Author Topic: What did you do to your bike today ?  (Read 3279733 times)
« Reply #19100 on: January 16, 2015, 08:14:13 PM »
Cranked over the K4 after it sitting for about a month cuz of crap weather. After 3, 10 second attempts, my new Scorpoin battery slowly died til it would no longer crank. A few kicks and the 836 roared to life and I was off on a sunset cruise on this beautiful day.
I don't believe the battery was fully charged when I bought it and obviously I should have charged it.
It s now charging.....
Offline grcamna2
« Reply #19101 on: January 16, 2015, 09:08:02 PM »
My everyday rider 750 went in for surgery yesterday to replace the extremely notchy steering bearings with rollers. Needed new fork boots as one was ripped and guess I'll do some fork seals also while its apart.
Going to be doing the same thing in a month or so...but in a non-heated shed. And I'm in the north east. Could be worse I guess; I could not have a bike to work on at all!
1978 Honda CB550K
Dave,I can take about 2+ hrs. working like that myself.. Brrrr .I've got lot's of parts & a couple engines upstairs in my Apt.(4th flr.) & it sure beats working out at storage,just hope the Apt. manager doesn't pop in unexpectantly  :o
Offline DaveBarbier
« Reply #19102 on: January 16, 2015, 10:27:35 PM »
1978 Honda CB550K
Ha, just say it's abstract art or something. Or just come clean and hope he's a member here, haha.
1978 Honda CB550K
Offline maduncle
  • Don't confuse me with a
« Reply #19103 on: January 17, 2015, 01:52:23 AM »
I rode my 500/4 up and down the street for the first time.
All good, except for a sticky throttle that does not always return.
Question - should I just go get new cables (these are the originals) or is there something I should lubricate?
CB750K2 (only slightly modified)
« Reply #19104 on: January 17, 2015, 06:18:35 AM »
Now that it is complete, I find myself liking that way more than I expected to, based on what parts you are using.  This has been a fun thread because you got it done fast and ended up with functional motorcycle, without much "build thread rambling".  Nice job.
Markcb750
« Reply #19105 on: January 17, 2015, 12:43:02 PM »
Today the K6 got a new transmission cover gasket & a new gear shift seal.  bought both a Honda part & a standard 14  28 x 7  seal, The standard seal looked more robust across the primary & dust lips, so I put it in.
I had installed cartridge emulators last spring, was not happy with the performance over bumps, so I changed the fork oil to 10w from 15W.  Took a nice 40 mile ride on known roads, Much better.
Looks like the Honda Brake Piston seal is performing better than the eBay deluxe.
Next winter job; Oil pup rebuild with the parts I bought from Elan.
Offline edwardmorris
  • Youngish
« Reply #19106 on: January 17, 2015, 04:30:41 PM »
Started assembling controls, finished the left one, stumped on the right because of this
« Reply #19107 on: January 17, 2015, 05:37:14 PM »
Edward,  might be from a different bike as oriented 90 degree out...
case of stump the chump. Plus, no contact pad...
  • Youngish
« Reply #19108 on: January 17, 2015, 05:56:01 PM »
Yep, right one was what came with the controls, damaged during shipping, left one I refurbed, but its from later year bikes, need a good one for k2
Offline Jo3f1sh
  • Still don't have a jacket, even though I'm a
« Reply #19109 on: January 18, 2015, 09:46:41 AM »
Ran outta gas...
1974 Honda CB350 Four
Build thread: http://forums.sohc4.net/index.php?topic=138848.0
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=v4do68pft98ao3bc57545c1sg4&/topic,60973.0.html
« Reply #19110 on: January 18, 2015, 10:08:44 AM »
i finaly faund a nice 400 four in denmark..
.its not orginal in all parts..but exept for the thanged parts the bike are orginal..the exhosts are marchall deeptone
it have nice bags,,and the old nice koni choks..rear fender are rusty,and battery gone..as the vorst defeks75,000 km
 10,000  danish kroner,,old bikes are kosty and few in denmark..ve have salty seavater and rainy veather..so most  1970 bikes are ruined ,,or to heigh preised
i hate all this v-w.... vords
« Reply #19111 on: January 18, 2015, 11:01:15 AM »
Seems like a fair price ($1555 US).  You going to buy?
« Reply #19112 on: January 18, 2015, 12:29:53 PM »
Check the frame carefully to ensure that it is solid. Then there is the issue of bent frames or forks on old bikes. Looks like a nice bike and a decent price given the rare nature IF it is what you want. The Konis are rebuildable and it has a nice fairing too. I like the Marshall Deep Tone exhaust.
« Reply #19113 on: January 18, 2015, 12:52:18 PM »
Edward,  could you  take a chunk of brass and file it to shape needed for the contact pad? I think I would take a short brass rod sized to fit the recess of the plastic top  then drill a hole through the rectangle or strip stock for the rod to form the pad.Silver solder the strip to the rod. Cut the rod flush with the strip leaving room to finish with fine files and very fine sandpaper. Trim the rectangle strip to size and finish as mentioned.  Then, since gold contacts aren't easily feasible for mist hobbiest I would flux and apply a layer of silver solder. Or, see if a jewelry store does electroplating of the contact with gold. If they resize a ring for $20 they should not want more than that to apply a layer of gold on it...right?
Once your pad is built, then rough up the back side and the socket and glue it in place with a drop of 2 hour or 30 minute cure epoxy . The short cure epoxy is not as strong.
  • Youngish
« Reply #19114 on: January 18, 2015, 01:29:51 PM »
Thanks RAF, I do have the contact pad and rest of it, details in my K2 build thread in my sig. For now, I'm just going to find a replacement knob and refurb it like I did this one. Its just a mistake on my part for not checking it before working on it  :-[
Offline strynboen
« Reply #19115 on: January 19, 2015, 05:34:30 AM »
i have closet the deal...got it for 9000 kr and he bring it to me. pay at del...
.(in 2 month,have to vait to he opens his summer residens,,and then he bring it here..
have thekked for korosion and bend parts(cracks in paint)specily at stering head..and all are ok..i get it regirestered vith plate..nice to safe the money for plate..i hate new plates..they dont have patina
he vas sekkend ovner,,have got it for over 30 years...alvays stand inside..but not oiled the crome parts,,,so minor rust marks..but can be polished fine..
only rear fender are total lost..
its a time kapsel from 1980..all parts are from this era..and typican euro bike marchall,, koni,, italy seat..and loverings parts on stering head..and the side bags..
im in big heddic..bring it fabric. 1976.or 1980 typical as it is.....think i just make it running..and take one seson before deside the vay ..but not cafee/bratt for shure
« Last Edit: January 19, 2015, 05:46:17 AM by strynboen »
« Reply #19116 on: January 19, 2015, 06:23:10 AM »
Kewl. Is that a Marshall exhaust?
Offline strynboen
« Reply #19117 on: January 19, 2015, 09:11:03 AM »
i have marchall on both  my small  bike"s ,,the new 400 and 550...they have a nice saund..can use senterstand..and get to the oil filter..and lean dovn are fine..no scratcing in corners...its typical vith that sqvare konnektor..it takes some free space under the bike..but it are not a problem
« Last Edit: January 19, 2015, 11:58:48 AM by strynboen »
Re: What did you do to your bike today ? - LED bulbs in Headlight and new shocks
« Reply #19118 on: January 19, 2015, 11:52:31 AM »
I got my T10 Led bulbs for parking light. That match a bike from the 70's when LED Zeppelin and LED filled snow shoes with yellow snow according to Frank was very common... :o
Photos:
 with Parking light only
 Lo beam LED H4
 Hi beam LED H4 and T10 Led parking light.
I look forward to road test in the evening to check how the headlight will work. I'm sure that 9W LED parking light will be good enough during daytime.
I have not meaured the amps when light is on. I need to verify the chines bulb sellers selling low price bulbs and free international shipping. Really low price. I'm sure that I can give bad car drivers a flash in the eyes next season!!
Shocks taking bike back in time.
Offline drkush
« Reply #19119 on: January 19, 2015, 12:00:03 PM »
18 month ago
Sent from my iPad using Tapatalk
Offline drkush
« Reply #19120 on: January 19, 2015, 12:02:29 PM »
so far, doing wiring now
Offline rickman750
« Reply #19121 on: January 19, 2015, 11:03:56 PM »
Four and a half grands worth of parts and machining are starting to come together.
« Reply #19122 on: January 19, 2015, 11:29:12 PM »
Very nice, it adds up quick doesn't it... ;)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19123 on: January 20, 2015, 06:31:46 PM »
Got halfway through my drag bar install prior to the starter button housing exploding. RadioShack... here I come!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline maduncle
« Reply #19124 on: January 20, 2015, 06:33:00 PM »
I like that bikini fairing - what or where is it from?
