Author Topic: What did you do to your bike today ?  (Read 3330205 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20000 on: June 18, 2015, 08:27:54 AM »
Got a "bearing puller" from Canadian Tire...
5/8" sleeved concrete anchor! Going to open it up on the old bearing, and tap them out from the inside. Should save having to mess around with the internal spacer.
--Evan
1975 CB750K "Rhonda"
« Reply #20001 on: June 18, 2015, 08:54:49 AM »
Good luck.
I went that route, once. Couldnt get enough purchase on the inner race to get it to budge.
A BFH and a punch were much more effective  ;D
Offline evanphi
  • Apparently I'm an
« Reply #20002 on: June 18, 2015, 09:18:19 AM »
Good luck.
Yes that will be my alternative solution. ;D I went around to a bunch of stores to get a nice big one. Most had only 1/2" anchors. Hopefully this does the trick.
--Evan
Offline DaveBarbier
« Reply #20003 on: June 20, 2015, 09:08:10 PM »
Just tried to stop a leak at the brake splitter. We'll see if it's dry tomorrow...but in the meantime, I replaced the CV axle in my Hyundai. I only say this here because I made a vice grip slide hammer. Used a 650 motor mount bolt as the slide and alternator rotor as the hammer. Worked like a charm! I removed most of the axle first then used the slide hammer for the cup and spindle that goes into the tranny.
1978 Honda CB550K
Offline DaveBarbier
« Reply #20004 on: June 21, 2015, 05:14:01 AM »
Did you pop it into the dryer for a few minutes first to warm it up? Steam cycle or dry heat?
-Inquiring minds want to know 8)
Regular dry heat. First tried permanent press...it does sh¡t!
1978 Honda CB550K
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20005 on: June 22, 2015, 09:13:26 AM »
Put on about 180 miles yesterday. Beautiful, warm, non-windy day on the Great Plains... pretty rare. I now know why the CB is rumored to stand for City Bike. That is where they are meant to stay! Kidding, as I'm sure many members tour on theirs, but my back is killing me. Need to order some Hagon's asap.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Tews19
  • I am no
« Reply #20006 on: June 22, 2015, 09:22:03 AM »
LOL I think the 550 CB is as comfortable as they come when riding. Its on the highway with heavy winds when it gets scary. I am a buck 50 so wind gust can be scary!
1970 Honda CB750 survivor.
Offline joeyvans
  • Definitely not a
« Reply #20007 on: June 22, 2015, 09:26:23 AM »
I am completely to blame, as I haven't ridden much in the last 10 years..... and I'm out of shape. Instead of cycling this summer, I have been working on this bike. And oh yeah..... I'm running drag bars with stock pegs. Derp!
1976 CB550 K2
Offline Tews19
  • I am no
« Reply #20008 on: June 22, 2015, 09:46:30 AM »
I had drag bars on a 750. I couldn't stand them. Swapped in the super bike and a completely different feel.
Offline joeyvans
  • Definitely not a
« Reply #20009 on: June 22, 2015, 09:58:18 AM »
I think I'll be replacing my drags with those pre-drilled super bikes from DCC at some point in the next year or 2.
1976 CB550 K2
Offline evanphi
  • Apparently I'm an
« Reply #20010 on: June 22, 2015, 10:01:38 AM »
+1 for superbike bars. You can tuck when you need to, but you're still "upright" when going slow.
--Evan
Offline socal1200r
« Reply #20011 on: June 22, 2015, 11:56:46 AM »
+2 for superbike bars.  That's what I put on my CB650, and I think that's what I put on my VT500, altho those bars might've been GP bars.  But superbike and GP bars are pretty close in dimensions.
Upon closer look, it appears that I put superbike bars on the CB, and GP bars on the VT...
« Reply #20012 on: June 22, 2015, 02:35:06 PM »
Back from the drawing board  ;D  Got my bearing sets from Japan. Ordered last Tuesday night and the mail man brought them to me on Saturday!!
Tried the brown set but they were still too loose for my taste after Plastigaging so I tried the blacks and they look OK. Good thing too since they are the thickest. Put the cases together. Next up is pistons, rings, cylinder studs and cylinders. We'll see what the next few days bring.
Offline FlipYa4Fake
« Reply #20013 on: June 22, 2015, 04:57:35 PM »
+3 for superbike bars.
Offline MoMo
  • Ride like you're invisible
« Reply #20014 on: June 22, 2015, 05:06:19 PM »
sold one of my projects(the 2000 CB250 Nighthawk) leaves 4 projects to get rid of...Larry
Offline Gene
  • Chat enuf you too can be a
« Reply #20015 on: June 22, 2015, 05:23:48 PM »
Pushing w/my feet, into the bike corner at the garage @ work, backed right up into a cement wall breaking my taillight lens.  :-[  My goodness but I do feel like an idiot . . .
*1973 CB750K3 (Bow)
Offline diloret2
« Reply #20016 on: June 22, 2015, 06:21:04 PM »
Put on a new aftermarket master cylinder, stainless brake lines and some dynatek coils/wires. It was a good day.
'64 C105T 'Trail 55'
'08 Speed Triple
'10 Vespa LX150
Past Bikes:
'75 CB550F
'76 CJ360T
'77 CT90
'80 KZ1000J
'82 CB750F
'01 VFR800
'03 919
'03 Monster S2R
'05 SV650S
'15 Monster 821
« Reply #20017 on: June 22, 2015, 06:28:16 PM »
Fitted the rings on my 71mm 1000 APE kit. Installed them on the pistons. Broke out the APE studs. Got my cam chain tensioner stuff together along with the base gasket.
Got the call from my powder guy to come pick up the Lesters. Need to drop off the frame to have the Gordon kit welded in and then a good coat of metallic silver.
Next up is Loctite and torque the studs, install the pistons and slide the cylinders down over the pistons and install the All Balls bearing kits on the Lesters.
Offline joeyvans
  • Definitely not a
« Reply #20018 on: June 24, 2015, 07:34:09 PM »
Nothing, but some goodies came in the mail today. Now I have weekend projects.
1976 CB550 K2
« Reply #20019 on: June 24, 2015, 09:06:54 PM »
Got the studs installed. Got the pistons installed. Got the cylinders installed. It rotates fine. Picked up the Lesters. My powder guy did a helluva job. Look great. Dropped the frame off for Gordon's Kit to be welded in place. There was a sign on the door "closed" but I found a garage door open. The guys were prepping a quad for the Pikes Peak Hill Climb on Sunday.  Left it with them. Doing a little yard work too so my bike progress is slow but deliberate  ;).
Gotta work outta town the rest of the week. Next up is wheel bearing install. Install the head and cam then degree it. Pick up the frame next week and drop it off at the coater. Few other odd and ends on tap before the frame is coated.
Offline brandEn
« Reply #20020 on: June 24, 2015, 09:38:12 PM »
Jerry your building a 1000? Where the F have I been? Sweet! Any pics buried in this thread?
Offline evanphi
  • Apparently I'm an
« Reply #20021 on: June 25, 2015, 05:38:48 AM »
Ordered my tapered steering bearings and wheel bearings... All Balls for everything from http://www.canadasmotorcycle.com! Now I can get my wheels and swingarm all done up, I'm going to save the steering bearings for the winter.
The previous owner of my house left something like this:
in the garage... Couldn't figure what it was for until the other day. Bearing race remover! This will be helpful for the steering bearings job.
Ordered cush drive rubbers and a new o-ring for the rear wheel/sprocket carrier, new tongued washers for the rear sprocket, and new lockplate for the front sprocket. All from my local stealership.
Also ordered a new shield for my helmet, and some new gloves.
« Last Edit: June 25, 2015, 05:45:15 AM by evanphi »
--Evan
Online CycleRanger
  • No comment about being an
« Reply #20022 on: June 25, 2015, 04:04:55 PM »
Got a few stickers for the CJ360T side covers.
I have a buddy who has a sign shop. He reproduced these for me.
I was like dude, I only needed two!
He said it was just as easy to print twenty as two. ;D
Might see if any other CJ owners over at the Twins forum need any of these.
Offline Tews19
  • I am no
« Reply #20023 on: June 25, 2015, 08:49:32 PM »
What a great day with the honda! While I traveled across Wisconsin to Michigan on m vfr. My Lil bro clean my 605
Sent from my SAMSUNG-SM-G900A using Tapatalk
Offline edwardmorris
  • Youngish
« Reply #20024 on: June 25, 2015, 09:04:50 PM »
