Author Topic: What did you do to your bike today ?  (Read 3283055 times)
« Reply #21600 on: April 24, 2016, 05:11:09 PM »
Well on Saturday April 23rd  I took my CB750 for it's first ride on the street.  After about 10 months, I got to ride it!  ;D  During those 10 months, I changed out the fenders, the exhaust, tires, seat, horn, added blinkers, had the carbs off several times, and had the oil lines rebuilt.  Slow but steady.   Still have some tuning to do, but it ran pretty good.  I'm a happy camper.
Tom
Congrats Tom, looks good, nice job.  Snap some pics in the sun so we can see that paint shine!
Stev-o,
Thanks!  About the time I took a few pics, I was enjoying a beer in the shade with my Honda, feeling kind of proud that another SOHC has been brought back to life.  Here in "sunny" Tucson, shade is appreciated.  I'll get some pics in the sun and post them.
Tom
I can understand that but thankfully it hasnt hit 90 here in TX yet.
Offline CycleRanger
  • No comment about being an
« Reply #21601 on: April 24, 2016, 06:11:03 PM »
Spent a considerable amount of time today cursing Yamabond and whoever felt it was necessary to glue on every damn gasket on the XS650.  >:(
Spent the rest of time slathering on paint stripper and scraping with a razor blade.
I mean seriously, whoever worked on this bike must have mistaken it for a old Brit twin.
Offline BPellerine
« Reply #21602 on: April 24, 2016, 06:46:55 PM »
Last grind session on the upper case so the 70mm sleeves fit with clearance all around. 67.5mm bores, 901,75cc. (Often called 915cc kit)
My K6 case must have extra meet since the 70mm sleeves are sold to fit withput case bore.
Good reason for extra cleaning of the case. Blow it clean with air removed most of the alu dust but much left outside and inside, channels too. Cleaned with dish washer powder and used a big syringe to fluch all channels clean plus the small debris collecting compartments in front of the bores inside.
Then another rincse session with clean waater. Blowed it dry in channels and outside with my compressor.
Upper case will mate with lower case tomorrow, seal and torque it.
pewe did you get a new piston kit and sleeves?bill
1978 CB 750K ard and webers
another anfob
Offline krusty
« Reply #21603 on: April 24, 2016, 07:37:09 PM »
Finally got around to fitting Frank's frame kit to my CB750G. Made a VJMC shed day out of it which was well attended.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Magpie
« Reply #21604 on: April 24, 2016, 10:27:02 PM »
Before, during and after.
« Reply #21605 on: April 25, 2016, 05:05:50 AM »
 You gonna put some huge knee dents in there Cliff and maybe airbrush a Unicorn ;D ;D
Offline Magpie
« Reply #21606 on: April 25, 2016, 07:25:26 AM »
Don't give me ideas Eric. This bike has fought me on along the way - maybe I need to teach it a lesson!  :D
Offline theslayedsaint
« Reply #21607 on: April 25, 2016, 11:44:14 AM »
Finished up my seat... Turned out ok.  :-\
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #21608 on: April 25, 2016, 11:52:26 AM »
"That is one fine piece of ash!" Or... whatever it is.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=oeap1mqpvdtsd8lqo19u8oujf6&/topic,60973.0.html
« Reply #21609 on: April 25, 2016, 12:10:05 PM »
nov do the fuel tank of Wood..use a liner to seal inside
i hate all this v-w.... vords
« Reply #21610 on: April 25, 2016, 12:27:11 PM »
It's cedar planks molded together. And gas tank would be cool... :-\
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline strynboen
« Reply #21611 on: April 25, 2016, 12:35:02 PM »
just made a inner steel kostum tank..and make a vooden look koffin..it vill look great
« Last Edit: April 25, 2016, 12:40:40 PM by strynboen »
« Reply #21612 on: April 25, 2016, 12:37:45 PM »
just made a inner steel kostum tank..and make a vooden look kofin..it vill look great
I saw a fit-over like this before.  Cool design.
Offline MoMo
  • Ride like you're invisible
« Reply #21613 on: April 25, 2016, 12:50:39 PM »
here you go ::)
« Reply #21614 on: April 25, 2016, 01:13:21 PM »
here you go ::)
Needs rearsets, clubman bars, and a checkerboard stripe ::)
« Reply #21615 on: April 25, 2016, 02:06:40 PM »
Offline MoMo
« Reply #21616 on: April 25, 2016, 02:51:25 PM »
here you go ::)
Larry's got wood!
I've been told I have a wooden head(upper that is).
Offline Davez134
« Reply #21617 on: April 26, 2016, 08:29:32 PM »
I'm finally tired of oil all over my rim and leaking down kickstand. Started replacing deal
Got it out in 10 minutes
Going to install tomorrow
Offline WV_750
« Reply #21618 on: April 26, 2016, 09:32:47 PM »
Installed new carb boots and velocity stacks. Airbox was more of a PITA than I thought it would be with new rubber until I figured out the carbs needed pushed down a bit to get the velocity stacks to seat properly. Oh, and I bought a 919  ;D
« Last Edit: April 26, 2016, 09:35:43 PM by WV_750 »
73 CB750 K3
76 CT90
78 CT90
07 CB900F (919 Hornet)
« Reply #21619 on: April 27, 2016, 02:37:45 AM »
I'll be interested to see how you go with that Dave, I don't think I've ever seen one installed successfully without splitting the cases? Cheers, Terry. ;D
« Reply #21620 on: April 27, 2016, 04:31:49 AM »
^^^  When Dorothy was new to me, the seal came out on its own.  I tapped it back in and it lasted 25 000 miles no problem.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21621 on: April 27, 2016, 05:10:48 AM »
Wire-wheel'd off all the old paint from my exhaust, and then sprayed with several coats of self-priming BBQ paint. I'll be interested to see how this turns out. ;D
--Evan
1975 CB750K "Rhonda"
Offline jonda500
« Reply #21622 on: April 27, 2016, 05:48:19 AM »
As well as swapping out a spark plug cap, I also fixed the 'can't select neutral when hot' problem my 500 has always had - turns out it was the #$%*ty old aftermarket clutch cable - I changed it today because a process of elimination with fixing my stiff clutch lever - I hoped changing it would fix the hard to pull lever - last link in the clutch release chain - but I had learned to live with the difficulty getting neutral when hot!
:) John
A starter clutch thread:
Offline Davez134
« Reply #21623 on: April 27, 2016, 09:48:08 AM »
I think it went well. Will have to check for leaks after a longer ride.
http://forums.sohc4.net/index.php/topic,139768.msg1800703.html#msg1800703
« Reply #21624 on: April 27, 2016, 01:24:41 PM »
Did that once and it worked fine and was easy
