Author Topic: What did you do to your bike today ?  (Read 3217411 times)
« Reply #19900 on: June 03, 2015, 04:38:35 AM »
Prepped and painted my headlight bracket for a 1975 F0. Total cost $1.00   :D
sprung for the highest quality paint money could buy Eric? ::) ::)
  ;D ;D   Nothing but the best over here Larry.  Still using up my garage sale box buyout of Rustoleum and other paints. Even got a can of 'chrome' in the box.  :o
« Last Edit: June 03, 2015, 04:40:35 AM by ekpent »
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19901 on: June 03, 2015, 05:09:11 AM »
Balanced my rear wheel. Was able to remove one of the big weights that was on there from the previous tire. In the process I definitely heard some SLOPPY/CRUNCHY bearings... ordering replacements soon, as well as steering stem bearings.
Lubed the chain.
Also tightened my swingarm bolt to 50ft-lbs. It was LOOSE. That might explain why my chain was going slack often, too... I've got new bushings on tap from Kenosha_Kid.
--Evan
1975 CB750K "Rhonda"
Markcb750
« Reply #19902 on: June 03, 2015, 09:43:07 AM »
After riding in the rain from a VJMC event and then having the clutch cable break a few miles from home I finally got to lube the hastily installed replacement cable.
Also cleaned & re-lubed the drive chain, then took up a little chain slack with about 1/4 turn on each jack bolt.
I also did a couple of hours cleaning the entire machine, including using some brake cleaner to remove the inevitable oil & dust collected below the cylinder head.
Nice relaxing evening it was.
 ;D
« Last Edit: June 04, 2015, 09:42:05 PM by Markcb750 »
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #19903 on: June 03, 2015, 11:18:15 AM »
My K5 finally developed the tach drive seal leak issue.  I was amazed at how much oil leaked.  Since my budget is extremely fixed, I use my bike as a daily rider and I am a cheap bastard I wanted to wait until I saved up enough for a bulk order of several items from DSS.  I noted the seal size was 4.8 x 14.5 so as a TEMPORARY fix I cut a washer out of tire patch rubber 3/16 x 1/2 with hollow punches, cleaned the face of the existing seal, applied a small amount of rubber cement and pressed the homemade washer against the face of the old seal.  I then slid a 4.8 ID oring over the tach drive shaft and reinstalled the cable.  Three days riding and no leaks.  Not a "purist" fix but not bad Hillbilly engineering to keep you riding and your engine clean TEMPORARILY!
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
« Reply #19904 on: June 03, 2015, 11:25:20 AM »
Cost me less than $4.00 for a new one at my local Honda dealer with no shipping but whatever works, you got the job done.
Offline evanphi
  • Apparently I'm an
« Reply #19905 on: June 03, 2015, 11:47:50 AM »
I don't run an original tach any more, but I am using the end of the tach cable as a plug (packed with JB Weld and shortened). I wrapped the end a few times with PTFE tape just to ensure perfect seal, as mine was leaking before, too. Turn it in the same way you wrap the tape so it doesn't come unraveled!
--Evan
  • Butch
« Reply #19906 on: June 03, 2015, 11:51:53 AM »
My local Honda dealer does not even want to look up parts on these old bikes even if you give them the part number much less offer to order it for you.  If your not buying a new bike, getting a 200 buck oil change or a 300 dollar tire they make it clear your wasting their time.  Winston Salem and Charlotte both have the seal in stock but it is not worth the drive to go pick it up so I will wait till I order multiple items and save on the shipping and gas.
750 K5
550 K1
Offline jonda500
« Reply #19907 on: June 04, 2015, 02:14:47 AM »
+1 that's exactly my experience too with the only honda dealer here in Canberra Australia, which is a newfangled motorcycle super store that also sells all the new non japanese budget brands. I ride further and pay a little more for my parts by ordering them from the suzuki dealer in Queanbyan- then they have to deal with the unhelpful bastards!!
A starter clutch thread:
« Reply #19908 on: June 04, 2015, 03:33:14 AM »
Luckily my local Honda dealer goes under the name of Cyclepartsnation on the internet so I can order from home and just walk in and pick the stuff up. About a mile from my shop, But unlike you fellas these are a bunch of very helpful folks behind the counter. Have known most for many years. One guy rooted around for 1/2 hour once through a bunch of stuff and dug me out a pair of NOS 1975 Kaw 900 Z1B keys that matched my ignition.
Offline enwri
  • So that noise is normal?
« Reply #19909 on: June 04, 2015, 04:18:29 AM »
This is what I see in my local Honda shop in Cairns, Cairns Honda.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline MoMo
  • Ride like you're invisible
« Reply #19910 on: June 04, 2015, 04:24:42 AM »
Local shop here has the same bike displayed along with a CBX,  by and large the shop is helpful and friendly.............and not all that over priced.  The younger guys(all compared to me) seem to enjoy hearing some of my stories about shop life back in the 70s-80s..Larry
Offline Proto
  • 1976 CB750F
« Reply #19911 on: June 04, 2015, 05:02:13 AM »
Did a 500 mile loop up here in NW Colorado.  Went from Craig to Grand Junction and visited the new grandkid.  Next a.m headed south to Delta and then east through Crawford and Paonia.   Backtracked to Cedar ridge and then up and over the the Grand Mesa.  Still snow on the ground up there and some of the lakes are still iced over.  Dropped down the other side and hit I-70 at Debeque and then back north to Craig.  Fun ride!  The old bike did good.
1976 Honda CB-750F1
2013 Harley Davidson Ultra Classic
Offline mcswny
« Reply #19912 on: June 04, 2015, 05:44:48 AM »
Sounds like a nice little Wednesday to me!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Markcb750
« Reply #19913 on: June 04, 2015, 09:49:59 PM »
http://forums.sohc4.net/index.php/topic,133247.0.html
For those with leaking tachometer seals
Offline jonda500
« Reply #19914 on: June 04, 2015, 10:23:58 PM »
sounds too good to be true- but I have plenty of grease so I'll definately try packing some in where the tacho cable attaches to the tacho drive and see if it makes any difference to the oil leak there..
Has anyone else tried this?
Offline Davez134
« Reply #19915 on: June 04, 2015, 10:41:15 PM »
Removed the crankshaft oil seal and drove in a generic, no-lip one on my 750 because I had put it in backwards and it started leaking badly. Posting this in hopes it can stop someone else from doing this. Metal ring in! This is wrong...
« Reply #19916 on: June 05, 2015, 04:44:50 AM »
I bought another one.................. ;D
Offline evanphi
  • Apparently I'm an
« Reply #19917 on: June 05, 2015, 06:21:23 AM »
I put a few wraps of PTFE tape on the end of the tach cable.
--Evan
Offline dave the welder
  • dave the welder
« Reply #19918 on: June 05, 2015, 06:37:01 AM »
repaired my 77 matic after a small electrical fire under the left side cover.sure am glad i never throw out stuff as i had everything in the junk wiring milk crate
don't buy it build it
Offline jonda500
« Reply #19919 on: June 05, 2015, 07:31:29 AM »
Now that sounds like a better idea- sold!  -what if the leak it between the tacho drive and the engine though?
Offline evanphi
  • Apparently I'm an
« Reply #19920 on: June 05, 2015, 07:55:17 AM »
I'm talking about the end of the cable that attaches to the engine.
I cut the end off a cable to make a plug since I use an electronic tach.
--Evan
« Reply #19921 on: June 05, 2015, 08:16:44 AM »
I rode to work today, and it was good.
Supposed to be near 80F for the next few days raining and wet forever, so don't move here  ;D
« Reply #19922 on: June 05, 2015, 10:26:41 PM »
don't worry, I won't
Offline evanphi
  • Apparently I'm an
« Reply #19923 on: June 06, 2015, 05:45:10 AM »
My bike wouldn't start yesterday.... OH NO A GREMLIN!!!
Took my tank off, started jiggling wires... IT CAME BACK ON. WOOHOO! Got me home...
Inspection (further jiggling of wires) this morning before big Ride for Dad event (you can still donate here) found that the switched power wire for my electronic speedo had come a bit loose! Fuxed her up good, and threw some electrical tape on there for good measure, too. All working fine now!
--Evan
Offline jonda500
« Reply #19924 on: June 06, 2015, 07:24:54 AM »
actually something I did nearly a year ago- scored a set of used oem carb boot clamps and popped them into a jar of fuel/kero mix, covered it and left them to soak for a while....
Today I finally pulled them out and to my dismay some of the fuel has devolved into a thick white powder crust all over the clamps arrrrrgh the opposite of the intended effect! :(
