are better off getting caught with no plate, than one that doesn't belong to the bike.
« Reply #18914 on: December 05, 2014, 07:39:33 pm »
Dave down at Life Cycle says I should just try and get a dealer plate, that sounds scary though dealing with more government.
« Reply #18915 on: December 05, 2014, 07:51:32 pm »
to get a dealer plate, you need a dealer's license...I don't think it's that big a deal ha ha...seriously though, it's probably just a bunch more forms and fees, nothing to be scared of, just annoying.  Yeah, I too find my self on too many un-plated, un-insured extended test rides.
Offline tfrasca
    • CB550 Project
« Reply #18916 on: December 05, 2014, 08:13:25 pm »
Are you guys saying that riding without a plate is a felony in CA? A friend of mine with a very nice CX500 has never had a plate on his and has never even been hassled. I'll have to look into this and let him know...
Offline socal1200r
« Reply #18917 on: December 05, 2014, 08:30:36 pm »
Perfect, we wouldn't have to share our great weather and terrific roads with any mainlanders, or haoles, lol...
« Reply #18918 on: December 05, 2014, 11:35:31 pm »
yep, good riddance to cocky west coast douches...
Offline DWS
  • Treat others as you would like to be treated .
« Reply #18919 on: December 06, 2014, 12:14:17 am »
Hi all, just got my cb750 temporary operating permit today have to wait for the real plate (Vintage Plate). They gave me this paper and said to put it on the back of the bike as best i can, well this paper is like 18 in by 18 in, I guess ill just get me a card board box and duck tape it on, yeah right.
DMV said i could get a vintage plate since the bike is 36 years old but the cost was $99.86 and once the bike is 40 years old, it will only be $10.00 Really!! what kind of crap is that? three years to go.
I guess it would have been a bit cheaper if i did not have to get the title change from Wyo to UT and the vintage plate but my hell.
The good side is the state safety inspection was only 7 bucks.
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
« Reply #18920 on: December 06, 2014, 05:05:07 am »
Funny!
Offline DaveBarbier
« Reply #18921 on: December 06, 2014, 05:22:24 am »
Wear it as a cape! Trying to think of your superhero name...
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #18922 on: December 06, 2014, 06:55:05 am »
More of an Anti-hero, no?
Offline DaveBarbier
« Reply #18923 on: December 06, 2014, 09:23:32 am »
True, Temporary Operating Permit Man doesn't seem to work well. But maybe better than Jumps Through Hoops Of DMV Rules and Regulations Man.
1978 Honda CB550K
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=nuvs9rin3f0ngve04t3al660f0&/topic,60973.0.html
« Reply #18924 on: December 06, 2014, 09:50:37 am »
have faund a old glasfiber fairling to fit on the cbx..
it have not total horensontal line on the pexiglass buttom...but can it be mounted better ..??.seen a lot mounted like this in film(stone) mad max..so think they just must be fitted like that...
its glasfiber /poliester..so i can cut ..and lowerd it some cm at back..to get it more lined up..but that lover the vinssheild..and it are nice heigh now..
try to improve..or just mount it as it fit now..it fits mainlight /forks perfekt....
« Last Edit: December 06, 2014, 09:54:30 am by strynboen »
i hate all this v-w.... vords
