Author Topic: What did you do to your bike today ?  (Read 3271100 times)
« Reply #33075 on: June 03, 2024, 07:32:21 AM »
....drove 300km in the rain to the Honda CB750 meeting 2024.
Bet that was fun!  How many 750's?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #33076 on: June 03, 2024, 08:34:48 AM »
I will try a pic
That's very cool Sean. Are you going to ride that to the Gilmore next weekend?
Offline Bankerdanny
« Reply #33077 on: June 03, 2024, 08:47:11 AM »
It was finally time to wake up the bike from it's long winter and spring nap. We've had a ton of work to do around the house and I am only in Michigan on weekends, so I just haven't been able to get to it. I had tried to start it a couple weekends ago, but got nothing when I turned the key. I didn't have time to figure it out, so I just pulled the battery and waited.
Yesterday afternoon I got back to it. First I aired up the tires, then I reinstalled the battery and turned the key. Same issue, no lights of any kind. Pulled off the side cover and checked the fuses, no problems. Opened the little case on the frame that F0/1 bikes have for much of the wiring that it in the headlight shell on other SOHC4's, didn't find anything, but then all of a sudden I had power.
I put the tank back on, choked it up and it fired right up. So I closed the box back up, pushed it out of the barn, went to re-start and stone cold dead again.
Off comes the wiring box again and I start checking connections. Again, no obvious problems. After a few minutes of staring, I noticed the main connection between the harness and switch was disconnected. I have a replacement switch that came from 4into1 and it uses a pigtail out from the switch to move the switch end of the connector to where it is easier to get to. The harness end has the opening for the retainer clip, and it is broken, so the connection had apparently just vibrated loose then separated all together when I moved the bike out of the barn and turned the bars. I plugged it back in and all was good.
Rode up to the house, geared up and went for a 60 mile ride. It was sunny and 72 and just beautiful. A picture is posted in the Photo thread.
When I got home it got fresh oil and filter. Next weekend is the Gilmore Vintage Motorcycle weekend. I'm busy Saturday, but I'll do a quick timing chain adjustment and hit the show on Sunday.
« Last Edit: June 03, 2024, 08:48:47 AM by Bankerdanny »
« Reply #33078 on: June 03, 2024, 10:32:18 PM »
I will try a pic
Yeah, hopefully.  I have been sort of trying to save the fresh build effect for a good show....but I gotta try and swap meet a bunch of stuff so I don't know if I will have time and/or space to get it there.
Offline newday777
« Reply #33079 on: June 04, 2024, 02:58:27 AM »
I got a bike back from a friend after a decade. I took the tank off to drain out gas that was a few years old, drained the fuel from the carbs, and filled it up with some fresh gas and seafoam. I’m hoping I can get away without pulling the carbs and rebuilding them.
Welcome back aboard
What bike is it?
Stu
My current rides
Prior bikes....
Offline WhyNot2
  • I'm finally an
« Reply #33080 on: June 04, 2024, 05:26:11 AM »
Got the CB550 front forks on the CB750.
Wheel and brake installed.
Gotta button up the rear fender and Lucus style tail light.
Then "ride sally ride"
Offline fire113
« Reply #33081 on: June 05, 2024, 03:59:02 PM »
...don't know, not so many may be 150+- for sure not so many as last Year because the weather was real bad, it was raining all 4 Days.
A lot people came by car and some by car and trailer with motorbike on it.
Had a lot of fun there, bought some parts and arrived dry at home.
Parked the CB750 in the garage and took the car and then I killed Bambi.
« Last Edit: June 05, 2024, 04:01:55 PM by fire113 »
Offline spotty
« Reply #33082 on: June 05, 2024, 06:35:48 PM »
i blame Terry
« Reply #33083 on: June 06, 2024, 06:52:14 AM »
150 CB750's...wow, that would be fantastic!
Good to hear you didnt hit Bambi on your bike, that would be bad.
Damage to my truck last time I hit one a few years back:
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #33084 on: June 06, 2024, 08:18:01 AM »
Good thing you were not hurt.
We have an out of control population of Axis deer here, we have no predators, only hunters and they cannot keep up. It's excellent venison, after all, they are living in a 12 month garden. We have to be very careful driving at night and even in the day time.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Kelly E
  • Geriatric Hooligan
« Reply #33085 on: June 06, 2024, 03:48:00 PM »
Sounds like some of the local restaurants should start serving Axis to create some demand and a market for it. Maybe then you can get enough hunters supplying Axis to control the population.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline fire113
« Reply #33086 on: June 06, 2024, 04:44:53 PM »
...checked the parts that I bought at the CB750 meeting.
@spotty
Because this Sexpistols song I wrote Bambi  ;)
@Stev-o and MauiK3
You can be sure that I am glad that I did not hit it with the CB750 and I am real happy that I am not get hurt.
The car is insured against a crash like this but I am still a little bit sad because I just finished the car several weeks ago with a complete paintjob and a fresh installed turbo engine :(
...have a good one...
« Last Edit: June 06, 2024, 04:50:04 PM by fire113 »
Offline wolf550
« Reply #33087 on: June 06, 2024, 07:19:00 PM »
starting to tear apart brown betty. changed out the old seat cover/ put on the new. got the oem turn signals taken apart to sand/polish. started on the front fender stays got them polished and tomorrow is fender. yeah pics coming
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline wolf550
« Reply #33088 on: June 07, 2024, 11:05:12 AM »
out with the old on with the new
74' CB550 (Sold)
Offline wolf550
« Reply #33089 on: June 07, 2024, 11:07:12 AM »
signals
74' CB550 (Sold)
Offline fire113
« Reply #33090 on: June 08, 2024, 02:14:40 PM »
...did a paint job of the inner gauge housings and beought the frame for the next project home.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #33091 on: June 10, 2024, 12:05:26 PM »
This weekend I
- refurbished and repainted front master cylinder
- polished brake and clutch lever to mirror sheen
- made new braided steel pvc-coated brake lines with new banjo fittings
- put fluid in brake lines and tested. Good stuff!
- mounted chain
- mounted chain guard
- mounted and adjusted clutch
- checked transmission. It works
- rebuilt and bench-synced carburetors, and installed new clamps and boots (OEM)
- lubed all cables
- lubed throttle shaft with graphite
- started getting to grips with #$%*ty old harness
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline WhyNot2
  • I'm finally an
« Reply #33092 on: June 12, 2024, 04:30:23 PM »
This weekend I
- mounted chain
- lubed all cables
Lot of work.....like to see those brake lines you made up.....!!!!
Offline fire113
« Reply #33093 on: June 14, 2024, 02:27:12 PM »
...mounted the handlebar, left/right switches and the pump/brake lines.
Offline Magpie
« Reply #33094 on: June 14, 2024, 09:30:04 PM »
Got my side panels back from my painter for the K6.As soon as the tank decals arrive here the tank will be done. the one on the right is the stock colour. I think he came close in the colour match in spite of the poor lighting.
  Cliff.
« Reply #33095 on: June 14, 2024, 11:15:32 PM »
Red does fade with age and it like most yellows is very additive due to its transparency. That is why painting side covers and other parts at the same time is about the only way to get good color matches. Much harder when done later. Skills really have to be higher to do very good color matches on colors like red later. One light coat can change the color depth and shade a fairly significant amount.
Your painter did a nice job on the paint!
Offline wolf550
« Reply #33096 on: June 15, 2024, 09:01:09 AM »
taking all the front end off of brown betty to give everything a spruce up and found the fork seals leaking so ordered a new set
74' CB550 (Sold)
Offline spotty
« Reply #33097 on: June 15, 2024, 07:20:07 PM »
Got the front mount made for the seat, the tongue at the front slides under the rear tank mount sleeve and goes around the bolt that holds the tank on
i blame Terry
Offline grcamna2
« Reply #33098 on: June 15, 2024, 08:28:34 PM »
Looking like it's getting closer spotty;have you had it running ?
I see a blue fairing plastic w/ silver? numbers behind it:what does that fit ?
Offline spotty
« Reply #33099 on: June 16, 2024, 05:11:27 PM »
it hasn't run since i started the whole project but it did run and was being ridden so i don't hold too many doubts on that front ( except the carbs have been changed and i'm putting electronic ignition in so theres two new variables...)
the fairing is from a zzr600 that i was given, it should be good to go now I've properly cleaned the carbs and done fluid changes, when i can get some room in the garage i'll finish putting the carbs back on, repair the fairings and put it up for sale
i blame Terry
