Author Topic: What did you do to your bike today ?  (Read 3161721 times)
0 Members and 8 Guests are viewing this topic.
« Reply #21050 on: February 10, 2016, 03:02:38 pm »
Sounds great Jerry.... ;)
« Reply #21051 on: February 10, 2016, 03:05:50 pm »
1000 APE cc's of ground shaking POWER!  ;D
Thanks to Big Jay for having the kit made and doing the cylinders and for having the Crower rods made up for us.
Muffler?? We don't need no steenkin muffler.  ;)
1000cc APE, DP/RC315 cam, 33.5mm intakes with freshing up by Mike Rieck, Crower rods, must be more #$%* in it too..
« Last Edit: February 10, 2016, 03:07:46 pm by Jerry Rxman Griffin aka MuthaF'er »
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #21052 on: February 10, 2016, 03:17:16 pm »
Gee thanks, Jerry.... I just wet my pants.
Well done!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline kmb69
« Reply #21053 on: February 10, 2016, 03:20:04 pm »
Sounds real good!
I would suggest that maybe your kick starter recoil spring might not be installed correctly since the kick starter appears to be doing the Watusi ???
« Reply #21054 on: February 10, 2016, 03:31:06 pm »
Thanks LeRoy. We know how to fix that damn spring, huh! Take off the kicker  ;) I'm not going in unless I have to.
« Reply #21055 on: February 10, 2016, 03:41:06 pm »
Sounds real good!
 ;D ;D
« Reply #21056 on: February 10, 2016, 04:05:17 pm »
Well done Jerry, let us know how it goes once you get a chain on it, if the carbs are going to be a problem, it'll show up under load. Cheers, Terry. ;D
Offline BPellerine
« Reply #21057 on: February 10, 2016, 04:54:48 pm »
really nice jerry,good work!billp
1978 CB 750K ard and webers
another anfob
« Reply #21058 on: February 10, 2016, 05:10:03 pm »
Sounds great Jerry! Makes me want to pull my muffler, just to hear it.   :D
At least off idle, it sounds crisp.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #21059 on: February 10, 2016, 07:17:15 pm »
OK Wilbur, you shamed me into this!
Hot damn! Sounds great!  8)
You've got plenty of time to be ready for Valdosta!  :o  ;)  ;D
Definitely sounds better than just uttering "vroom" noises!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline edwardmorris
  • Youngish
« Reply #21060 on: February 10, 2016, 08:29:23 pm »
I had to wait till I got home to play the vid with sound, very very nice! Congratulations Jerry!
Offline mrbreeze
  • Not your average
« Reply #21061 on: February 10, 2016, 09:33:38 pm »
That sounded great for a first start Jerry. Settled in to an acceptable idle. I've always had to fiddle with things on mine to get a good idle on first go. I didn't realize you had 2 F's. I thought you just had one with 3 different colored gas tanks!!
MEMBER # 257
« Reply #21062 on: February 10, 2016, 10:23:52 pm »
Sounds very good! Which cam?
1000cc sounds tempting. I have rods for it..... sleeves have 74.5mm OD into the case? Case bore is 75mm?
First step is tp prepare the case so a BIG bore cyl can be fitted when found.
« Last Edit: February 11, 2016, 10:36:00 am by PeWe »
« Reply #21063 on: February 10, 2016, 10:32:54 pm »
Fred, this one came from all the late night EBay ramblings of a unhappily married father and his computer escape  ;D ;)  I began collecting parts after I scored the unobtainable (at the time) big bore 900 Henry Abe kit one late night session. Told myself I always wanted to do it up right just one time after all those years with the original. It snowballed from there. 5+ years. 9 countries. NOS, discontinued, bargains, etc. I picked everything I could from Honda. $$, $$, mas dinero. When it slowed to a trickle I began the journey. As a matter of fact I have 3 MORE nos parts parts to install on the original during the next week. I have shelves with a box for EVERY page of the parts manual in the basement. After the divorce I decided that a change in life is long overdue. The basement has never been finished and that is becoming a good investment in equity now. The new parts slowly turned into used parts into the boxes as I began the restomod and I needed to do something with all of them. Most were very useable just slightly used after 40 years. I picked a titled frame and engine. This is what you now see  :) If you want I can install the blue or candy presto red body if we get boring but that presto stuff is sacrilege to the 75!!
Thanks to all for the nice comments.
« Reply #21064 on: February 10, 2016, 10:39:04 pm »
1000cc sounds attempting. I have rods for it..... sleeves have 74.5mm OD into the case? Case bore is 75mm?
First step is to prepare the case so a BIG bore cyl can be fitted when found.
Same cam I believe you are experimenting with, DP315  ;D  I did not have this crank cut but I did install a RC lightened rotor to help make up the difference. It has the Crower rods I got Jay to have a run made of as well as his 1000 kit. He did the cylinder work and opening the case half. Heavy rods but really sweet. Stage III head. Going for a torque street monster theme here as compared to the other bike with the stage IV head, 900, Carrillos, 125-75, and lightened crank with stock rotor.
Just wish I knew WTF I am doing  ;) ;) ;D
« Reply #21065 on: February 11, 2016, 01:44:02 am »
I hoped you used the DP315 since I had vague memories about your modifications and RC/DP315 cam.
125-75 will give more hp than DP315?
- Do you know the diameter of the case bore to fit the 1000cc kit?
I look forward to mount mine since the idle sounds good when hearing your video. APE ultra crank might affect the idle. I suppose that carbs and ignition must be perfectly set with lighter crank.
I'm still taking things apart. Drained oil yesterday. Oil pump with new gaskets got new countersunk bolts with allen heads.
Will remove clutch basket after work so the remaining engine will be easier to pull out from frame. Head, cyl and pistons are removed.
About Honda parts and upgrades to a CB750... I have got bitten by that nice bug too!
Before buying parts when needed, now buy parts to have spares home and not waste time waiting for parts. Buy NOS while still available. I should have bought mored Tsubaki HD cam chains a few years ago wheil still sold everywhere for $40US.
I got a NOS Front fender from David Silver a few days ago when the price was right, fender on bike is old and from a K2, nuts instead of rivited.
Now looking for rear fender. My K6 has not the US style of rear lamp, it's the K0-K1 version. Closest Rear fender is K1.
I have an old cylinder with tapered sleeves, 67.5mm bore that are scratched, sleeves must be replaced. Cylinder is an old version not made for the  8 large o-rings for oil transport. Oil leak will happen easier,right? New sleeves and 67mm pistons can be something for future or finding a 1000cc cylinder with freash bores + pistons (that need case bore).  I have a working 836 setup and the $$$ are flowing as it is...
But, I know myself...I will soon think about 1000cc most of the time, when going to sleep and when wake up... I have to get it to get  piece in my mind. :)
« Last Edit: February 11, 2016, 01:46:47 am by PeWe »
« Reply #21066 on: February 11, 2016, 02:29:42 am »
Well CB750 parts are getting way harder to find, and awfully expensive. Long gone are the days where you could buy a rideable CB750 for under a dollar a cc. Anyway, when I was scanning Gumtree (Craigslist) I found a guy selling a couple of CB750 engines.
The seller is a very interesting guy, he has around 80 bikes, but most are British, with a few Jap bikes that he's picked up along the way. He's pretty much retired, but invited me over to his shop, which is full of Classic Aussie Brit and American cars, and lots of (mostly British) bikes. It's always a good sign when you see that his "Daily Driver" is a very rare 1961 Jag E Type convertible, that was a race car back in the day:
Then there was just mechanical eye candy for as far as the eye could see:
But of course I didn't come here to admire Peter's collection, I needed more CB750 parts:
There was a complete F2 engine that had been restored mechanically, in anticipation of going into a Seeley, but the owner found a hotrod K engine instead, and a complete, "never been apart" F engine that had powered the Seeley for the previous 40 years. No busted fins or grazed cases, and I think I'll shove it in my K1 and just ride it for awhile. Not sure about what to do with the F2 engine, but parts are always nice to have..........
I know Carpy (Crappy) lived in Melbourne for a few years, I didn't know that he'd spent time in Canberra:
No busted fins, clean as a whistle, with re-seated valves and surface ground for a nice seal:
Sadly bargains are hard to find nowadays, it wasn't cheap, but it was good, so I'm still happy! Cheers, Terry. ;D
« Reply #21067 on: February 11, 2016, 03:23:38 am »
It might be the vintage racers that vacuum clean the market of cheap 750 stuff?
It has changed here too. A few years ago a complete engine for about $300US (In need of repair). A CB750 K1-K6 in rather good shape around $2000-3000US.
F1 and F2 can still be found in veru good original condition for around $3000US- K1-K6 double as minimum
Offline maduncle
  • Don't confuse me with a
« Reply #21068 on: February 12, 2016, 01:55:19 am »
Nice work Terry, always good to see parts slowly accruing in the hand of enthusiasts.
CB750K2 (only slightly modified)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21069 on: February 12, 2016, 06:01:36 am »
Drove the lower race off the triple tree, getting prepped to re-paint where the brake fluid ate it away. Doing the same on the upper.
Fork bits should arrive today, then I can assemble the forks tonight!
--Evan
1975 CB750K "Rhonda"
« Reply #21070 on: February 12, 2016, 12:34:15 pm »
Pewe,
I do not know the case bore diameter. I just sent them to Big Jay and let him do his thing. He plugged the oil return passages with aluminum?? inserts like the older blocks are and do not have the dowels or o-rings now. He filled in the spaces in the block between 1 & 2 and 3 & 4 with epoxy too.
Offline Davez134
« Reply #21071 on: February 12, 2016, 01:38:25 pm »
Put on an oil pressure gauge. Seemed like the oil was wet sumping into the motor a bit, and I saw my light flicker on quickly while at a stop. All good according to gauge though. 65ish psi while riding and 16ish at idle fully warmed. Will drop occasionally to about 12
« Last Edit: February 12, 2016, 02:05:10 pm by Davez134 »
Offline mrbreeze
  • Not your average
« Reply #21072 on: February 12, 2016, 06:45:23 pm »
Terry, that looks like a pretty good haul of parts and on your side of the pond too! I take parts for granted more than you because they are plentiful here in the states. I couldn't afford to have stuff shipped from other countries although I did get a small package from Yamiya for like $10.50. I think its the worst between here in the states and Canada though for expensive shipping.
MEMBER # 257
« Reply #21073 on: February 13, 2016, 02:15:19 am »
Thanks Guys, yeah I know what you're saying Fred, most of the 500,000 CB750's built were sold in the US, and while there were plenty here once upon a time, good used bikes and parts are going for silly prices now.
Anyway, having a bad back I was dreading the idea of pulling the engines out on my own. I can lift a complete CB750 engine on my own, but I'm usually sore for a day or two after, so I decided to work smarter, not harder.
I scored a "patient lifter" a couple of years ago that was being thrown out because it was missing some lifting stuff and the batteries were clagged, so I put some new batteries in it and re-purposed it as a mobile bike/engine lifter. I ran some rope through the engine mounting bolts and tied it off in a makeshift harness, and just lifted each engine out, rolled them down to the garage. Simples......... ;D
Offline hotdog
« Reply #21074 on: February 13, 2016, 02:17:26 am »
Nice haul Terry
Sent from my HTC_M9u using Tapatalk
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
