Author Topic: What did you do to your bike today ?  (Read 3338053 times)
« Reply #6475 on: June 05, 2011, 09:00:46 PM »
Nato, did you make or buy the rear frame section..?
Offline nayto550
« Reply #6476 on: June 05, 2011, 09:15:03 PM »
I got it from CycleOne.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
« Reply #6477 on: June 05, 2011, 09:28:20 PM »
Thanks... ;)
Offline longshanks
« Reply #6478 on: June 05, 2011, 10:11:29 PM »
Changed out the bulbs on my speedo gauge only to find out they were fine and that I have an obvious electrical problem.
cb450 K5
« Reply #6479 on: June 06, 2011, 02:45:17 AM »
That's a beautiful tank Dave, how the hell did you get those massive dents out? Did you weld pins into it? I bought a stud welder a few years ago when I was painting cars (2000 bucks, ouch!) and it's good, but bike tanks are buggers to get dents out of, that's why I've started splitting 750 tanks to knock the dents out from the inside. Cheers, Terry. ;D
i gave it to a panel shop,,surely it would have a fair bit of bog/bondo in it,the filler neck was still slightly at an angle,that was the bike i just sold,i remember your post on splitting the tanks,i cant find it now have you got a link maybe terry?i want to try and straighten this one myself(how hard can it be?)famous last words.
Offline isred09
  • you meet the nicest people riding a honda
« Reply #6480 on: June 06, 2011, 05:03:46 AM »
Well it cheating because I haven't done it yet, but I plan on putting a good 200 to 250 miles on my 550 today on a planned ride. Any ways got to go, brent
« Reply #6481 on: June 06, 2011, 06:02:03 AM »
+1 on that frame repair Terry. I'd like to know more about the splitting the tank idea. I have a few that could use it.
Thanks Dave, Danny and Fred et al, on the older CB750 tanks (and maybe the 500 tanks too Dave) the top and bottom sections of the tank are seam welded, so I used the linisher (belt sander) attachment that's mounted on my old bench grinder to carefully grind around the seam, just enough until the seam started to split.
Once you've got the two halves apart it's a piece of cake to bash the dings out. (don't be too over-enthusiastic with the hammer or you'll end up with a high spot which you'll need to shrink back) Once you're happy with your panel beating efforts, just braze or Tig weld (not Mig) the two halves back together again.
Make sure you do a leak test though, or buy a gallon of POR-15! I did post some pics on this thread from memory, back in November or December last year, I did that tank on my blue K2. (December BOTM winner) I've got pics somewhere, so if you can't find my pics on this thread, I'll dig 'em out again. Cheers, Terry. ;D
Offline domer
« Reply #6482 on: June 06, 2011, 08:08:13 AM »
got my tarozzi's, installed with ease (for the most part) 8) now the waiting game for the rest of my parts!
Offline curemode2002
« Reply #6483 on: June 06, 2011, 08:12:47 AM »
Finished up my horn issues late last night and took her in for the yearly inspection this morning. Passed with flying colors finally back on the road after a rough year sorting out little gremlins.  ;D
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline Spanner 1
« Reply #6484 on: June 06, 2011, 02:13:02 PM »
Super hot for the last week or so here in 37217. Just toooo hot to ride.... until yesterday when a big t'storm rolled thru' and the temp. dropped from about 93 to 73 behind it. I yanked the bike out of the garage PDQ and rode it from 5 to 7 pm.... bliss 8) ;D..... Pulled 6,500 rpm in 5th. for a bit  ::)
( Go figure; 15mph per 1,000 rpm , stock K1).......
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #6485 on: June 06, 2011, 02:38:32 PM »
Have had the 750 up on blocks for 3-4 weeks while I tackle the front wheel. It has always had too much "wobble" and truing the spokes came to a stop as several were rusted solid. So I've pulled it apart. Managed to snag my NEW inner tube on the way out with a recklish bull at a gate attempt to lever off the tyre. But now have the rim de-spoked aftter leaving the wheel soaking in a electric salt bath for a week - to de-rust the inner rim. Worked nicely. Dropped the rim at the electroplater today and picked up the mudguard and stays he just finished after 2 weeks. This had a nasty series of ripples along the top surface - I've no idea how this could have been so mangled. The plater spent a good time with his linisher puttitng as good a surface back on it before polishing and  rechroming. It looks good - not 100% - but a 95% result - for $130.
See pics.
regards
Mark
Offline CJ
  • 1981 CB750 Custom
« Reply #6486 on: June 06, 2011, 03:09:30 PM »
I have a 1981 CB750 Custom. Today I removed the broken machine screw on the brake master cylinder. Then drilled and retapped  it for 8-32 screws and replaced the O ring. Fixed the clogged hose on the clutch side disc brake and fixed my speedo cable that I didn't have hooked up right after I did my fork seals the day before. I replaced my back brakes and took to the road for a while. It feels like a new bike now...
Offline Trav-i
  • Has finally become an
« Reply #6487 on: June 06, 2011, 04:19:07 PM »
Cleaned the carbs again today, then got'em put back on.  And I also decided to put an inline filter (I know I know not cool), but until I can get around to cleaning the tank better it'll have to do.  It runs so much better  :D  now it's ready for Sunday!
Forum member #9962
1992 GL1500 Interstate
Offline DJ_AX
« Reply #6488 on: June 06, 2011, 04:40:45 PM »
still chasing gremilns ...
many . many .. hours ... of ...... chasing  ........... phuckin .................. gremilns
Really looking forward to seeing more of my 750's top side....... eventually.
Offline mjstone
  • I'm definitly not a
« Reply #6489 on: June 06, 2011, 05:07:16 PM »
mounted a ammeter.  Then went to lunch at the restaurant 4 blocks away.  Just as I was parking it the clutch cable broke. >:( Called the wife and told her I thought I could make it home.  After eating I went out to the bike and tried to get it going. Just couldn't get it rolling fast enough. Called the wife and told her I was going to have to push it home.  Pushed it around the block and started going down a hill. Had to use the brake to keep it from getting away. Then I thought maybe I could push it down the hill fast enough, hop on and fire it up!  Well, I came to my senses, and realized at my age there is no hopping left in me, so I climbed on the bike walked it forward until it picked up a little speed, turned on the ignition, slammed the shifter down into first and she took right off.  Waved at the wife as I passed her going the other way with my son on her way to rescue me.  Rode home in first gear and hit the kill switch as it wheeled up into the front yard.  Had to take the CJ-7 into work this afternoon for the first time in over two months. ::)
Now I've got to find a clutch cable.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #6490 on: June 06, 2011, 06:12:56 PM »
Well it was time to get bikes inspected in Massachusetts.  I brought my 500 and 400 in for their compulsory take money from the owner minute.  The kid checked the fork seals, brake pad thickness, head bearing play, chain tension, light and horn function, tread thickness, etc. etc.  Everything passed.  Turns out the kid was not even born when these machines hit the road.  The realization made me feel very old, still it is nice to be alive in the spring with two wheels.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline thrutheframe
« Reply #6491 on: June 07, 2011, 05:30:22 AM »
I ordered a clutch cable for my 360T.  The old one is pretty stretched out, if I adjust it to spec per the shop manual it pulls the lever too far.  Also ordered a gasket for my stator cover and four new rubber bushings for under the tach and speedo
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline WhyNot2
  • I'm finally an
« Reply #6492 on: June 07, 2011, 05:53:58 AM »
Where, may I ask, did you order your parts from?
Thanks
Jack
Offline Trav-i
« Reply #6493 on: June 07, 2011, 07:42:46 AM »
Hey Terry if you could repost those pictures that would be awesome!  I'm actually about to do the same thing, my tank is just so dirty and dented it's gonna be easier to cut it open and fix it then tryintg to do it from the outside.  I have full access to a fab shop so I just need a good example to follow.
Travis
Forum member #9962
Offline Radam
  • taco racer
« Reply #6494 on: June 07, 2011, 08:58:44 AM »
I wanna try it because I just took a class that taught brazing. I guess I need to find a bad tank to try it on.
« Reply #6495 on: June 07, 2011, 11:36:22 AM »
Thanks
Jack
I ordered todays stuff from Bike Bandit.  The clutch cable is a Motion Pro $8.46, the other stuff is straight OEM.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Trav-i
« Reply #6496 on: June 07, 2011, 12:01:32 PM »
I won't be the one putting it back together, but I need to go in and clean the tank by hand (lots of old tankliner in there a long with a lot of old sediment), because I'm sick and tired of having to clean my carbs.  Not that it'd hard to do, it's just a royal pain in the arse.
Forum member #9962
Offline WhyNot2
  • I'm finally an
« Reply #6497 on: June 07, 2011, 12:32:07 PM »
Thanks
Jack
Thanks man, appreciate it.
Offline mjstone
« Reply #6498 on: June 07, 2011, 07:41:31 PM »
Bagged a new clutch cable at a local motorcycle shop in Flint called Mike's.  It's a MotionPro cable.  Installed it this evening.  Now the CJ can go back to sleep for a while. ;D
MJ
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6499 on: June 07, 2011, 09:43:53 PM »
Changed the oil, and then kicked over the whole dirty oil bucket on the concrete :o
Good thing I know I'm clumsy and had layed out a 4x4 piece of heavy plastic under the bike before I started ;D
