Author Topic: What did you do to your bike today ?  (Read 3218499 times)
Offline mcswny
« Reply #19875 on: May 31, 2015, 05:09:49 AM »
Started the fun process of switching out all the old bullets on my wiring harness to new vintage connections. man does it feel good!!!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Online PeWe
« Reply #19876 on: May 31, 2015, 05:38:46 AM »
To the supemarket again for additional 13L vinegar, 12% version. Plundered the shelf with 12% vinegar ;D
Filled the tank completely. When done I'll store the vinegar in a 20L petrol can to be reused in another tank I have.
I guess it will be OK tomorrow afternoon 48 hours after first 5L went in.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=lsq2jgboifql1u4g7rbrn6qbn0&/topic,60973.0.html
« Reply #19877 on: May 31, 2015, 05:49:43 AM »
good you not have to get it at the  "monopolet"..vas there not a limit oif 2 bottels pr person number....
i hate all this v-w.... vords
« Reply #19878 on: May 31, 2015, 07:16:26 AM »
  Your a vinegar HOARDER   ;D ;D   What the heck do people really do with that stuff  besides cleaning coffee pots ?
« Last Edit: May 31, 2015, 07:18:52 AM by ekpent »
Online PeWe
« Reply #19879 on: May 31, 2015, 08:20:36 AM »
Pickling cucumbers, herring, salmon.... mmm
The gardening shops also sell vinegar for weed kill. 12 or 24% too.
Online PeWe
« Reply #19880 on: May 31, 2015, 08:24:50 AM »
Monopolet...Systembolaget... no limits at all, amount as well as the price! No vinegar here, only alcohol.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #19881 on: May 31, 2015, 01:31:53 PM »
Cleaned out garage to park the friends.
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline socal1200r
« Reply #19882 on: May 31, 2015, 05:00:30 PM »
Took her out on a ride from Newport News to Smithfield (est 1752) and back, about 120 miles.  Bike ran great, altho I'm a little concerned about pulling 5000 rpms at 60 mph.  But since that's half the way to redline, I guess that's okay.  I might have to check the rear sprocket, and see if it's the stock one, because that seems like a lot of rpms at 60 mph to me.  But then again, my other bikes are v-twins, which pull less rpms at 60 mph, so maybe it's okay...
Offline dusterdude
« Reply #19883 on: May 31, 2015, 05:55:05 PM »
Socal,which nn and smithfield?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Online PeWe
« Reply #19884 on: June 01, 2015, 12:59:27 PM »
Bike transformed to  more OEM like than it has been since over 33 years. It is a K6-76 now look like a K2/K4-74 with the Freedom Green Metallic and K2 swing arm that CB750 guys will notice.
Offline InAquaVeritas
« Reply #19885 on: June 01, 2015, 03:03:55 PM »
Why not use HG rust converter? Works like a charm! Used it on a badly rusted oil tank and it cleaned it out in half an hour. One bottle might do a tank, but it's not super expensive.
Was a chromed tank as well and it didn't damage it at all. Probably will eat your paint if you don't rinse it right away.
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline socal1200r
« Reply #19886 on: June 01, 2015, 06:32:03 PM »
That would be the great commonwealth of Virginia...
Online PeWe
« Reply #19887 on: June 02, 2015, 03:26:18 AM »
I have read so much about vinegar as a soft way to derust tanks inside without risk of eating thru the metal or harm the paint.
I got the idea on Saturday morning, took my car to the supermarket and bought 5L vinegar. Understood that I was too cheap and went for additional 13L on Sunday and filled tank completely. I verified tank volume when I could fill it with 17.5 bottles that most likely has a little extra in each 1L bottle (+ 3-4cl)
I have a complete tank clean/derust and sealing kit (Restom Super kit) that I planned to use. But I changed my mind when reading about eventual difficulties with sealers and the tank was rather good, no holes what I have seen (yet).
Vinegar in tank 48 hours in total (28 hours completely full). Saved vinegar in a spare plastic gas tank for my red avatar tank. Flushed tank with warm water plus brushed inside with a bottle brush.
After a few times with tap water, drained almost all water, filled with 2L conc. alcohol (for car windscreen washer tank) that diluted water to more alcohol than water. Drained tank again and direct 0.7L white spirit and 2 spoons of motor oil and shaked the tank. Out with that and in with 0.5 L gasoline and shaked the tank again and drained tank for last time.
Mounted a new fuel petcock, tank on bike and filled it with Shell V-power. Started bike and let it idle for 5-10 minutes. No signs of water in fuel..
« Last Edit: June 02, 2015, 03:29:45 AM by PeWe »
Offline Tews19
  • I am no
« Reply #19888 on: June 02, 2015, 05:44:14 AM »
Vinegar is awesome! Using a pressure washer to rinse the inside out makes the tank like new. I have done it many times. Not once have I had flash rusting.
1970 Honda CB750 survivor.
Offline mcswny
« Reply #19889 on: June 02, 2015, 05:48:40 AM »
Never thought of incorporating a power washer. Genius.
1972 CB750 K2
1975 XL250
198 XR80
« Reply #19890 on: June 02, 2015, 06:59:06 AM »
Prepped and painted my headlight bracket for a 1975 F0. Total cost $1.00   :D
« Reply #19891 on: June 02, 2015, 07:03:21 AM »
be careful to not blow out a rust-weakened area/seam  :o
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19892 on: June 02, 2015, 07:06:41 AM »
using a wide stream should help reduce pressure somewhat. Don't use a straight jet!
--Evan
1975 CB750K "Rhonda"
Offline mcswny
« Reply #19893 on: June 02, 2015, 11:51:28 AM »
Just going to put it in my back pocket for later, just cleaned my tank out last winter and im good to go for the time being.
1972 CB750 K2
1975 XL250
198 XR80
« Reply #19894 on: June 02, 2015, 12:18:32 PM »
That sounds like a really safe way to do it for sure. Good one to keep in mind if I ever have to go there.
The pressure washer on a good tank sounds good as well!
Past "bikes" ;)
Online PeWe
« Reply #19895 on: June 02, 2015, 12:41:57 PM »
My pressure washer is not functional at the moment. Hose got som holes.. I might have used it in tank which must be very good rust remover after vinegar bath.
I cleaned the engine cases with pressure washer when I restored the engine.  Felt good to flush all old dirt out from the cases with alll the small oil holes
Offline Tintop
« Reply #19896 on: June 02, 2015, 04:53:11 PM »
Put 70 miles on the 550 today. ;D  Seems the charging issue is resolved, but I've now got a front brake squeak. ::)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline MoMo
  • Ride like you're invisible
« Reply #19897 on: June 02, 2015, 05:39:59 PM »
sprung for the highest quality paint money could buy Eric? ::) ::)
Offline Tintop
« Reply #19898 on: June 02, 2015, 07:02:51 PM »
 ;D ;D ;D ;D ;D ;D ;D
77 CB550 Cafe build
Offline jebon
« Reply #19899 on: June 02, 2015, 10:19:45 PM »
Changing tires. Took off the front wheel. Ripped the rim band waiting for a new one
"Don't let schooling interfere with your education"
CB750 K0 1971
