Support the site. Your contributions keep this site running.
I'm a little pissed Just noticed the directional arrow on the new tire I just had mounted for my CB750 is opposite of the actual rotation. Has anybody had this happen to them. Did you have it remounted correctly or were you temped to just to put it back on the bike and run it like it is. Alright tire experts could it be unsafe to do this? Would the bike handle and ride different. If there could be some safety issues I will definitely have it remounted.
Just got done replacing my headlight. The screw holding the trim ring on was rusted in place. Ended up having to drill it out. Got a stainless steal screw in there now. Went to the auto parts store to get the headlight. Only had two choices in 7" headlights, both halogen Sylvania's. Bought the cheaper one. Mounted it up right there at the store. No listing of power consumption on the box.MJ
Went to the shed to start tearing my CB750 apart, checked the temp gauge inside the shed. It read 114, decided that was just alittle too warm, locked the shed up and went in the house with AC running and started slamming brewskies instead.
Quote from: budlite282 on June 03, 2011, 08:01:53 AMWent to the shed to start tearing my CB750 apart, checked the temp gauge inside the shed. It read 114, decided that was just alittle too warm, locked the shed up and went in the house with AC running and started slamming brewskies instead.You need to invest in a rolling A/C unit. You can vent it out through a wall using a drier vent fitting and they work pretty well. I have two in my condo where window units wouldn't have worked. They aren't as effective as normal window units, and they can be pricey. But they do offer a lot of flexibility in positioning.
Quote from: Bankerdanny on June 03, 2011, 08:19:08 AMQuote from: budlite282 on June 03, 2011, 08:01:53 AMWent to the shed to start tearing my CB750 apart, checked the temp gauge inside the shed. It read 114, decided that was just alittle too warm, locked the shed up and went in the house with AC running and started slamming brewskies instead.You need to invest in a rolling A/C unit. You can vent it out through a wall using a drier vent fitting and they work pretty well. I have two in my condo where window units wouldn't have worked. They aren't as effective as normal window units, and they can be pricey. But they do offer a lot of flexibility in positioning.I'm assuming this rolling A/C unit requires electricity, of which, is not available in my shed.
I sanded my 4-4's and primed them for the flat black. I think I am going to have to wait to put the black paint on, because I don't own an oven or grill large enough to bake the pipes.
yesterday she died, I pushed her back to the shop where I been working on my truck. The batt still had spark but the lights dont come on .... I'll work on it later I need sleep. I am glad those janky wires lasted as long as they did as jerry rigged as it is.Time to go back to the OG setup love, she deserves it. Hey at least she didn't die with Godzilla out in the middle of nowhere!!!
Quote from: dhall57 on June 02, 2011, 04:42:45 PMI'm a little pissed Just noticed the directional arrow on the new tire I just had mounted for my CB750 is opposite of the actual rotation. Has anybody had this happen to them. Did you have it remounted correctly or were you temped to just to put it back on the bike and run it like it is. Alright tire experts could it be unsafe to do this? Would the bike handle and ride different. If there could be some safety issues I will definitely have it remounted.Same thing happened to me when I had my front tire replaced a couple of years ago. Took it back and they flipped it around without argument. When i had them do the rear last summer, I took a sharpie and marked the direction of spin with an arrow on the wheel in a couple of places so they wouldn't screw up again. I think you'd definitely want to have it flipped the right way so water sheds correctly.
Quote from: Elniniomuchachos on June 03, 2011, 02:42:13 PMI sanded my 4-4's and primed them for the flat black. I think I am going to have to wait to put the black paint on, because I don't own an oven or grill large enough to bake the pipes.I hope the finish wasn't in very good shape, otherwise you ruined $900 worth of exhaust.
