Author Topic: What did you do to your bike today ?  (Read 3161808 times)
0 Members and 18 Guests are viewing this topic.
« Reply #21000 on: February 02, 2016, 07:20:07 pm »
nice Terry,what rpm does it turn on the highway?no tach on mine.bill
Mine sits at around 3,000 but its a 4 speed lol
mine is 4 speed too,guys, some time it feels like it could use an od gear,but other than that it will pull from low down in any gear.terry they claim that the 5spd was better at slower spds.bill
Could be Bill, but they're such a torquey engine I suspect it had more to do with marketing....... ;D
Offline kghost
« Reply #21001 on: February 02, 2016, 11:34:59 pm »
Don't hold your breath Tim, they take a long time to get there...... ;D
Yeah my 883 did....this 1200 is a bit punchier...
Stranger in a strange land
« Reply #21002 on: February 03, 2016, 01:00:53 am »
I (only just) got mine up to the "Ton" at Christmas Tim, it pulls really well up to about 80, then runs out of puff with the overly lean stock CV carb.
My project is to double the stock rear wheel horsepower over time, it's already got the Screaming Chicken mufflers, so should be improved with the Mikuni HSR42 carb when it arrives. My engine's only done 4000 miles in it's 22 years so I don't want to do any major surgery yet, just little mods.
Like you, I've got much faster bikes, so it's not like I'm starved for scary fast thrills........... ;D
Offline kghost
« Reply #21003 on: February 03, 2016, 01:57:58 am »
True that...I can scare myself silly any day of the week....
Got an R1 around here somewhere.....
« Reply #21004 on: February 03, 2016, 02:36:57 am »
Nice! My neighbour's kid has a pretty rough early R1 rotting in his driveway, I've been tempted to make him an offer for it, but I just can't squeeze another bike in my garage at the moment..... ;D
Offline Bronko37
« Reply #21005 on: February 03, 2016, 05:14:47 am »
Today I am going to begin stripping the paint from the gas tank of the 750K. I just picked this bike up on Sunday and I cant wait to get her stripped!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21006 on: February 03, 2016, 06:34:19 am »
New progressive springs arriving by post today... new tubes by the end of next week, hopefully!
--Evan
1975 CB750K "Rhonda"
« Reply #21007 on: February 04, 2016, 10:18:38 am »
Oil pump restore with Elan oil pump kit. Waiting for new countersunk bolts M6 x 60.
I do not like the X bolts and they dont like me. I took them out the hard way with my drilling machine and various sizses of drills. That worked fine, not a scratch on the pump.
Now only hex bolts and the countersunk ones will have allen heads. Pump has to wait for rest of the engine that is not yest out from frame and opened. It will get another crank, trans and better clutch parts.
http://www.ebay.com/itm/111837901896?_trksid=p2060353.m2749.l2649&var=410819989873&ssPageName=STRK%3AMEBIDX%3AIT
« Last Edit: February 04, 2016, 10:22:17 am by PeWe »
Offline egli1000
« Reply #21008 on: February 05, 2016, 11:26:30 am »
BON 2016 A VOUS.
[/b][/color]
[/center]
« Last Edit: February 05, 2016, 11:29:42 am by egli1000 »
« Reply #21009 on: February 05, 2016, 11:50:12 am »
Terry, if its early evo sporty , i cantel, you how to get in the 12,s for around a gnote and your labour....we got my buddies to12.7 first outing.. With stock carbs and original pipes..minus baffles.
« Reply #21010 on: February 05, 2016, 11:58:38 am »
Thanks Frank, the guys over on the Sporty and Buell forums say that a better carb and less restrictive pipes makes a huge difference to their performance, and even reduces the vibrations by a fair bit, so I'm looking forward to the new HSR42's arrival. I was hoping it would have arrived by now, but no biggie, plenty of other bikes to work on...... ;D
« Reply #21011 on: February 05, 2016, 12:04:58 pm »
Heres what we did..stretched swingarm 4 inches.. This can be optional..
1200 kit.. Back then it was stock 80 inch big twin pistons and a template the hemi the head..gonna grind for a while.. Todays dropin pistons may elimnate that part .
 We removed airfilter, put cover back on.
 Mounted the mufflers in the mill,cut out the main baffle... With a hole saw.. Allows you to weld it back in ..throathy,but still some baffle so you can ride on the street.
 Not sure if we touched the gearing... Thats all we did to it.. Maybe rejetting..
Offline kghost
« Reply #21012 on: February 06, 2016, 01:26:40 am »
....What are these Baffles you guys keep talking about?
I put the R1 back together....
« Reply #21013 on: February 06, 2016, 03:29:56 am »
Thanks Frank, mine's an XLH1200, I don't want to do any internal engine mods just yet, but I must admit I'd love to take it out to 100 cubic inches, (1640cc) eventually. I've been looking at prices of donor engines in the US, and I've seen some for around $1K, so eventually I might import one and stuff it full of S&S big bore kit, cams, heads etc. I'd love to just buy a whole S&S engine, but they're silly money.
That's a nice old R1 Tim, where'd you score that? Cheers, Terry. ;D
Offline kghost
« Reply #21014 on: February 06, 2016, 01:35:28 pm »
He called us....was moving to adelaide...
Offline Desert-SOHC
  • It's old
« Reply #21015 on: February 06, 2016, 03:09:51 pm »
I finally got around to figuring out the rest of my electrical issues. I had no front brake light signal and my horn has never worked for me. Turns out "as usual" it was 38 years of corrosion...cleaned the switches and housings and now everything works as designed.
WoooooHoooooo!!
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Kenzo
« Reply #21016 on: February 06, 2016, 03:45:09 pm »
Sorting out the electrical relocation(under-seat), went on check-out ride(she likes 60 degree air) everything looks good. Now its time get everything permanently mounted. Next big project is the fiberglass seat pan and cowl. Oh...and I tested some new riding gear, ATGATT. ;)
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #21017 on: February 06, 2016, 06:46:46 pm »
I swapped the wheels back on the 2 400F's. Yellow got it's original wheels and new ties back so Red can have the new rims, tires  and spokes.
Offline two40
« Reply #21018 on: February 06, 2016, 11:34:37 pm »
Finally got the clutch adjusted to a sort-of-acceptable pull. It still gives me a workout but I can live with it I guess. Can't wait to meet owners of other CB's so that I can compare with their clutches.
Last week I changed the flat bars the previous owner installed to Renthal low bars. At the same time I got rid of a third party start switch and got the original one working. Took me 3 attempts to make the little bracket but persiverance paid off.
Offline flatlander
« Reply #21019 on: February 06, 2016, 11:45:54 pm »
after a lot of searching in all possible and impossible places, getting really desperate and close to checking myself into a mental institution, i finally found my helicoil kit in the dog's box!! does that count?
Offline Andy K
« Reply #21020 on: February 06, 2016, 11:52:18 pm »
actually yesterday but anyway.. made some new wires for new speedometer and light/blinker/horn switch
« Last Edit: February 06, 2016, 11:54:12 pm by Andy K »
ex bikes:
Honda CBR 1100XX '98
Suzuki VL1500 Intruder LC '98
Suzuki GSX1300R Hayabusa '03
this is my version of Honda CB750 '77:
http://caferacer77.blogspot.fi/2015/10/tasta-lahdettiin.html?m=0
Offline evanphi
  • Apparently I'm an
« Reply #21021 on: February 07, 2016, 03:49:07 am »
Winter 2016 project begins! For more pics see my build thread in sig.
--Evan
Offline Desert-SOHC
  • It's old
« Reply #21022 on: February 07, 2016, 02:01:53 pm »
Broke it!
Went out to do a nice ride through wine country...clutch stopped working 15 miles from the house. Had AAA come to the rescue and get her back home. The cable was iffy when I got it, will order a new one tomorrow and start taking her apart.  :(
11 Ranger S/C 2wd
« Reply #21023 on: February 07, 2016, 02:10:25 pm »
Broke it!
Must be more than clutch cable?
No problem to drive without cluch as long it is not sliding and maybe too much city driving with redlights, green lights OK :). Elecric starter with gear in, change gear when release throttle just when the gearbox is unloaded between acc to dec.
« Reply #21024 on: February 07, 2016, 02:24:01 pm »
Got my ass out from my  sofa and TV!
Started with the engine, got carbs head and cyl off.  Bores OK, pistons and rings too.
Measured all 4 bores with bore micrometer and they have same diam and rather straight. Measured 4 points in each bore, bottom, lower end before under the rings, middle and top.  Mostly 65.25mm.
Cyl on table with last year oily cam beside next yeras cam. old RC295 copy and new DP315.
