Author Topic: What did you do to your bike today ?  (Read 3331699 times)
Offline BenelliSEI
  • 1969 cb750
« Reply #32300 on: July 11, 2023, 04:16:22 PM »
Thanks Bill, yeah I’m stoked to find a good one in original condition that I could afford, I had a terrible day on Monday when something at work went terribly wrong that turned out to be something that someone else had fcuked up, so it was almost like the gods had taken pity on me yesterday.
They are a comfy bike, and almost bulletproof, they did have one issue with poor top end oiling but I can see that there’s a kit available to fix that, that only takes about 15 minutes to install so I’ll buy one, and anything else that it needs to make it as reliable and enjoyable as my first one was. I’m excited! ;D
Terry….. Parrallel lives again! I also swore “no more bikes” until I finish my three current projects. Then I stumbled on this. Today an unsolicited enquiry on my mothballed K8 got the gears turning……..
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #32301 on: July 11, 2023, 04:39:57 PM »
Gritted my teeth all day under and over and in my 750 trying to find a misplaced tappet nut, as I’m sure you have all read, only to find it resting casually on the cam chain tensioner when I took it out. I’m glad I put some shop towel under it before I tried to retrieve it because it was only held in place by oil friction.
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline Kelly E
  • Geriatric Hooligan
« Reply #32302 on: July 11, 2023, 04:52:38 PM »
Today I peeled off the masking from spraying bedliner on the front and bottom of the KL 250 frame.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline BenelliSEI
  • 1969 cb750
« Reply #32303 on: July 11, 2023, 05:14:57 PM »
Neat idea. Light restoration? This will be a show bike!
Offline Kelly E
« Reply #32304 on: July 11, 2023, 05:58:11 PM »
It ain't no show bike, it's a dirt bike. ::)
I only know one way to go through a bike so it's safe to ride. It will be dirty quick enough. I'm going to make a pilot box for the wiring that goes in the headlight bucket. That way I can leave off the lights, turn signals and gauges while the boy learns to ride. Right now I have him training on his bmx bicycle until the bike is done.
Once done we'll get out the tractor and make some trails in the wooded 2.5 acres behind the shop for him.
1983 Honda CB 1100F
« Reply #32305 on: July 11, 2023, 05:59:34 PM »
Nice bike John, and much more user friendly than my XR500RE, which was a pig to start. Lucky for me, on the day I sold it, it started first kick from cold, and the buyer was so impressed he almost threw the money at me. He didn’t see the bruises under my foot from the previous day's attempts…. ;D
« Last Edit: July 12, 2023, 01:44:04 AM by Terry in Australia »
« Reply #32306 on: July 11, 2023, 11:18:26 PM »
Congrats on finding it! You will sleep easier. It was positioned for some carnage...
  • Money pit enjoyer
« Reply #32307 on: July 12, 2023, 08:39:37 AM »
It's a miracle it stayed perched there and didn't cause catastrophic failure!
'77 CB750 SS
Offline spotty
« Reply #32308 on: July 15, 2023, 07:01:03 PM »
Oil tank guard / cage / heat shield welded up , needs some polishing and a bit more grinding of ugly welds but looks so much better than the first on
i blame Terry
Offline spotty
« Reply #32309 on: July 15, 2023, 07:37:09 PM »
Chopped the sh1t out of a perfectly good battery box.
That's the battery I'm going to use, a 5ah will work perfectly well for kickstart only
It is turned 180 degrees so the battery will face outward. Next is to rebuild the lower half to fit the little battery and then mount the minimalist electrics on a plate above the battery
i blame Terry
Offline grcamna2
« Reply #32310 on: July 15, 2023, 08:12:41 PM »
You making the stock battery box smaller to fit a smaller battery;I get it.
Offline fire113
« Reply #32311 on: July 18, 2023, 02:45:00 PM »
...bought some rods.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #32312 on: July 20, 2023, 09:39:54 AM »
Learned the shear strength of my 4043 welded and tapped threads was not up to snuff for the cylinder studs.
So there's a helicoil in the block now.  Really shoulda done the stress test before putting the two halves together.  Managed a pretty clean job with tape and rags and q tips.
J•B welded that insert to its new home and got the rest of the engine assembled.
The big mystery cam is set neatly near the stock timing mark for now.  Ample clearance for initial start up.
  • Money pit enjoyer
« Reply #32313 on: July 20, 2023, 11:43:25 AM »
I moved it to the opposite side of the street to avoid a parking ticket.
I haven't ridden it in a few days. I'm waiting for a "good" petcock to arrive so I can install these new float valves, they keep getting gritty and stuck open. It's perfectly ridable with a minor gas leak, I make jokes to people that it's pouring one out for the homies, but I don't think it's very good for the motor to have a fuel level that high.
'77 CB750 SS
Offline BenelliSEI
  • 1969 cb750
« Reply #32314 on: July 20, 2023, 01:04:10 PM »
Changed out this old battery on the K1. Went to go for a ride and nothing! 6 years old, so no real complaints.
« Reply #32315 on: July 20, 2023, 02:57:40 PM »
You can’t complain about that John, I’ve had Yuasa batteries that lasted a year. The black  Motobatt’s are fantastic, the one I put in my Sportster in 2016 is in my Rocket III now, and has never let me down, nor has it seen a trickle charger in its life. ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #32316 on: July 20, 2023, 04:46:01 PM »
A buddy of mine (very snobby BMW owner) swears by the mottobatts. I would try one, but don’t want to give him the satisfaction!
« Reply #32317 on: July 20, 2023, 07:41:14 PM »
I feel your pain mate, I'm also a BMW owner and am a member of the BMW club here since 1991, but there are certainly some "characters" in the club, hence my not attending a meeting or a club ride in 30 years. I only stay in the club to keep my "Club" plates for all of my other old bikes. ;D
  • Money pit enjoyer
« Reply #32318 on: July 22, 2023, 05:39:56 AM »
Replaced petcock, blasted carbs out, installed OEM float valves and corrected fuel level.
Then I went to get something to eat, ran into my recently estranged wife, and proceeded to get so drunk I had to leave my bike and get a cab home.
'77 CB750 SS
  • Money pit enjoyer
« Reply #32319 on: July 23, 2023, 07:32:08 AM »
PD42A carbs in frankly sparkling condition came in, so I took the OEM floats of my crap carbs and put them in the “new” ones, moved the jets over, adjusted fuel height, bike runs like a dream even having only bench synced. Will be vacuum-syncing this morning.
Can I do this on the side stand? My bike doesn’t have the center stand, and my motorcycle stand it inaccessible right now.
'77 CB750 SS
Offline BenelliSEI
  • 1969 cb750
« Reply #32320 on: July 23, 2023, 09:41:28 AM »
Use a screw Jack or a stack of wood under the right side and shim up the side stand. It’s important to be fairly level so the float levels are where they “normally” sit…….
  • Money pit enjoyer
« Reply #32321 on: July 23, 2023, 12:05:45 PM »
Good to know, cheers.
New carbs and petcock have solved every issue this bike had. No more hanging or climbing idle, no more stumbling under heavy load, no more leaking, no more having to adjust the idle screw at every stoplight. It just … works.
Now I just have to get a chain guard to keep oil from flying all over my tire
'77 CB750 SS
« Reply #32322 on: July 23, 2023, 01:14:21 PM »
I use a 2" thick piece of wood under the sidestand to make it sit almost vertical. Stable to not tip over.
Wooden plank 2" thick is usually 45 mm in reality.
Same when syncing carbs letting it idle for a while. A fan blows from front.
My K2 has centerstand for show, too tricky to use on flat concrete floor. Side stand there too.
Below my K6
« Last Edit: July 23, 2023, 01:33:58 PM by PeWe »
Offline JamesH
« Reply #32323 on: July 23, 2023, 01:16:50 PM »
Been batching up smaller jobs on the Cb750’s. Tackling a repair on the Sandcast speedo gauge drive spigot. Had to sacrifice the threads from a spare diecast unit I had to repair the Sandcast unit. Luckily all went to plan. I f*ing hate parting off stuff on the lathe at the best of times; doing it on an irregular shaped speedo drive was fun..
Offline grcamna2
« Reply #32324 on: July 23, 2023, 01:21:55 PM »
JamrsH,how did you attach the donor threaded piece from the diecast to the sandcast housing ?
