Author Topic: What did you do to your bike today ?  (Read 3965418 times)
0 Members and 53 Guests are viewing this topic.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #23300 on: January 12, 2017, 04:55:02 AM »
Started taking more things off Rhonda...
MAC exhaust is off. Going on soon is the Delkevic. Still need to make a reducer pipe for the cone engineering bit.
Carbs came off and 42 slows went in.
Old oil drained, new oil added.
Started slowly picking away at the rear wheel truing. Started by tightening everything so they ring. Closer to true already! Many were very loose.
I think my oil pressure switch is leaking. How do I get the hard old rubber cap off it? Heat gun?
Started taking apart my seat some more. Sprayed a coat of gloss black last night, then another this morning. Very rusty from some PO tipovers and leaky battery! Will spray underside tomorrow.
« Last Edit: January 12, 2017, 04:57:47 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
« Reply #23301 on: January 12, 2017, 06:13:25 AM »
Wow, I thought that Craftsman was good quality Eric? Lucky I didn't buy any! I'd wait until you have the engine installed, then run it up to temp, while spraying some liquid wrench etc into the screws, and that should un-stick 'em! Cheers, Terry. ;D
  With my luck Terry it probably won't run after all my farking around with it    :)
« Reply #23302 on: January 12, 2017, 07:17:01 AM »
 I'd wait until you have the engine installed, then run it up to temp...
Run it w/o exhaust?!  Or remove 341's from another bike and install em on this? Doubt he wants to do that.
« Reply #23303 on: January 12, 2017, 07:28:11 AM »
  I do have some stock Honda head pipes that the rotten mufflers were cut off.  Just slip them over the spigots sometimes to test out an engine for its first start before going all in with real pipes. Nothing like the sound of 4 straight pipes ------
Offline b52bombardier1
« Reply #23304 on: January 12, 2017, 11:00:55 AM »
Just rode it to work this afternoon.  It's 77 degrees F here and she started very easily. I was completely off the choke and settled into a nice idle in maybe 30 seconds. A beautiful day to be riding. Less so this summer in the high humidity.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline USMC5811
« Reply #23305 on: January 12, 2017, 11:45:25 AM »
70° in mid-January?
No rain or snow?
What else - I unwinterized and went for a ride!!
(Took the sting out of a trip to the dentist)
Offline kezz32
« Reply #23306 on: January 12, 2017, 02:03:03 PM »
searched again in vain for missing oil gallery bung  >:(
« Reply #23307 on: January 12, 2017, 02:17:21 PM »
Make one.
Many suppliers of viton cord in the UK (google search)
check www.corseal.com.uk
« Reply #23308 on: January 12, 2017, 02:34:59 PM »
Yep, I've got my old 4 into 2 drag pipes that I bought when I was 21 hanging up in the garage Eric, and I still use them to "test run" an engine, the baffles have mostly gone to God now, but they're better than no pipes at all. Cheers, Terry. ;D
Offline rickman750
« Reply #23309 on: January 13, 2017, 04:07:49 AM »
No pictures, so based on the Internet moto, it probably didn't happen...
New plugs, lowered the needles a notch, and fitted new grips to my K2. It feels like a new bike.
Offline cooley
« Reply #23310 on: January 13, 2017, 07:54:47 AM »
Took her for the first ride since the build.
Sent from my SM-G920T using Tapatalk
« Reply #23311 on: January 13, 2017, 11:43:29 AM »
^^ Nice.   Another one saved from the scrap heap  8)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #23312 on: January 13, 2017, 12:09:47 PM »
I dig the tank.
Welcome to sohc4
« Reply #23313 on: January 13, 2017, 06:18:44 PM »
Well Mark and his dad Tony came by this morning to collect the K1 and K2 "projects" I bought last year, so we spent a couple of hours dragging parts out and finding bits that were missing, etc. They left happy, and I was happy with a big wad of 100 dollar bills, it's been an expensive Christmas, so will be nice to put it all back in the bank again.
As usual though, moving a huge pile of parts hasn't really made a dent on the mess in the garage, so I only just had enough room to park my bikes. There are still 6 in storage and 2 under covers, plus I took Mike's bike over to Jeff at Ace to fix a couple of things I don't have time to sort, so I might have to sell off a few more to make some room............ ;D
Offline maduncle
  • Don't confuse me with a
« Reply #23314 on: January 13, 2017, 10:37:11 PM »
Hey Terry - remember your shed's strange TARDIS like properties...
... no matter how full it looks you can always get another bike in there.
I spent yesterday and today working on Hondas. Tweaked my CB750 "Terries TARDIS special" K2 front brakes and went for a fun ride, relocated the Motogadget M -lock so it works quicker and then rebuilt a set of old CL450K3 forks using new old stock 4" extended fork tubes (I have a chopper build underway).
I might upgrade the front brakes on the CB750 a little, a friend of mine bought a CB750F2 project and he is already busy fitting a Cognito Moto USD front end on it, so I can buy his F2 front end and have dual front disks.
Just need to modify those few small parts for the speedo drive to work under a rotor.
Now where was that post ....?
CB750K2 (only slightly modified)
« Reply #23315 on: January 13, 2017, 11:55:50 PM »
Ha ha, you're quite right Cliff, as much as I need to sell at least another 5 bikes so I can stop paying the storage fees, if something interesting came along, I'd probably jump at it....... F2 forks? Hmmnn, the problem you'll have is fitting the F2 calipers over fat K2 discs, or are you installing the Comstar front wheel with it's thinner discs (which aren't interchangeable with a K hub) too? Cheers, Terry. ;D
Offline cooley
« Reply #23316 on: January 14, 2017, 02:42:50 AM »
I dig the tank.
Welcome to sohc4
Thanks, its all paint. No decals here.
I plan to paint the tail to match.
And the oil tank is matching as well.
Offline cooley
« Reply #23317 on: January 14, 2017, 02:49:03 AM »
Offline markreimer
« Reply #23318 on: January 14, 2017, 05:01:29 PM »
I thought I'd help my neighbors wake up on time so I installed this.
Offline Scott
  • 72 CB750
« Reply #23319 on: January 14, 2017, 10:45:37 PM »
I soldeted together the wires that were only twisted together to get me home.
Offline Rocky2010
  • Live in Strayla
« Reply #23320 on: January 15, 2017, 02:15:10 AM »
Hi Terry,
would you have a spare crankshaft for a CB750 K2 which is in good shape in your pile of stuff which you would like to sell if you have a spare.
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
« Reply #23321 on: January 15, 2017, 04:02:58 AM »
G'Day Rocky, I'll have a look next weekend when I get home and let you know. Cheers, Terry. ;D
Offline USMC5811
« Reply #23322 on: January 15, 2017, 07:13:41 AM »
I visited the shop that's doing the spare tank that will become the primary tank once it's done
Offline emlupi
« Reply #23323 on: January 15, 2017, 09:25:35 AM »
After cleaning up/truing  wheels and installing/balancing new tires I set to rebuilding the carbs. New gaskets, needle valves, o-rings, vent and overflow tubes, insulators and boots. Installed refreshed parts back onto the bike over the past several days. Getting closer.
Offline evanphi
  • Apparently I'm an
« Reply #23324 on: January 16, 2017, 04:56:14 AM »
New seat cover! Combo of binder clips and wife's clothespins to hold the edge down for cementing. Tonight will test-fit the old chrome trim. If it works well I'll cement it down.
--Evan
