Author Topic: What did you do to your bike today ?  (Read 3160795 times)
0 Members and 8 Guests are viewing this topic.
Offline Desert-SOHC
  • It's old
« Reply #21425 on: March 29, 2016, 07:06:30 pm »
Rode it...in the worst cross winds that I've been in awhile!
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Flatlander80
« Reply #21426 on: March 29, 2016, 07:07:58 pm »
Swapped out my headlight for one with an H4 replaceable bulb, removed chain, rear wheel and sprockets (going +1 on the front and -1 on the rear).
« Reply #21427 on: March 29, 2016, 07:44:01 pm »
Slapped a new AGM battery in the XL250s and rode it up for its annual inspection.
Then gave the state more money for fresh tags.
Do you know if you register as an antique, an annual inspection is not required?
Don't ya know if you register as an antique it's only $60 and good for five years?!
It's a no-brainer.
Online CycleRanger
  • No comment about being an
« Reply #21428 on: March 29, 2016, 07:47:23 pm »
It's a no-brainer.
Yes, I heard you the first time.  ;)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #21429 on: March 29, 2016, 08:55:51 pm »
Which headlight housing/bulb is this? Looks good!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Kenzo
« Reply #21430 on: March 29, 2016, 09:32:06 pm »
It's a no-brainer.
Well...I've read the regulations(and I haven't stayed at A Holiday Inn in years) but what probably thousands of Texans do is not within the intent of the law. That being said I'll be registering my 550 as an antique when the current registration expires. :)
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #21431 on: March 29, 2016, 09:33:53 pm »
It's a no-brainer.
Smart man
« Reply #21432 on: March 30, 2016, 02:38:21 am »
It's a no-brainer.
It's OK mate, I think you're a smart man too, Steve can be so mean some times.......... ;D
Offline hotdog
« Reply #21433 on: March 30, 2016, 04:04:37 am »
Chopped a Cam in half and joined it back together.....
Sent from my HTC_M9u using Tapatalk
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
« Reply #21434 on: March 30, 2016, 04:11:02 am »
OK, I bite :)
Why?
Offline hotdog
« Reply #21435 on: March 30, 2016, 04:19:37 am »
Yamaha xs650 camshaft, rephased to 277° along with the crankshaft.
Gets rid of the 360° firing order with both pistons rising and falling together, now when one piston is mid stroke the other is either tdc/bdc...much smoother. Similar configuration as nearly all parallel twins built today with their 270° cranks.
Sounds ducati-ish....
« Reply #21436 on: March 30, 2016, 04:21:06 am »
Got it  ;)
Nice machine btw.
Online CycleRanger
« Reply #21437 on: March 30, 2016, 06:12:17 am »
Very ambitious! Nice to have the tools and skill to do that.
Online CycleRanger
« Reply #21438 on: March 30, 2016, 06:22:12 am »
It's a no-brainer.
If he didn't care he wouldn't hit me so hard... :o
And, to be fair, if I'm only going to ride the XL250s ~85 miles a year I really should register it as an antique.
Maybe next year.
Or sell it.
« Reply #21439 on: March 30, 2016, 06:45:11 am »
  WAAAAAAY over my pay grade
Offline jamesbekman
« Reply #21440 on: March 30, 2016, 07:32:28 am »
Got back to work.
Originally looked kind of like the last picture.  Soda blasted it a while ago then just a lot of sanding then buff
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #21441 on: March 30, 2016, 03:25:02 pm »
If you cut/join your factory cam 180* out, you can get 1-4 to fire TOGETHER as well as 2-3.  Will give you that POTATO-POTATO-POTATO Harley sound ;D
It will also climb sand hills (with proper tyres) like no ones business.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #21442 on: March 31, 2016, 01:48:02 am »
Is that 3 potatoes or 4? Will it make it miss on one cylinder? I'm confused, cos I want to be the first kid on my block with a 4 cylinder Harley! ;D
Offline hotdog
« Reply #21443 on: March 31, 2016, 02:30:45 am »
The Cam I've cut is from a Yamaha xs650 parallel twin, not a sohc /4
Changing it from a 360° to a 277° crank, enabling smoother running.
Most parallel twins made today run with this configuration.
Sorry for any confusion....
« Reply #21444 on: March 31, 2016, 02:18:38 pm »
Replaced the front wheel bearings and 2 discs on
« Reply #21445 on: March 31, 2016, 02:42:23 pm »
It's a "Big Bang" cam configuration. Basically the paired cylinders fire on the same spark. So instead of the nice smooth bang-bang-bang-bang we all know & love, you get BANG-BANG-rest-rest.  If you wana try it before you buy it, Terry, re-time one cam on ur Mighty Wang by 180* and you'll have an 800 pound hill climber!
Sure.
Is it hard?
Offline Seeker0131
  • Jack of all, Master of none
  • Time with a motorcycle is never "wasted".
« Reply #21446 on: March 31, 2016, 02:52:25 pm »
Wrote a post: Re-Rebuilding of 1972 CB 500 K1
Looking for direction/advice on options.
1972 Honda CB 500 K1
1952 Zundapp KS 601
« Reply #21447 on: March 31, 2016, 03:40:28 pm »
It's Biker's Choice housing and an H4 bulb. Got it online from http://www.canadasmotorcycle.ca. Cost was about $55 CDN. It's a lot lighter than the sealed beam it replaced... Guess I'll see how it holds up over a season.
« Reply #21448 on: March 31, 2016, 04:51:12 pm »
Fcuk it, now I want a "Big Bang cam"! Hey hotty, can you make me one? ;D
« Reply #21449 on: March 31, 2016, 06:00:31 pm »
It's been discussed before. You are amazingly consistent, Terry!
http://forums.sohc4.net/index.php?topic=63952.0
Sure.
Is it hard?
