Author Topic: What did you do to your bike today ?  (Read 3161905 times)
0 Members and 9 Guests are viewing this topic.
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #20950 on: January 23, 2016, 03:13:12 pm »
Charged the battery and started the bike.  27 degrees F. foot of snow in the ground.   Haven't had it started since early Decemeber.  I let it run on choke until it started complaining and then opened her up. I kept it running until the exhaust stopped producing fog.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #20951 on: January 23, 2016, 03:38:17 pm »
Took an 80 mile spin to check out a new members bike. Pretty solid example.
It was a little cool but I've been jonesing to go for a ride all week!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline whitjonw
  • Motorcycle Maniac
« Reply #20952 on: January 23, 2016, 04:19:12 pm »
Fitted new bars to my '74 CB750 today....low and 32" wide. Tomorrow, the '73 CB500 gets new bars.
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline theslayedsaint
« Reply #20953 on: January 23, 2016, 07:38:51 pm »
Finally got a full day of stuff done!!
-got my rear wheel put on
-figured out how to run my rear brake with bigger tire
-bent the brake bar to work with bigger tire
-found out that my fresh painted brake caliber has a striped blender hole!! Yay
-and did a little mock up
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline spotty
« Reply #20954 on: January 24, 2016, 02:50:51 am »
got another hour or two with the motor this morning, pulled all the bolts i could find on the bottom of the motor, then all the bolts i could find on the top of the motor then tapped gently with a nice gentle rubber hammer. no go.
rather than forcing the issue i investigated further and discovered one more bolt hiding under the starter motor cover, undid that then mrs spotty called me away to spend a fruitful day painting granny's house.....
work tomorrow but day off tuesday so we shall see what happens then
i blame Terry
« Reply #20955 on: January 25, 2016, 02:45:10 pm »
Got a box with parts to my CB750 from David Silver.
One package was extra fun when it was NOS part with old package before the barcodes.
These old NOS packages will be collectables too? :)
The good higher fork seal, 13mm version that replaced the earlier 11mm model that had a washer. The 14mm version explained in Bulletine 1974. Same model I bought 1980 and 1984.I remember the harder and tougher seal.
I'm very surprised that the crappy 11mm model is the one that most dealers sell. I bought them 2012, 2013. Got a leak direct. Replaced with the 13mm version that is really tight and clear which side up. I have 3 sets of the better one, just for sure.
Honda replaced the 11mm version over 40 years ago. Why still on the market?
« Last Edit: January 26, 2016, 01:17:23 am by PeWe »
Offline gdgreen56
« Reply #20956 on: January 25, 2016, 05:28:20 pm »
I'm in the process of mocking up the electrical system. Today I finished building a mounting plate for the rectifier. I ended up removing the mounting ears for the original voltage regulator and rectifier to make room.  I wish I had thought through this modification before I had the battery tray and voltage regulator mount plate powder coated the first time....
I used the two holes at the bottom of the battery tray and the right mounting ear for the fuse box as the main mount points.  The fuse box ear sits about .25" above the surface of the battery box so I added a .25" spacer to each of the bottom mount points to get the spacing right.  I'm not sure how warm the rectifier gets in operation but the gap created should give it some extra airflow anyway.
I'm thinking about shortening up the leads coming from the new rectifier to keep the installation tidy.  I'll probably have to do the same on the wiring harness side.  So, next on my "need to have" tool list will be a good quality crimper!
Here are a couple of pics of what I ended up with.
1976 CB750K Cafe Project
2007 VT1100C2 - Sabre
Offline spotty
« Reply #20957 on: January 26, 2016, 02:58:46 am »
finally got the two halves of the motor apart (kept taking bits off the sides until it wanted to come apart, gear selector stuff etc) and there appears to be no obvious damage or wear, i can see no reason why the kicker locks up when the motor is complete....hate hate hate
there is, as far as i can see, no damage, missing bits, broken bits anywhere near the kicker mechanism so i shall go out and give the whole thing a thorough looking over for any signs of wear/damage to the cases to indicate where the shards of alloy came from (stuck to the oil pump pickup screen)
on a more positive note, i got absolutley nowhere with the front end after much bfarting round with axles/spacers/etc as i discovered i need to have the discs bolted up with the speedo drive retainer as well as the speedo etc to get the final spacing and because i'm going twin discs (with GSXR calipers) the old bolts are a cm too short so new ones of them before the weekend and maybe get the front end finished ....
i blame Terry
Offline Guido56
« Reply #20958 on: January 26, 2016, 09:40:18 am »
Today I decided
They revised the engine of my K1
It has 90,000 km, I have to do it
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
« Reply #20959 on: January 26, 2016, 07:16:46 pm »
Back to it. Dropped by Honda this morning to pick up my 12mm hose. 95005-1200120M. 12 X 1000 = 12MM X 1000MM = ~ 4' which is enough for all the hoses on 1 bike, mine anyway. Got all those cut and attached.
Put the carb bank together. Smooth and clean. Terry has scared the #$%* outta me about the bead blasting but I gotta try. I sprayed the passages with brake cleaner and hit them with compressed air from both sides. We'll see, keeping my fingers crossed. The larger passages shouldn't be an issue.
Installed my new carb boots and the carbs went on relatively easy.
Went looking for the throttle cables..... Uh Oh! No cables. #$%*!! Did I mention #$%*!! Oh well, there's still stuff to do. That's a jug of oil and fork oil. Need to do that. May as well order a new wire harness with the throttle cables and a new right side control so I know I'll have a good starter button. Worked a bunch extra lately  ;D Gotta run a new fuel line from the petcock too. Clean up and install the air cleaner box with new boots. Bleed brakes. Hang the Dyna III box. Install the chain. May start with a stock seat in place of the Corbin?? Fire this 1000cc #$%* up soon.  ;D
Now for any of you that wish to replace that bottom unobtainium drain tube on the little catch container on the vent lines you may want to try ordering this. It's a little long but just cut it off  ;)
« Reply #20960 on: January 26, 2016, 08:20:25 pm »
You mentioned in another thread you may cafe it to some degree..?  I would leave it as it is mate, its starting to look the business, except for those bloody handle bars, did I mention superbike bars would look good..?   ;D ;)
« Last Edit: January 26, 2016, 11:37:33 pm by Retro Rocket »
« Reply #20961 on: January 26, 2016, 11:06:47 pm »
Thanks Mick. Give me your idea of bars. Link me up. I really wouldn't mind a modern GSXR (?) front end down the road but that'd delete the Lesters and the period look. The way I figure it I have my restomod original owner stock 75 with an upgraded engine so why not do a hot rod?!
« Reply #20962 on: January 27, 2016, 01:55:35 am »
Looks great Jerry, just make sure you've got another set of good carbs on hand for it for when your worst fears are realised and your engine runs like shiite. (Ask Hondaman if you're still not sure, he explained how I'd destroyed my carbs by bead blasting them) No amount of carb cleaner and compressed air will move that mountain of glass beads jamming up your carb's tiny circuits.
I definitely wouldn't put modern forks on it unless you're gonna go the whole hog and do a wider swingarm, modern wheels and brakes at both ends etc. Superbikes bars would be good, I remember the horrible factory ape hangers that were on my F0 when I bought it new back in the 1970's, they lasted about a week before I replaced them with flat bars and a "Stone" fairing. Cheers, Terry. ;D
Offline Dino
    • HackAWeek
« Reply #20963 on: January 27, 2016, 04:22:55 am »
I fired up the CB750K3 again today after work. I let it run for several minutes this time. he rings are starting to get well seated and the idle smoothed out considerably. Sure does sound great! Looking forward to spring and a completed project!
If it ain't broke, don't fix it!
« Reply #20964 on: January 27, 2016, 05:51:48 am »
Pics or it didn't happen
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=i4f4hp7c22o6t5dhsr86gsq7d0&/topic,60973.0.html
« Reply #20965 on: January 27, 2016, 06:17:10 am »
made some old 1970 puch stuff better looking..
« Last Edit: January 27, 2016, 06:19:12 am by strynboen »
i hate all this v-w.... vords
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20966 on: January 27, 2016, 07:52:43 am »
--Evan
1975 CB750K "Rhonda"
« Reply #20967 on: January 27, 2016, 07:55:54 am »
It happened!  Thx
Offline strynboen
« Reply #20968 on: January 27, 2016, 09:39:12 am »
i normaly prime the oil  pump galeliry/,,using a battery drill machine...to rotate the engine vith no plugs inn. and kontroll the cam and valve time a ekstra time.let it build pressure up and shut Down the oil light...or have the cover off to see the oil .then i power the coils up..and fire it up..it gives a ekstra safty..
« Last Edit: January 27, 2016, 10:15:26 am by strynboen »
« Reply #20969 on: January 27, 2016, 09:48:24 am »
I have that set of Australian Webers up next. Can't figure out how the gas stays in the bowls with them on upside down??  ;)
« Reply #20970 on: January 27, 2016, 06:54:42 pm »
Yeah mate, sadly Oz spec Webers won't work in the Northern hemisphere, send 'em to me and I'll send you a set of CR31mm carbs I bought from the USA before I discovered this problem. Cheers, Terry. ;D
Offline jamesv220820
« Reply #20971 on: January 29, 2016, 04:58:46 pm »
I went for a ride.  I have put a grand total of 110 miles on her. since the 5 year rebuild
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20972 on: January 29, 2016, 05:26:30 pm »
Beautiful bike, beautiful scenery, beautiful pic.
Thanks for sharing!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #20973 on: January 30, 2016, 12:44:55 am »
When I bought my magnificent BMW R1100GS, it had been set up by John, the PO, and probably the PO's before him, for long distance dirt road touring, so the more I remove from it, the more I like it.
John had built a really practical, but thoroughly fugly rack to take lots of aftermarket soft luggage, but it looked a bit too industrial for my tastes, so today I removed the last of the home made racking, and installed a new Hepco and Becker topbox, which will be about all I'll need, it'll be especially handy for picking up groceries. Cheers, Terry. ;D
Before:
Today:
Offline calj737
  • I refuse...
« Reply #20974 on: January 30, 2016, 04:25:51 am »
C'mon Terry, show us the man purse you attached that holds your riding Lycra!  ;D ;D ;D
