Author Topic: What did you do to your bike today ?  (Read 3277692 times)
0 Members and 7 Guests are viewing this topic.
« Reply #20625 on: October 26, 2015, 02:04:27 PM »
I added oil to the beast and I am wondering if I should add Chrome or Black headers.  What say you.  Wrap is also an option.
Black  8)
A cheap header, saved from the junk pile, wrapped and VHT'd black would look good.
Just find a better looking can than a MAC  ;)
« Reply #20626 on: October 26, 2015, 03:14:51 PM »
Black  8)
+1 a nice black header [not wrapped] with a Cone can.
I have a nice header for sale if you are looking.
Offline millla03
« Reply #20627 on: October 26, 2015, 04:25:24 PM »
Rolled it over 30,000 miles!
Luke
72 Honda CB750 K2
78 BMW R100/7
83 Honda Nighthawk 650
07 Honda Rebel 250
Offline Pat_at_APE
    • APE Race Parts
« Reply #20628 on: October 27, 2015, 04:07:35 PM »
Took this image just now.....  I'm almost there too!!!!!!
Pat at APE
Offline Oz350Four
  • Keep yer stick on the ice...!!!
« Reply #20629 on: November 01, 2015, 01:54:11 AM »
Started on the forks to get the bottom cases ready to go to the powder coater with all the other parts.
So I got the forks out of the triple tree.  Both of them had heaps of rust up under the shrouds and covers (ears).  I used some very fine wet n' dry to get it all off followed by some cutting compound.
Next were the chrome doohickies... man what a pain...!!! but slowly slowly catchy monkey tapping all around gently and done.  Decided to polish the fork ends (the bits that hold the axle on).
"Me speed officer...?? never..!!!"
1972 CB350F Four - Project Ol' Red (current)
2007 Harley Davidson Softail Deuce - Sold to start this project.
Offline CycleRanger
  • No comment about being an
« Reply #20630 on: November 02, 2015, 03:53:56 PM »
After cleaning out the glass beads I loaded the blasting cabinet with soda.
It was a little chunky so I did a little chopping...  ::)
Cleaned up a carb body for the CJ360 to replace the one that broke when I knocked the carbs off the bench!
 >:( :P
Offline millla03
« Reply #20631 on: November 05, 2015, 06:50:57 PM »
Pat at APE
Nice, Pat! I know there are bikes on here with a lot more miles but it's a cool watch all the numbers roll over.
Luke
72 Honda CB750 K2
78 BMW R100/7
07 Honda Rebel 250
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20632 on: November 10, 2015, 08:08:53 AM »
Replaced stock coils with Dyna 5 ohm coils (DC8-1) & Dyna copper core wires with NGK 5k ohm caps  to complete my ignition upgrade... Pamco was installed about a month ago. Hoping this corrects my weak spark on #4 so we can burn out some of the carbon buildup. If this doesn't fix my #4 issue, I'm probably looking at a top end refresh. Ugh! Hope to test run later today, then if weather cooperates..... get out for a long, spirited ride this weekend.... then park it for the winter.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #20633 on: November 10, 2015, 09:14:02 AM »
 >:( :P
I was in H.F. the other day and noticed they have an adapter for soda. Are you using that? Hoping for some nice after pictures! I have a set of Webers that could use a soda blasting.
Sounds like #4 is/was the wire (did you swap out #4 with #1?), the plug cap (previous comment), the plug or the carb since it is only on one cylinder.
Offline joeyvans
  • Definitely not a
« Reply #20634 on: November 10, 2015, 11:52:30 AM »
Jerry, I had intended to swap the 1 & 4 wires to see if I could get some soot on the #1 plug and confirm the wire as the problem, but the wires had been snipped too far by the PO.  They weren't long enough to swap.  Also, because I couldn't snip much more of the wires, I just wanted to start fresh anyways.  But I agree.... I would have been nice to confirm a bad wire before upgrading.
I am ditching out of work in a half hour to do a little shakedown on the new coils/wires.  Fingers crossed that I get some consistent readings now.  It's gonna work!!!!!
1976 CB550 K2
Offline CycleRanger
« Reply #20635 on: November 10, 2015, 03:14:26 PM »
 >:( :P
No I don't use any adapter, I just install a smaller orifice.  Seems to work ok.  I got the CJ360 carbs back together. I guess I could take a photo.
But in the meantime here's the carbs from the 750K5 I did a couple of years ago. :)
« Reply #20636 on: November 10, 2015, 04:53:46 PM »
I picked up a fresh box of 80 grit glass bead since mine is getting very difficult to blast assuming it's due to age and maybe 2000 grit now LOL. I looked at the orifice but wasn't sure how to remove it for replacement. Ideas??
I may try that conversion kit for soda when it comes time to clean up the Webers.
Those carbs look nice plus the soda is water soluble leaving no engine damaging grit.
« Reply #20637 on: November 10, 2015, 07:12:57 PM »
I bought another one. BMW R1100GS. Pics when I pick it up on the weekend. ;D
Offline CycleRanger
« Reply #20638 on: November 10, 2015, 08:36:12 PM »
My gun uses replaceable ceramic tips.  Yes, the soda works great on the pot metal.  Just make sure you have enough pressure. I run at ~90psi / ~15CFM
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=vieohq1r65a14aqqdl3mn09qd3&/topic,60973.0.html
« Reply #20639 on: November 11, 2015, 03:26:18 AM »
is it a runner.?.you..goes to summer...so be ready for the road.
..ve are going for snow my insurence ends at the 15 this month...then it 4 month Winter sleep....and fixing bikes inside in the shop/cave...thinking of a vinter bike ....
« Last Edit: November 11, 2015, 07:54:43 AM by strynboen »
i hate all this v-w.... vords
Offline CycleRanger
« Reply #20640 on: November 11, 2015, 04:25:41 AM »
Go for it! ;D
Offline 72 yellow
« Reply #20641 on: November 11, 2015, 06:40:13 AM »
Pulled the Kerker off and dropped the oil pan.  No strange objects lurking in the bottom.  Going to pull the pump and replace the O rings.  Neighbor and I built a wooden stand to run the bike up on.  What a relief on my old back.  No more laying on the floor.  Should have done this years ago.
Offline joeyvans
  • Definitely not a
« Reply #20642 on: November 11, 2015, 06:54:18 AM »
Nice! We need pictures of the stand. One without the bike and one with!
1976 CB550 K2
Offline strynboen
« Reply #20643 on: November 11, 2015, 07:58:53 AM »
i used to have a Yamaha dt for Winter...but are tired of 2 stroke smell..and gets to old for rpm...needs a singel stamper 500 4 stroke..to hammer through the Winter snow....
Offline joeyvans
  • Definitely not a
« Reply #20644 on: November 11, 2015, 08:08:36 AM »
Got my '88 DT50 (49cc, liquid cooled)going this past weekend for the 1st time in 15 years. I was surprised at how well it got my 195 pound body up to speed. Neat little street legal smoker. But there is no way it would run through much snow. I don't think I could ever tire of the smell of 2 stroke.
1976 CB550 K2
Offline 72 yellow
« Reply #20645 on: November 11, 2015, 04:37:20 PM »
No pics of the bike off the stand.  As soon as it was built the repairs began.
Offline 72 yellow
« Reply #20646 on: November 11, 2015, 04:42:22 PM »
Built the stand in 2- four foot long sections.  About 25 inches wide.  17 inches high.  The chock is from Harbor Freight.  The ramp attaches to the rear using the 2 spikes to hold it in place.
Offline joeyvans
  • Definitely not a
« Reply #20647 on: November 11, 2015, 04:45:32 PM »
Excellent.... Looks beefy! Someday, I'll have room for a nice big stand.
1976 CB550 K2
Offline CycleRanger
« Reply #20648 on: November 11, 2015, 07:25:00 PM »
Yeah, I need to build one of those.
Offline 72 yellow
« Reply #20649 on: November 12, 2015, 05:59:59 AM »
Looks are deceiving.  It's a 2 1/2 car garage shared by my 77 Monte Carlo, a 71 BSA Lightning, a 66 CB77 SuperHawk and the CB750.
