Author Topic: What did you do to your bike today ?  (Read 3161506 times)
Biffer and 22 Guests are viewing this topic.
Offline kghost
« Reply #21125 on: February 17, 2016, 04:28:18 am »
I've actually never seen Retro Rocket on a bike......you ever gonna finish and ride one?
Well seeings though I've only ever seen you about 4, maybe 5 times in my life, that really doesn't surprise me, I've never seen you fly a plane either.. You do your thing and i'll do mine... 8)  You got any CB900 F2c parts {boomerang comstars} ..? I need a speedo drive....
I may have very well have flown over your house...so perhaps you have seen me.
By all means do your own thing....didn't really answer the question though did ya?
Stranger in a strange land
« Reply #21126 on: February 17, 2016, 11:43:23 am »
Opened the cases after work. ("After work" is usually beers, food and women....but not for me)
I got a reminder to NEVER use Hondabond as extra sealer around the oil seals. I'll use athin layer of Hylomar blue next time around theese seals as before.
REAL PITA to remove the upper case when the crank followed and stucked with prim chains. Crank oil seal at ign side and final outgoing axis, crank was stucked in upper case due to the glued by hondabond oil seals.
I had to use brutal force to hammer down the crank, a soft distance between the opened cases made it possible
« Reply #21127 on: February 17, 2016, 12:17:04 pm »
Ha ha, looking at your pic reminded me that I've got a great workbench under piles of crap that I've never cleaned off in years PeWe, I really must get my garage in some kind of order, I'm picking up my latest CB750 purchase today, and my work bench is big enough to lay the whole bike out on, if I could just expend the energy to clean it up first............ ;D
« Reply #21128 on: February 17, 2016, 01:30:33 pm »
Same here....the workbench was full of junk 2 weeks ago. I removed all stuff so I could do the oil pump restore. It's too easy that the bench and other work areas fills with parts, garbage, tools etc.
« Reply #21129 on: February 17, 2016, 01:41:08 pm »
Nope, because it's no one elses business.... ;D
Offline hotdog
« Reply #21130 on: February 17, 2016, 02:51:29 pm »
Not a cb sohc, but another ongoing project...
It is a sohc....does that help?
Sent from my HTC_M9u using Tapatalk
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline Desert-SOHC
  • It's old
« Reply #21131 on: February 17, 2016, 05:30:36 pm »
Figured out why my neutral light was flickering and then died, LED bulb gave up.  Got some decent used gaskets for the stock fork ears, think I'll do those in the morning.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #21132 on: February 18, 2016, 12:16:06 am »
Yeah yeah, good work mate, nice tools (looks way too clean for my liking though......) but more importantly, what's that bike with the STP sticker on the tank? Post some pics of that sucker, will you? Cheers, Terry. ;D
« Reply #21133 on: February 18, 2016, 03:59:12 am »
How do you like those Neway cutters?
Offline kghost
« Reply #21134 on: February 18, 2016, 04:46:21 am »
Maybe you just need some poking, prodding and encouragement......
After all isn't that what community is all about?
Come on....you ever gonna finish?
The Panama Canal only took 10 yrs......
Maybe you're going for the Sydney Opera house....it only took 14 yrs....
Offline Mantree
« Reply #21135 on: February 18, 2016, 07:56:16 am »
New petcock fuel filter and lines
Sent from my SM-G900V using Tapatalk
« Reply #21136 on: February 18, 2016, 08:45:24 am »
hotdog those things are the most robust engines. Tree trunks for valve stems and studs. They too get hammered though!
« Reply #21137 on: February 18, 2016, 12:05:01 pm »
I need no prodding mate, i'm not rich and its all about priorities. You should drop Mick in Darwin a few words of encouragement, he's been going longer on his silver 750 than me, and he started with a full bike... ;D If you really are interested, I'm currently waiting on some spacers I've ordered so I can finish fitting the wheels  to the 41mm forks I'm using, picked up the axle and bearings last week. You didn't answer my question either, Any Idea where I can get me hands on a speedo drive for a late model 900 boldor or cb1100f, must be for an 18 inch front wheel  ..?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #21138 on: February 18, 2016, 03:49:23 pm »
Draped it with some swag that came in the mail today...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline hotdog
« Reply #21139 on: February 18, 2016, 04:22:42 pm »
Here you go uncle tez, the bastardized child...it's/was an xs650 I built around 5 years ago...
Not for the purists this one. However they might get some comfort knowing the entire bike was scrap worthy prior to this.
Rebuilt engine to standard specs ( not like the other one) but has been rephased to a 277° firing interval instead of the standard 360°, sounds ducati-ish.
Hall effect ignition and vm34 carbs and custom 2-1 pipe. Surprising how fast this little #$%* is....
Offline hotdog
« Reply #21140 on: February 18, 2016, 04:29:02 pm »
I find them excellent, easy to use and do a great job - if you take your time.
Used to do lots of evo Harley heads with them with great success.
You need to make sure the pilots are a good fit for concentric seats, new pilots can be expensive I just spin my own in the lathe.
Using them infrequently at the moment but will be advertising for work soon at my modest shop, depending of levels of work I get, I may upgrade to a single blade cutter system for my mill.
Regards.
Offline hotdog
« Reply #21141 on: February 18, 2016, 04:31:08 pm »
Yes they are over-engineered, Yamaha's first 4st.
This one's hopped up a bit....
« Last Edit: February 18, 2016, 06:08:40 pm by hotdog »
Offline Desert-SOHC
  • It's old
« Reply #21142 on: February 18, 2016, 06:43:37 pm »
Put on the stock fork ears, badge, and changed the fork oil to Belray 10w.
11 Ranger S/C 2wd
Offline kghost
« Reply #21143 on: February 18, 2016, 07:00:51 pm »
Since I work at a bike shop/wrecker 2 days a week I should probably look huh?
I need some pictures for encouragement......
Offline Kenzo
« Reply #21144 on: February 18, 2016, 09:07:18 pm »
Ditched the chrome shock covers. Shocks felt decent...fast compression, rebound dampened well. Only 14K on the 40 years old shocks. :)
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #21145 on: February 18, 2016, 09:24:59 pm »
If you could have a look it would be much appreciated, I want to run a stock speedo and the rolladoor speedo drive  is a 2240:60, just like the old Honda. I'll get the son to take some pics, I don't have a camera. {old phone}..
« Reply #21146 on: February 19, 2016, 04:21:05 am »
Ha ha, that is sweet! One bike I've never owned, but I've ridden a couple of Yammy 650's, and they were a great bike, God, I remember them when they were new! I love that bike mate, if you ever get sick of it, send it to me! Cheers, Terry. ;D
Offline mick7504
« Reply #21147 on: February 19, 2016, 06:48:07 am »
I took a picture  of my crank and Carrillos.
Does that count.  ;D
If I was you
I'd be worried about me.
Wobbly
« Reply #21148 on: February 19, 2016, 07:14:41 am »
Attn.: retro rocket
If you find anything on this side of the pond, I can get it for you, mailing it to you with domestic USPS mail.
http://www.ebay.de/sch/i.html?_from=R40&_trksid=p2055119.m570.l1313.TR0.TRC0.H0.Xtachoantrieb+cb900+honda.TRS0&_nkw=tachoantrieb+cb900+honda&_sacat=0
« Reply #21149 on: February 19, 2016, 11:49:17 am »
Does that count.  ;D
Yes, thats a good start! It has the stamped detail too? Mine is on the way in....
« Last Edit: February 19, 2016, 11:54:51 am by PeWe »
