Author Topic: What did you do to your bike today ?  (Read 3275782 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21850 on: May 31, 2016, 11:28:58 AM »
Something special came yesterday! Going to install tonight.
Creative locations for mounting without disassembling too much are welcome. I'm thinking between the battery box and rear fender, stuck to the fender with some industrial velcro.
that is exactly where I put mine
Please educate me on this transistor gadget!
http://sohc4shop.com/catalog/product_info.php?manufacturers_id=12&products_id=32&osCsid=8d81514349086b4d8b31ca72c3c1e5bb
HondaMan makes them!
--Evan
1975 CB750K "Rhonda"
« Reply #21851 on: May 31, 2016, 11:49:36 AM »
+1
Had one on my 350F, and one is on my 750 8)
Easy to install, and switch back to points (if needed)  Just seconds really.
The Green wire, which grounds at the points plate....i just added an in-line quick disconnect with the added bullet connectors so the points cover doesnt have to be removed.  Its all hidden under the tank.
djwillard18
« Reply #21852 on: May 31, 2016, 04:33:03 PM »
Nice! Did you brush that on?
And today I rode the 750K5 like I owned it.  :)
Do you own it?
I did use a brush and thinned model paint. One more coat and then the white.
Offline CycleRanger
  • No comment about being an
« Reply #21853 on: May 31, 2016, 04:52:19 PM »
Do you own it?
Own it, rebuilt it, love it. :D
Model paint. That was first attempt.
Perhaps my mistake was giving them to a buddy who is very skilled at model building but apparently not very skilled at painting tank badges.
His paint job looked terrible so I stripped them back.
djwillard18
« Reply #21854 on: May 31, 2016, 05:06:55 PM »
Do you own it?
This is my second attempt from scratch. We'll see. Probably clear coat after finished with the white.
My CB750 K4 was in pretty good shape, but PO was starting to café it. Not enough budget to fully restore to orig, but close facsimile is my goal.
« Reply #21855 on: May 31, 2016, 09:12:23 PM »
No Shirt, No Shoes, No DICE!
Offline CycleRanger
« Reply #21856 on: May 31, 2016, 09:38:49 PM »
Why don't you get a job Spicoli!  ::)
Offline 72Bramma
« Reply #21857 on: May 31, 2016, 11:07:00 PM »
Final assembly and finishing touches.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #21858 on: May 31, 2016, 11:23:18 PM »
Ah, Gratsi
Seems neat, but I'm seriously considering a PAMCO.  If only for the reliable timing advance/decel retard
« Reply #21859 on: May 31, 2016, 11:41:36 PM »
Ah, Gratsi
[/quote]
Geez, don't call him that mate, he was only trying to help? ;D
« Reply #21860 on: May 31, 2016, 11:43:18 PM »
On the table? ;D
Offline maduncle
  • Don't confuse me with a
« Reply #21861 on: June 01, 2016, 04:28:45 AM »
Ah, Gratsi
[/quote]
Well - if I can wire a PAMCO up and get it working right "FIRST TIME" they must be easy to install.
CB750K2 (only slightly modified)
« Reply #21862 on: June 01, 2016, 09:30:26 AM »
On the table? ;D
terry, you keep goofin around and you aint gonna like where I put it..all joking aside, you are missing out if you dont run the hondaman ignition
Offline evanphi
  • Apparently I'm an
« Reply #21863 on: June 01, 2016, 10:17:52 AM »
Woo. Installed it last night.
For those interested in the HondaMan Ignition and are running an electronic tach, tap your tach lead to the ORANGE wire.
I stuck it behind the battery box to the plastic fender with some industrial velcro. I unhooked my condensers but left them attached under the points plate just in case I ever need to revert. I also need to adjust the timing now. My previous issues with 2/3 being off might have been due to the condensers. I was only able to time correctly by closing the gap to 0.011". Anywho. It runs and revs just fine, but I need to recheck things, and that will happen on Monday!
--Evan
  • Holy Cow! I'm a
« Reply #21864 on: June 01, 2016, 10:40:38 AM »
Ah, Gratsi
[/quote]
 Wwwhhhhaaaaattt.  ::)
Decel Retard?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #21865 on: June 01, 2016, 02:19:40 PM »
Ordered a key blank and clutch cable from David Silver.
Offline Old Scrambler
« Reply #21866 on: June 01, 2016, 07:10:14 PM »
I took my CB750 K3 for a ride ;D ;D ;D ;D ;D ;D ;D ;D...........after loosing ignition on #1 back in September of 2015. I pulled the head, re-sealed all of the pucks and threads, heli-coiled a few holes for the tower-fasteners, new head gasket and cover-gasket, checked all of the rocker-pins and rockers for wear (replaced 2 rockers on exhaust) and SWITCHED the stock cam (after 72,000 miles) for an F-2 unit.
When everything was buttoned up, I rolled the bike off of the lift and touched the starter. It fired immediately ;D ;D ;D ;D ;D ;D ;D. One carb was acting up for a few miles but then all was good. When I got back to my garage I checked for leaks and found NONE ;D ;D ;D ;D ;D ;D  The goal was to not only get the motor running again, but to cure some minor oil leaks and try to quiet a ticking sound that had developed a few thousand miles ago. So far.........so GOOD ;D ;D ;D ;D ;D ;D ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline MoMo
  • Ride like you're invisible
« Reply #21867 on: June 01, 2016, 07:37:10 PM »
^^^nothing like a rewarding end!!!  Larry
« Reply #21868 on: June 02, 2016, 03:31:21 AM »
Very good!  Did you put the F2 cam in original position or did you advance it?
quote author=Old Scrambler link=topic=61168.msg1812823#msg1812823 date=1464833414]
[/quote]
Offline maduncle
« Reply #21869 on: June 03, 2016, 04:22:14 AM »
Fixed a pin hole leak in a tank (hopefully).
Then spent some time trying to get oil pressure - in between reading advice on the SOHC4 forum on how to get oil pressure...
Offline CycleRanger
« Reply #21870 on: June 03, 2016, 07:13:37 AM »
Put some new shoes on the XS650 rims and greased the caliper.
« Reply #21871 on: June 03, 2016, 08:04:05 AM »
70..........cam in original position............it has a 'lope' to it at idle............but pulls very much like I remember a K0. In all stock form this original K3 would barely creep above the 100-mph mark on the clock...........now it gets there with more to go ;D ;D ;D ;D ;D ;D  Its not a kick-in-the-pants thing at 5000 rpm..........but the motor responds much better to a quick twist of the throttle. The bike looks stock and still has points.........only non OEM items are 1st-over pistons, a K&N filter, and 115-mains.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline TomsK8resto
« Reply #21872 on: June 03, 2016, 08:34:53 AM »
Ordered a new set of handle bars for my '78 750K bike.  The set that came on it were too tall, the super bike bars on it now are too short, so I ordered a set of '69-'71 750 replica bars from 4into1.  Hopefully they will be just right!
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline evanphi
  • Apparently I'm an
« Reply #21873 on: June 03, 2016, 11:04:14 AM »
I has my first ride with the new ignition module today.
WOW
what a difference. Power all through the revs is an understatement! Pulled right up to 130km/h in 3rd gear and could have kept going! But I was over the speed limit... Just a little bit... Before, I would hit a wall when the revs got above 7-8K.
Easiest cold kickstart in my life today too.
Thanks again, HondaMan. I will be praising this little box of magic any chance I get!
--Evan
Offline CycleRanger
« Reply #21874 on: June 03, 2016, 06:27:32 PM »
I got some test samples of these done today.
Thanks to everyone who responded to my photo request. :)
I will be in contact with you to send you a pair of these.
These stickers are "life size" full color on laminated UV-protected vinyl.
The image was rendered in 3D then outputted to 2D.
I'm going to make some larger ones too. Maybe 12".
I'm working on a 750 badge too. :)
I had these made up for a project but I might have a few extras for sale soon if anyone is interested.
« Last Edit: June 03, 2016, 07:21:09 PM by CycleRanger »
