Author Topic: What did you do to your bike today ?  (Read 3270140 times)
0 Members and 7 Guests are viewing this topic.
Online Old Scrambler
« Reply #21925 on: June 03, 2016, 08:04:05 AM »
70..........cam in original position............it has a 'lope' to it at idle............but pulls very much like I remember a K0. In all stock form this original K3 would barely creep above the 100-mph mark on the clock...........now it gets there with more to go ;D ;D ;D ;D ;D ;D  Its not a kick-in-the-pants thing at 5000 rpm..........but the motor responds much better to a quick twist of the throttle. The bike looks stock and still has points.........only non OEM items are 1st-over pistons, a K&N filter, and 115-mains.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline TomsK8resto
« Reply #21926 on: June 03, 2016, 08:34:53 AM »
Ordered a new set of handle bars for my '78 750K bike.  The set that came on it were too tall, the super bike bars on it now are too short, so I ordered a set of '69-'71 750 replica bars from 4into1.  Hopefully they will be just right!
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21927 on: June 03, 2016, 11:04:14 AM »
I has my first ride with the new ignition module today.
WOW
what a difference. Power all through the revs is an understatement! Pulled right up to 130km/h in 3rd gear and could have kept going! But I was over the speed limit... Just a little bit... Before, I would hit a wall when the revs got above 7-8K.
Easiest cold kickstart in my life today too.
Thanks again, HondaMan. I will be praising this little box of magic any chance I get!
--Evan
1975 CB750K "Rhonda"
Offline CycleRanger
  • No comment about being an
« Reply #21928 on: June 03, 2016, 06:27:32 PM »
I got some test samples of these done today.
Thanks to everyone who responded to my photo request. :)
I will be in contact with you to send you a pair of these.
These stickers are "life size" full color on laminated UV-protected vinyl.
The image was rendered in 3D then outputted to 2D.
I'm going to make some larger ones too. Maybe 12".
I'm working on a 750 badge too. :)
I had these made up for a project but I might have a few extras for sale soon if anyone is interested.
« Last Edit: June 03, 2016, 07:21:09 PM by CycleRanger »
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #21929 on: June 03, 2016, 06:34:58 PM »
I'm definitely interested! And probably in the 12 inchers. They look great, CR!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #21930 on: June 03, 2016, 07:43:59 PM »
Took her for a ride today
« Reply #21931 on: June 03, 2016, 11:49:40 PM »
Something special came yesterday! Going to install tonight.
Creative locations for mounting without disassembling too much are welcome. I'm thinking between the battery box and rear fender, stuck to the fender with some industrial velcro.
I had mine in the toolbox, but need of OEM tools made me to place it over the battery. I had a shorter 14Ah battery but changed to 11Ah model to ensure space for the box and extra relays as spares.
Edit: I have wrapped the module with vulc tape as vibr reducer and eventual battery post contact. I do not know how warm the module will become efter hours of driving and if the tape will cause high temp for the electronics.
One more thing: The green ground cable is very important. Mine was one piece from module to point plate. I cut the wire parallel to the yellow and blue plugs when I pulled the engine last winter. Easier to disconnect all 3 wires.
I did not crimp the plugs correctly so the green did not have contact. The ignition really worked bad then.
« Last Edit: June 04, 2016, 12:00:31 AM by PeWe »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #21932 on: June 04, 2016, 10:35:44 AM »
Installed the M bars I got last week, lubed the throttle cables and confirmed what I suspected, that in addition to all the other upgrades a PO did, he also installed an electronic ignition, although I am not familiar with this brand.
Now I need to install the Lucas style tail light and original rear turn signals and for David Silver to ship me my replacement clutch cable so I can replace it before I leave for Rockerbox on Friday.
Offline CycleRanger
« Reply #21933 on: June 04, 2016, 11:00:54 AM »
Martek 440 -old school solid state.  Instructions in this thread.
http://forums.sohc4.net/index.php?topic=50846.0
Offline Bankerdanny
« Reply #21934 on: June 04, 2016, 11:17:09 AM »
Thanks CR. I Googled it after my post and found instruction in a couple places and saved them to my computer. Seems to work just fine, bike fires right up. Just needed to confirm how to find TDC with it so I can tension my cam chain and check my valves.
« Reply #21935 on: June 04, 2016, 03:57:45 PM »
I like the M bars.  You going to leave the oil pressure gauge?
Offline b52bombardier1
« Reply #21936 on: June 04, 2016, 05:19:35 PM »
Finished the POR15 tank sealing process on my CB500. Now wait four days for the urethane to cure.
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline Bankerdanny
« Reply #21937 on: June 04, 2016, 06:05:25 PM »
For the time being. That's actually a different one that the one on the bike when I got it. I need to make a better mount
Offline joeyvans
  • Definitely not a
« Reply #21938 on: June 05, 2016, 06:21:47 PM »
Picked up a very incomplete '74 550 that has a free motor (which is a '75 - according to the model guide).... and some sweet bars!!!
Also grabbed a spare '76 550 stuck motor.... which is stamped 16 numbers earlier than my other '76 motor.
Pulled off the rocker box on the free motor and I thought things looked pretty decent. But then again... I have no idea what the hell I'm looking for.
« Last Edit: June 05, 2016, 06:37:48 PM by joeyvans »
1976 CB550 K2
Offline CycleRanger
« Reply #21939 on: June 05, 2016, 06:57:45 PM »
Still plugging away on my not-Honda.  :)
Most subsystems done, just slowed by details.
Offline Rocky2010
  • Live in Strayla
« Reply #21940 on: June 05, 2016, 07:39:41 PM »
They look great do you have any for a 350/4 & 500/4 also 750/4 would be great
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline NastyNip
  • oh snap
« Reply #21941 on: June 05, 2016, 07:47:55 PM »
Quick question:
For the carbs on my '74 CB550, is there a way I can adjust the needle clip position with the carbs on the bike?
I have everything buttoned down pretty well but am having some lack of power from idle to 1/3 throttle (idle screws are @ 1.5 turns out) so I thought it might be them, but I don't want to pull the carbs to get to them?
Cheers!
1974 CB550K
1978 CB550K
Offline joeyvans
  • Definitely not a
« Reply #21942 on: June 05, 2016, 07:51:52 PM »
Nasty.... It can be done. Takes about an hour if you get good at it. But keep in mind, you will need a vac sync after you get everything back together. Good luck and take it slow.
Have you verified your carb settings with plug chops?
1976 CB550 K2
« Reply #21943 on: June 06, 2016, 02:44:29 AM »
Thoe Marteks are fantastic mate, I'd rather one of them than any other EI on the market today. I fitted one to my Suzuki GS750 years ago, and I wound down the throttle to the point where it was idling quite happily at only 200 RPM. I installed another one on my GS1000, and the difference between it and the OEM EI were like night and day. I've been trying to find a pic I posted here years ago of it firing a plug, with Dyna coils it produced a huge blue spark. I must find another one for one of my CB750 projects. Good stuff. Cheers, Terry. ;D
Offline Bankerdanny
« Reply #21944 on: June 06, 2016, 07:21:22 AM »
Finally assembled and installed the new head for my 2007 Yamaha Vino 125 scooter flip project. I was able to get it to run briefly before I had to shut down for the evening.
The 2nd photo shows why I had 2 replace the head, 2 bent valves! The replacement head plus 2 valves and seals was abt $220
« Last Edit: June 06, 2016, 07:25:28 AM by Bankerdanny »
« Reply #21945 on: June 06, 2016, 08:15:39 AM »
 You still got that Harley Danny ?
Offline Bankerdanny
« Reply #21946 on: June 06, 2016, 08:34:33 AM »
Yep. Scooter goes first, then when it's gone I will figure out what I am going to do with the Harley. I still think I should get it running then sell it as a running project, but I don't know if I will have the time.
Offline 72Bramma
« Reply #21947 on: June 07, 2016, 05:01:43 AM »
Fired up the old girl today!
« Reply #21948 on: June 07, 2016, 05:11:55 AM »
I changed oil and break light switches on Red yesterday - and took the jeep this morning :(
Wife needs mulch for her gardening efforts; could carry much of that sihte on Red.
« Reply #21949 on: June 07, 2016, 09:11:47 AM »
Pipes getting a little patina already
