Author Topic: What did you do to your bike today ?  (Read 3163117 times)
Offline calj737
  • I refuse...
« Reply #20075 on: June 29, 2015, 04:27:14 am »
Given the stain line on that pump, Terry, do you think the rust accumulation was more from storing the tank half full of gas for prolonged periods or from the use of ethanol fuel? I know ethanol gets a bad rap by lots, and I'm one of them, but I'm also of the opinion that half-full storage even with pure gas will create rust.
It's always been my practice to store full or empty to avoid such a problem. With no room (full) for expansion and separation, the rust is prevented. With no fuel (empty) left, there's nothing to separate and create moisture.
« Reply #20076 on: June 29, 2015, 04:58:41 am »
Yep, possibly Cal, but "normal" fuel doesn't cause that degree of rot over here mate, I used a "bore scope" to look inside her tank, and while I had it out I took a peek inside my Triumph Rocket III and BMW K100RS tanks, and even though they were both almost empty, (I often raid my bikes for fuel for mowers/chainsaws/other bikes) there was no staining, and no rust, (thank God) in either of them.
All the terrible things that you said about ethanol fuel is warranted, and normal fuel wouldn't have softened that O ring to the point where fuel was bypassing it, either. Cheers, Terry. ;D
« Reply #20077 on: June 29, 2015, 06:01:45 am »
I was in the basement of a friend who has a Ducati dealership called Life Cycle here in town and off in the corner was a pile of what looked like new tanks. They were all used recall that had swelled and distorted because Ducati did not take into account what effect ethanol would have on their plastic, err I mean composite tanks.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20078 on: June 29, 2015, 07:26:51 am »
Redid my swingarm bushings.
Removed the old ones...
Went to my in-laws and used the 10-ton shop press (mechanic for in-law is awesome!) to press them in...
Got everything back together with a nice coating of new grease. Going to ride it tonight.
Discovered something fun... Notice anything missing?
How about now?
Broke a forking spoke! No idea how long it has been like this. Anyone have a spare spoke for a 17" rim (Hondamatic/77-78K) they want to send me?
--Evan
1975 CB750K "Rhonda"
« Reply #20079 on: June 29, 2015, 01:32:18 pm »
FOUND MY OIL ORIFICES! yes!! They were right in front of me (as I expected) tucked under the fold of a towel. LOL. Fit them in the head with new o-rings. Check, all good.
On to the cam, or not. LOL. Grabbed all the cam tower hardware. Cleaned. Lubed. Test fit time. Insert the cam inside the chain. Damn, shoulda slid the cam inside both the sprocket and the chain. Grab the best sprocket of my 3 BUT.... none have slots in them for my 315 cam. LMAO while ordering a slotted sprocket from Dynoman.
Guess it's hurry up and wait time again. Gotta find something else to do until HOPEFULLY no longer than this weekend. Guess I'll select a coater for the frame in the mean time. The welding should be done then I can drop it off. Oh well, back to finishing out my basement. Plumbing rough in completed this morning. Inspection Wed. Electrician coming Th to get me set up and order the parts so I can do most of that myself.
I need to do my frame stuff too including the steering head bearings and swingarm bushings like evanphi but that's all after the powder coating. Sigh, more yard work too.... This other stuff just isn't as much fun.
Maybe I'll do a build thread later but this will have to do for now.
« Reply #20080 on: June 29, 2015, 02:49:38 pm »
Jerry you sound like a very busy man right now, nothing like mixing in a remodel project along with a little hot rod building. Looking great so far  ;)
Offline WhyNot2
  • I'm finally an
« Reply #20081 on: June 29, 2015, 04:45:40 pm »
I installed the new carb onto the engine  of my little tinker toy cb100.
Also put the new battery in, and mated the hot and ground wire for the ignition, and blew the freaking main fuse.
Ordered a new wire harness from online source, and will wait till it comes in to try again.
« Reply #20082 on: June 29, 2015, 06:38:17 pm »
I'd love to have one of these for a father son project.
Offline 5thofhonda
« Reply #20083 on: June 29, 2015, 08:15:07 pm »
Finally got the Honda tool for the clutch retaining nut, only to realize I have nothing to keep the basket from spinning.  So today I spun the clutch and stared for about half an hour before calling ita day.
Offline Tintop
« Reply #20084 on: June 30, 2015, 03:25:23 am »
An old clutch steel, with a piece of 1/4" steel rod welded on works. ;)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #20085 on: June 30, 2015, 03:44:39 am »
Or a cheap strap wrench. ;D
« Reply #20086 on: June 30, 2015, 03:56:33 am »
I just made me a tool for that.
Offline jonda500
« Reply #20087 on: June 30, 2015, 07:56:06 am »
one time I successfully used piece of rag stuffed between the cogs
A starter clutch thread:
Offline Tetter
  • CB500F Café - CB750F K6
« Reply #20088 on: June 30, 2015, 09:36:53 am »
Bought 1 1/2 CB650
The incomplete one has a title the complete one has not ....
Fixed some elec gremlins, cleaned the carbs as the PO already did...... Sure
Some fresh fuel and a charged battery...
Vrooom
Thinking of making this one a nice tracker for my lady
Verzonden vanaf mijn iPhone met Tapatalk
« Reply #20089 on: June 30, 2015, 08:18:25 pm »
Decided to come back in from the garage  :D
There are a number of little projects that can be done while waiting on the frame and the slotted cam sprocket. Did a total rebuild on what appears to be a really nice oil pump. Used Elans parts plus new end cap o-rings and the shaft seal. That's always fun to remove  ::)
Took the starter clutch off the RC lightened rotor. Had a little difficulty removing it. The threads are buggered. Glad I hadn't torqued it down! Got it cleaned and ready for overhaul parts which I need to order. Also cleaned up my oil lines using brake cleaner and the brass wheel. I sandwiched this between a doctor appt and lawn mowing.
Offline WhyNot2
  • I'm finally an
« Reply #20090 on: July 01, 2015, 07:51:36 am »
Sum beech.........she fired...................sum beech.
Don't know how............but...................sum beech.
Offline DaveBarbier
« Reply #20091 on: July 01, 2015, 09:11:03 am »
Dat dare woh sum beech
Offline WhyNot2
  • I'm finally an
« Reply #20092 on: July 01, 2015, 11:12:07 am »
Sum beech........................the efing kicker stripped..........sum beech.
Back to the drawing board..............or scrap pile.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=tr83kirljdkj0lbq19oiq95et0&/topic,60973.0.html
« Reply #20093 on: July 01, 2015, 01:59:27 pm »
pulled the carbs ,of the 550..it have not ran vell this seson..and after to have thanged plugs..and not better..it vas the hard vay..
or hard..,,,after to have worked on my cbx for a vinter...the cb is total simpel and easy to Work on..
faund some strange rubber/grease Wax stuff/plugged the mains half.. there vas no rust or oxidasion..only this soft strange Wax ..so after adjusting the flots..and klean all up..i heated the rubber konnektions..and pressed the all back inn..and it run perfekt..
i hate all this v-w.... vords
« Reply #20094 on: July 01, 2015, 05:42:41 pm »
That engine looks "F-ing" fantastic Jerry, but I don't think it'll run well, you've left all your rockers out! ;D
« Reply #20095 on: July 01, 2015, 06:46:50 pm »
Thanks Terry. Just had to put the bling valve cover on for the picture. If Buzz will get me that sprocket I'll use the rockers haha.
In the mean time I'm piddling. Not much headway today. I realized that I had not taken the rear sprocket carrier to be coated with the wheels so I did that. Thought I'd get by 'reasonable'. I paid $125 each to powder the wheels and now that damn carrier is $85.
Just came from the basement and gathered up all the hardware for the wheels. I'll give the parts for the Lesters a test fit tomorrow after installing the bearings plus clean up the swingarm and install the new bronze bushings. My discs really need surfacing and holes but not now. Decided its premature to coat the frame since I'll probably install a GSXR front and do something with the tail eventually but I want it to be road worthy first. Guess I need to look at the brakes too. Gotta do all the boring stuff sometime huh!  ::) So far I'm finding most of what I need
Gotta get tires and tubes ordered too. Avons maybe? Next credit card cycle  ;)
« Reply #20096 on: July 01, 2015, 06:54:14 pm »
Ha ha, yeah mate, it never stops, but the only way to get a bike you can ride is just bite the bullet and get it finished. I'm very happy with the Pirelli's I've put on my last three projects, but if you're looking for more traditional tread patterns, Avons are good, as are Conti's. Cheers, Terry. ;D
Offline Tews19
  • I am no
« Reply #20097 on: July 02, 2015, 06:22:42 am »
Jerry, get Perilli Angel GT's. I recently had a set installed on my VFR. The best, stickiest, smoothest tire for all types of riding.
1970 Honda CB750 survivor.
« Reply #20098 on: July 02, 2015, 03:48:50 pm »
yup, got Pirelli Sport Demons on my VF500 and they are really good tires
« Reply #20099 on: July 02, 2015, 05:28:50 pm »
They don't make Angel GT's in sizes to suit CB750's mate, that's why Sport Demons are so popular on our bikes. Cheers, Terry. ;D
