Author Topic: What did you do to your bike today ?  (Read 3277434 times)
0 Members and 9 Guests are viewing this topic.
Offline Tintop
« Reply #6400 on: May 29, 2011, 06:24:46 PM »
Watched mother nature give it a big time all day bath. Now that it's home for good, time to get a cover.
The bath part starts here tonight.  In the meantime the roads dried out from the last one, and I put another 60 miles on the 400SS up through the Hockley back roads.  When I stopped at Timmy's, it drew a small crowd.  Going to get my coffee 1st, answer questions 2nd next time. LOL
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6401 on: May 29, 2011, 06:43:54 PM »
The weather broke, so I ride to my favorite local watering hole for dinner. I also got to test my newly installed turn signal relay. Works like a charm.
Offline TruTred
« Reply #6402 on: May 29, 2011, 09:05:53 PM »
After what seemed like a lifetime in the garage (only couple months) without progress, finished rebuilding front caliper, reinstalled cleaned-up carbs, bolted back on holey exhaust (till 3:30 AM) and fired it up!!!!  After few hours sleep, went for couple mile shake down which went OK.  Later went for about 15 mile ride.  need to re-bleed front brake system, replace fork seals & oil.  After that-check rear brake.  Etc. Etc.  But it's working - Oh Yeah! Felt good to be back on 2 wheels after 13 yrs.
finis origine pendet
CB750K5
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #6403 on: May 29, 2011, 09:38:06 PM »
Made motor mounts and axles front/rear out of stainless, made dust caps for my forks, and made a remote oil fllter system for my 550 this weekend-
Follow my build "P38 Racer" in Project section
Offline mjstone
  • I'm definitly not a
« Reply #6404 on: May 30, 2011, 10:32:36 AM »
Installed new plugs this morning.  Installing plugs on my bike involves removing the fairing and tank.  Plug #2 was missing the compression ring.  Found it off to the side.  Made sure the new plugs had their compression rings.  Put everything back together and fired it up! Ran nice but no indication on the tach.  I had forgotten to hook it back up after installing plug #3. ::)  Managed to hook it back up with only shifting the tank.
Went for a four mile ride around the big block.  Everything went great until I turned back into my neighborhood.  About 4 blocks from home everything went dead. :o  Took only a few moments to realize I had no electricity.  Called home and told my wife what and where and asked her to send my daughter out to help me push the bike back home.  About 1/2 a block from the house she shows up an helps me push it up the last bit and into the front yard.
After a few checks with a meter I find the problem was with the ignition switch.  The red power wire had corroded of the switch. Took the switch apart, cleaned the contacts, cleaned the end of the post that the red wire was supposed to attach to and soldered the wire back on.  Hooked everything back up and power was back.  Took the bike out for another run around the big block and made it back home without any mishap. :)
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Trav-i
  • Has finally become an
« Reply #6405 on: May 30, 2011, 03:34:15 PM »
Took the bike out for a nice ride today.  Wanted to go look at a couple of houses and what better way to bum around on such a beatiful day.  Still gotta get new fork seals though, popped the right one last week in the mountians.
Forum member #9962
1992 GL1500 Interstate
Offline sopo400f
« Reply #6406 on: May 30, 2011, 04:22:19 PM »
Rebuilt the master cylinder and put my front brake back together. Bled the line using an oil change vacuum pump. Worked great!
1975 cb400f blue
Offline Tete
  • oily
« Reply #6407 on: May 30, 2011, 05:35:28 PM »
put on tail lights. I still can't get the right blinkers to blink but the left are working.
1973 Honda CB500Four
1975 CB200T
Offline thrutheframe
« Reply #6408 on: May 30, 2011, 07:27:03 PM »
Rode the Kaw to my shop, cleaned up and reassembled the sprocket cover and clutch lever mechanism for the CB 360, put another coat of paint on my CB650 brake lever then decided to go to Rock Bottom for lunch.  I hung out downtown at Taste of Cincinnati for awhile them rode back to the shop.  Sat in the sun and fought with my clutch lever mechanism until I felt sick from the heat.  It would have gone together right the first time but the PO had put an extra part in the mix, most likey in an effort to make the worn out clutch last a few mor miles.... (uhhhh WTF?)
I rode the Kaw home and posted my frustration on hondatwins.net...
Took a nap, woke up to an email from a forum member offering to talk me thru it.  I called the guy up and during our conversation figured out that there was an extra part in there.
Rode the Kaw back to the shop, sorted out the clutch adjustment literally as the sun was sliding behind the Metro garage, killing my only worklight in that part of the building.  It feels like a clutch on a bike that isn't running.  I couldn't test ride it or start it because the pipes are off.  I rode the Kaw home, smiling all the way.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline cb650
« Reply #6409 on: May 30, 2011, 07:43:21 PM »
Finally got the nitehawk home Jerry rode on the relay.   I think I like it but need to redo the front end.     # running sohc4's now and the 360.  The 360 is probably pissed I haven rode it in a couple months.
Offline Frankenkit
  • Industrial Strength
« Reply #6410 on: May 30, 2011, 08:20:50 PM »
Took the CB650 and CL350 out for a little 8 mi. ride.  Got about 4 miles out and the 350 started idling really low... then at 6 miles it started backfiring badly... then it died.  Took the 650 back, got a charged battery and new spark plugs.  The new battery started it, the plugs- one looked lean the other seriously rich... bike wouldn't idle at all but stayed running with a hand on the throttle.  We limped it home that way, but now thinking we'll wait 'til we can get the carbs done before taking it out again.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #6411 on: May 31, 2011, 12:34:55 AM »
Sounds like you got carb gremlins alright Kit.
Offline Bankerdanny
« Reply #6412 on: May 31, 2011, 07:39:10 AM »
This has become my standard reply since all the problems I had when the relay was here in Chicago: check the connections between the condensors and the points.
My 1-4 connection was loose causing the two to run intermittently and to backfire like crazy (and quite spectacularly with fire shooting out the #1 tail pipe). I tightened the nut and like magic I was back to running perfectly.
Offline Bankerdanny
« Reply #6413 on: May 31, 2011, 07:41:10 AM »
I put about 200 miles on it yesterday.
About 800 miles total in less than a month back on the road and probably 6-7 total rides.
Now I need to do something about the ass numbing properties of my seat (other than finding one of those incredibly ugly king/queen things)
bollingball
« Reply #6414 on: May 31, 2011, 05:24:21 PM »
Danny I have one of those ugly seats feels good on long rides but I hate the looks. Just bought a stock seat from a form member.looks a lot better but hard as a rock compared to the other one. So I'm sending the stock to this place all new foam and a gel insert in the front. Check out this place
http://www.astechseat.com/seat-modifications/
          Ken
Offline Tintop
« Reply #6415 on: May 31, 2011, 06:19:48 PM »
Parked the truck (monsoons have stopped ::)), and took the 400 to work.  Weather report is for sun all week. 8)  Hope the truck doesn't get to lonely. ;D ;D
77 CB550 Cafe build
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=hhdqp2mpneapv2f3tptuah8cq7&/topic,60973.0.html
« Reply #6416 on: June 01, 2011, 07:42:31 AM »
got my 77 home..1964..older then me.. faund that the engine  is an cb-72..damed....
..like that HOT honda...
« Last Edit: June 01, 2011, 07:46:46 AM by strynboen »
i hate all this v-w.... vords
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6417 on: June 01, 2011, 07:47:27 AM »
Looks like a fun project there!
« Reply #6418 on: June 01, 2011, 09:34:13 AM »
Rode the Kaw to work today. I really love that bike but I think I'm going to sell it once the CB650 is done.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline coldwave007
« Reply #6419 on: June 01, 2011, 10:39:16 AM »
Stared at my CB650 longingly this morning.  Went for a ride to my Dad's this Saturday (about a mile) and on the way back the shifter and sprocket seals both went out and started squirting oil.  So she's parked until the new seals get here.  And we have such beautiful riding weather now!!! Sunny with 75-80F.  :(
1980 Honda CB650C Custom, 1972 Yamaha LT-2 100
Offline Scott S
« Reply #6420 on: June 01, 2011, 11:47:01 AM »
 Went to the only local shop t hat has old bikes and got an unbroken clutch pushrod and a disc brake splash shield for my CB500, all for the grand total of ten bucks!
 I'm working on getting the pristine points plate off so I can get to the just as pristine advance mechanism and springs. Alas, two of the three screws are fighting back. Sprayed them down with PB Blaster and will go back with my impact driver soon.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline fire113
« Reply #6421 on: June 01, 2011, 01:52:26 PM »
...installed a kind of end caps or better end rings  ;D at my K1.
« Reply #6422 on: June 01, 2011, 09:37:39 PM »
Brought the 360 pipes home and cleaned the rust off of the unexposed surfaces.  I used a Scotch Brite pad and water and rubber them very lightly. then dried them with an old t-shirt.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline fire113
« Reply #6423 on: June 02, 2011, 04:11:53 PM »
...drove the K1 ~200km, what a nice day  8)
Offline dhall57
« Reply #6424 on: June 02, 2011, 04:42:45 PM »
I'm a little pissed  >:( Just noticed the directional arrow on the new tire I just had mounted for my CB750 is opposite of the actual rotation. Has anybody had this happen to them. Did you have it remounted correctly or were you temped to just to put it back on the bike and run it like it is. Alright tire experts could it be unsafe to do this? Would the bike handle and ride different. If there could be some safety issues I will definitely have it remounted.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
