Author Topic: What did you do to your bike today ?  (Read 3272732 times)
Offline fire113
« Reply #6100 on: May 01, 2011, 03:30:43 PM »
...started with the K0 speedo
Offline jkminer
« Reply #6101 on: May 01, 2011, 04:01:40 PM »
Put the Carbs on my CM400a and she runs!! Needs to be tuned, running rich now... but she runs and moves on her own!
Hoarder of old japanese bikes that need a loving home
K0 CB500 - former daily, currently needing some tlc
80 CM400A - my loaner and knock around bike
79 GL1000 - in full vetter kit
K3 CB750 - a project waiting for more time and money to start
« Reply #6102 on: May 01, 2011, 05:37:03 PM »
How do you pull them apart Georg? I want to refurbish my K0 speedo and tach. Cheers, Terry. ;D
Offline CycleRanger
  • No comment about being an
« Reply #6103 on: May 01, 2011, 06:35:09 PM »
Started the used motor I got for my K5 for the first time today.
It fired right up and actually sounded pretty darn good.
I completely rebuilt the carbs so it still needs a sync and I think I got the Dyna too far advanced.
Unfortunately the new cable didn't fix the sluggish/sticky tach.
I'll probably pull the tach off the K3 and use it for now.
Also gotta go back and check the connections since it didn't appear to be charging.
It's never gonna end...
Offline mjstone
  • I'm definitly not a
« Reply #6104 on: May 01, 2011, 06:49:39 PM »
Looks like that loose valve core was my problem. The rear tire seems to be holding air just fine.
Went on a 70 mile round trip to a friends house to help him work on one of his AMC Eagles, one of which he bought from me years ago.  I had my GPS hooked up to the bike.  I had mounted the GPS mount in the spot on my Cycle Sound stereo enclosure where the antenna used to be.  Worked out pretty good. :)
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline crp_iii
« Reply #6105 on: May 01, 2011, 09:21:45 PM »
Got the 350's front signals working again-bad ground. Too much tinkering with out running. Not enough juice to start. Trickle charger connected now.
72 CB350F With poor man drag pipes
77 CB750F
Offline mrbreeze
  • Not your average
« Reply #6106 on: May 01, 2011, 09:49:48 PM »
Put the left side grip on that I bought in Carson City,Nv. yesterday. My throttle grip took a dive Friday as I was doing my first leg of the rally. I removed the offending grip and wrapped my throttle sleeve with duct tape which was acceptable. Rode 50 miles from Fernley to Carson City,Nv. to a bike shop looking for a new chain for Fat Matt. We had to go another 50 or so mile round trip to Reno & back but they fixed him up with the chain and I had a new throttle grip. Like I said earlier....I put the matching grip on the left side and went for a 50 mile run in beautiful weather. Always carry duct tape on a long putt and I also learned that a roll of electrical tape doesn't hurt also!!!! (saved Sean's a$$ out in the desert!!!!)
MEMBER # 257
Offline magconpres
« Reply #6107 on: May 01, 2011, 11:27:56 PM »
Finally got the engine for one of my 400Fs back in the frame tonight.
I bought this bike about 9 years ago.  When I got it, it ran, but the cam chain made a horrible noise and couldn't be adjusted.  I pulled the engine to tear it down to fix/replace the adjuster.   Had some kids, changed some jobs, moved, etc....things just kept getting in the way . But tonight, I have a rebuilt engine (new bearings, rings, seals; everything within spec) sitting in the frame.
Now to get the rest of th ebits in place (cars, starter, etc), complete the rebuild of the front brake system, get some new suspension bits, and I'm back on the road...just in time to start the cafe build on CB400F #2 :)
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #6108 on: May 01, 2011, 11:41:15 PM »
got my brother to convert and upload the video today. This was shot by another co op member last month when my bike died. But I was there yesterday working on it all day getting an engine swapped. I was a little nervous that I would look like I was about to burst into tears during my interview.
South Austin Motorcycle Co Op
music
« Reply #6109 on: May 02, 2011, 12:07:34 AM »
Very cool Johnny..... ;)
Offline CycleRanger
« Reply #6110 on: May 02, 2011, 06:41:54 AM »
Congrats!  I suddenly don't feel so bad about it taking a year to get my motor swapped & running.
Offline fire113
« Reply #6111 on: May 02, 2011, 09:12:07 AM »
Hi Terry,
...I cut the half round plastic ring on the back of the speedo with a sharp cutter knife. You can it in the right corner of the picture that I posted. Will post a better one this evening, have to go I am short in time.
Prost...Georg ;D
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=agipc6v386aeqsc4k4q6actmi5&/topic,60973.0.html
« Reply #6112 on: May 02, 2011, 09:20:54 AM »
have an short test ride..last ride ended with lost all elektric battery vas flat..and 2 carps vas overfloted
have kleaned tank for rust and loadet battery...this time it runs...think  atlast im ready for road
ps im not that small.. ;)
« Last Edit: May 02, 2011, 09:24:53 AM by strynboen »
i hate all this v-w.... vords
Offline Plankton
  • adrenaline junky
« Reply #6113 on: May 02, 2011, 10:46:15 AM »
I rode it all through vermont and mass on dirt roads and country twisties for a couple hours it was awesome! the bike performed great finally no more carb problems because before I left put a bunch of seafoam in the gas now it idles around 1300!
Offline twinegar
« Reply #6114 on: May 02, 2011, 11:36:34 AM »
Bought some new oem parts for my 72 CB350F, rear helmet decal, oem turn signal relay and a new original Yuasa clear case battery like came in the bike in 72. I also bought a good used tool tray lid, headlight case and 72 owners manual for the same bike. On a near perfect bike I don't mind paying for nos to tweak it back to perfect condition. The helmet decal is hanging loose, the turn relay is the later round version, the tool tray lid has a melt in the center, the headlight case has a small scrape and the owners manual was missing. I got a near mint 73 owners manual and this 72 isn't as nice but correct for the build date. I will still be on the lookout for a new correct manual. If I ever show the bike, sticking the new original clear case battery in the box will be a nice touch.............and that is what I have been doing.
66 CL160      68 CL450      68 CL125A
69 CL125A    69 CB750K    71 CB450
71 CB500      71 CB750K    72 CB350F
72 CB750K    74 CB750K    75 CL360
75 CB550      76 CB750K    79 CB750K
79 CBX          79 CBX          80 CBX
82 CB750K    84 VF700S     85 VF1100S SABRE
05 HD1200R SPORTSTER ROADSTER
Offline coldwave007
« Reply #6115 on: May 02, 2011, 12:17:40 PM »
Put my CB650 on its center stand and set out to tear apart the rear end.  Pulled the rear tire and inspected/lubed the center axle and bearings.  Also inspected/cleaned the rear break (over 75% left on each pad), drive chain, and rear sprocket.  Interestingly, this chain has no master key - it's an infinite.  For now both the chain and sprocket are in good shape so I won't be replacing any time soon.  Also adjusted the throttle cables - had too much slack.
After I had it back together I took it for a quick 15 minute run.  I really do love this bike!
1980 Honda CB650C Custom, 1972 Yamaha LT-2 100
Offline fire113
« Reply #6116 on: May 02, 2011, 12:42:55 PM »
Hi Terry,
Prost...Georg ;D
...here You have the pictures.
Did a new compression test and this time with a warm engine 16 Bar at all 4 cylinders  ;D last time I did it when the engine was cold and got 15 Bar
Offline fire113
« Reply #6117 on: May 02, 2011, 04:27:27 PM »
...finished the K0 sandcast speedo to 90%,, have to polish the clear top lens and remove the protection film from the face plate and glue the back of the housing.
Time to go to get some seep...Georg
Offline thrutheframe
« Reply #6118 on: May 02, 2011, 06:09:41 PM »
Today I pushed the KZ750 out into the hall so I could get some work done on the CB650.  Got the clutch lever dry fitted and started on cleaning the new front master cylinder.  I also stopped by Western Hills Honda and paid off the CB360T.  I didnt bother to take delivery in the rain.  I ordered a real shop manual for the CB650 and some hardware for the clutch lever and master cylinder.  I have to go back out and work for 5 days or so but I will get to do some wrenching tomorrow.  I have the steering stem bearings, new tach and speedo cables coming.  Im goin to wait until I have the front end back together before I order the throttle and clutch cables.  I think those two and the brake line will need to be shortened to accomadate the low rise bars.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline mjstone
« Reply #6119 on: May 02, 2011, 06:38:21 PM »
Rode to work am and pm.  After work this morning I stopped and filled up the tank at $4.08 a gallon.  Later this afternoon I see that the price went up to $4.30 a gallon.  At these prices I can't afford to drive my CJ-7.  Gotta get with it and do a proper tune up and carb sync so I can get better gas mileage with my bike tho.  I did buy a set of vacuum gauges off eBay the other day.  Now I need to decide on what I want to do about the ignition, new point plate with points & condenser or go with a Pamco electronic unit.
MJ
Offline Radam
  • taco racer
« Reply #6120 on: May 03, 2011, 05:42:31 AM »
I got my rebuilt rear master cylinder in from silverback on Saturday and hooked it up. My brake pedal isn't coming all the way back up on it's own though. I can push the brake down, then it still has resistance on it when I take my foot off of it. I can pull it back up with my toe, but I'd like to fix it right. Do you think it could just be the adjustments or the spring? I didn't get to spend too much time because it started raining and I don't have a shop.
Offline fire113
« Reply #6121 on: May 03, 2011, 09:14:39 AM »
...made some new spacer for the front lamp housing.
Offline gnarlycharlie4u
  • Far from being an
« Reply #6122 on: May 03, 2011, 03:43:29 PM »
ooh pretty!
took the rear wheel off both of my gl1000's and got a new d404 and some gear oil for one of them.
Offline dylboss
« Reply #6123 on: May 03, 2011, 06:50:19 PM »
cleaned the rust out of the new tank I bought using Kleen Strip Pref+Etch.  Stuff works awesome!!
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline mjstone
« Reply #6124 on: May 03, 2011, 06:55:35 PM »
Rode to work again today. Got rained on coming home this evening. ;)
MJ
