Author Topic: What did you do to your bike today ?  (Read 3759142 times)
Offline 90blacknight
« Reply #28300 on: February 04, 2020, 08:51:00 AM »
Got my engine back together. I'm into month 3 of my first real restoration. Getting real close to finishing it all up.
Offline Jarrett_Honda
« Reply #28301 on: February 04, 2020, 08:53:09 AM »
Attempted to install saddlebags on the bike. Now I have to make a few modifications as it isn't a direct fit.
Sent from my SM-N950U using Tapatalk
Offline Tomshep
« Reply #28302 on: February 04, 2020, 11:24:36 AM »
The story so far: 400/4 brought back form a barn in early January having lain there for twelve years. Engine was stripped, blasted painted and reassembled. Everything but the frame, tank and sidepanels  has been painted and lots of parts cleaned and zinc plated. New forks and front brake fitted, most of the ignition system and about £1500 in odd bits. Object, a tidy useable bike, not a showpiece. Problems: Sheared engine mounting lower bolt which will need drilling out from the left hand side. 300mm long drill bit on order so I can use the frame mounting as a guide. Coils and condensers all shot and cam chain you could tie a knot in. Whole engine and much of frame painted (term used loosely) black. Instruments horrible. Spokes rusty, rims poor.
Day 31 of the rebuild. Head back on cam timed in, rocker cover ready to fit. Wiring loom to go back on at the weekend and carbs to be rebuilt next week. Should have it running in ten days' time and then run it around for a week before rebuilding the wheels.
Bobarama
« Reply #28303 on: February 04, 2020, 03:56:18 PM »
I rode mine. 70 in central Florida today.
Offline Tomshep
« Reply #28304 on: February 06, 2020, 11:10:45 AM »
Half the rocker cover bolts plated. Cover gently bolted one. Clutch cover painted, new oil seal and for the first time in my ownership, I kicked it over 'cos it now has a kickstart!   Once the top is bolted on, I can break out the oil and find out if it will stay inside the motor ...
Offline 72 yellow
« Reply #28305 on: February 06, 2020, 05:54:19 PM »
While waiting for my parts to arrive, I clicked on the USPS tracking to discover my package is visiting several area post offices getting farther away from my house.
Offline kerryb
  • Not a very
« Reply #28306 on: February 06, 2020, 11:02:14 PM »
I rode it 100 miles!  Last registered 2016, rebuilt carbs ($18), cheap pods w/ bench synch, and went for it...very pleased!   Of course, its a Honda (77 550f).
« Reply #28307 on: February 06, 2020, 11:50:05 PM »
picked up the last one today,that makes three!i might keep this one its the most complete an early 72 and was told it runs,popped the cap when i got home,glad i didnt turn the fuel tap on looks pretty rancid!this has a 550 in it.
Offline Moore54
« Reply #28308 on: February 07, 2020, 06:27:23 PM »
Finished rebuilding carbs and started restoring the front brakes. These parts are from a race bike
that I am putting back on the street. The PO added a second caliper and a Yamaha FZR master cylinder.
It has a Mega cycle cam, 458, and Yoshima exhaust as well as a custom 4-4 exhaust which was mandated when AHRMA made a rule change.
Lots more to do.
« Last Edit: February 07, 2020, 07:25:03 PM by Moore54 »
Offline WhyNot2
  • I'm finally an
« Reply #28309 on: February 08, 2020, 07:13:13 AM »
All I could do was look at them, and wish like hell they ran, so I could ride them........
But heading to Pigeon Forge for the weekend to celebrate the wifey's birthday.
Online PeWe
« Reply #28310 on: February 08, 2020, 08:57:31 AM »
Looked at my bikes that have got their things done witing for spring with sandless streets and roads.
Saw my old helmet from 1990 that was in need of a clean and back in its bag.
Maybe someone will build a Dominique Sarron replica bike and need a matching helmet, Shoei Sarron replica XL. From those days when they had various graphics like Eddie Lawson etc.
Until then a reserve helmet.
Offline Tomshep
« Reply #28311 on: February 08, 2020, 12:10:10 PM »
Screwed the new tappet caps in.  As I tightened the last one, it shattered, pouring shrapnel into number four exhaust valve spring pocket. Once the rocker cover was off, I saw the oil return path to the bottom of the engine and, as I couldn't be sure that onthing had gone down it, the head had to come off again. I put it back on and kicked the engine over three times before the kickstart failed again so I decided to start fitting the coils on to find that the new one is a different size. Came in from the cold and poured myself a whisky before spending another chunk of money at Long John Silver's.
Good shafts and kickstart knuckles being unobtainable, I shall have to design a suitable repair.
« Reply #28312 on: February 08, 2020, 12:19:08 PM »
Bags are almost fully installed. I'm thinking of painting them black or blue.
Offline VTCBike750
« Reply #28313 on: February 16, 2020, 01:31:15 PM »
Just picked up this K2 today. 4,200 miles. one owner. Hasnt run since 1995. I think she'll clean up nicely.
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline Tintop
« Reply #28314 on: February 16, 2020, 01:38:45 PM »
Nice score. 8)  That looks like a Hondaline rack & backrest.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline setdog
« Reply #28315 on: February 16, 2020, 02:07:46 PM »
spent a couple hours trying to remedy a wet fouling plug, cyl 1, on a rebuilt cb750k4.  broke out a set of nos points ive been hiding, set gap to .014, static timed, then strobe timed and had to nudge the points plate to the right a bit to get f mark nicely lined up.  then i broke out the carb sync and fiddled with the throttle slides.  after adjusting the 1 slide the most and getting all the sync gauges looking pretty even, took it out for a ride.  now its a bit on the lean side, but what a vast improvement and the 1 plug is looking immensely better and not wet at all. thank god b/c i was starting to think i might have to tear down again.  im running 105 mains, 40 idle, .50 over pistons, stock box/filter, 17/48 gears, 4:1's. think i may go back to 110s but i am pretty pleased so far, more needs to be done tho.
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline Tomshep
« Reply #28316 on: February 17, 2020, 02:54:38 AM »
Fitted the wiring loom and new switches. Installed a new set of cables then checked out the electrical system before timing in the ignition. Just the back end tidying and carbs to go.
Offline BenelliSEI
  • 1969 cb750
« Reply #28317 on: February 18, 2020, 04:10:20 PM »
Installed a Hindle exhaust on the Rickman CR.
Offline vik351
  • Adelaide South Australia ...
« Reply #28318 on: February 18, 2020, 09:46:04 PM »
Just remember ya put em on wont ya ...!!!  :o
vik...
« Reply #28319 on: February 19, 2020, 08:42:37 AM »
vik...
Oh jesus. Imagine explaining that to the boat owner.
I have hoped that the bags wouldn't get in the way. I see a lot of bikes starting to lane split here even though it's not legal. I definitely won't try that with the bags on.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #28320 on: February 21, 2020, 06:43:11 PM »
Got back to drilling on the VLX600 that I broke a grade 8 bolt off in the rear of the frame.
I need to buy better drill bits. about 30 min and finally most ofnthe way back through it.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #28321 on: February 22, 2020, 01:09:48 AM »
got the last of three cb500 running pretty saleable?had some kind of mucus in the tank n carbs,starts on the button now,reused all the carb o rings got a leak,the new owner can deal with that #$%*.
« Reply #28322 on: February 22, 2020, 02:57:39 AM »
Looks great mate, I presume that's not the same engine you're selling? ;D
Offline Tomshep
« Reply #28323 on: February 22, 2020, 04:46:07 AM »
The back end metalwork was plated so I bolted it all back together and then fitted the exhaust and the side panels.
Still to do: Fit chain and chainguard.
Strip, service and refit carbs.
Top up the oil and fit the tank back on.
Add petrol and start it up.
Debug.
« Reply #28324 on: February 22, 2020, 04:54:48 AM »
Finally connected the saddlebags electrically to the bike. As soon as I did all of the turn signals stopped working. At first I thought the issue was ground, but then I remembered that they're grounded through the frame.
