Author Topic: What did you do to your bike today ?  (Read 3338095 times)
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6525 on: June 11, 2011, 07:02:01 PM »
The Mrs and I did 140 miles, 2-up on an oldwing, as part of the Gilmore Vintage "Ride 'Em, Don't Hide 'Em" pre-show group ride today.  Planning to hit the show tomorrow and see what bits I can score at the swap meet!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline dhall57
« Reply #6526 on: June 12, 2011, 04:07:36 PM »
took forks off of the KO so I'll be ready to start putting stuff back together tomorrow when new seals come in.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Trav-i
  • Has finally become an
« Reply #6527 on: June 12, 2011, 05:02:42 PM »
Rode the dog out of it today!!  Covered about 380 miles today Gainesville GA to Augusta and back.  The old F bike performed great, with only one minor glitch right as I was getting off the interstate.  It felt like a fuel starvation issue, because I started loosing power, hit the off ramp and then all of the sudden all was good.  Oh well I'm too windbeaten, wet, and sore to really care about looking at it right now.  Maybe tomorrow...
Also had lunch with some awesome friends from the forum.  Met John Dupree for the first time today, also saw Bender01 from Bluffton, SC and I rode down with Rocker, Bluto, and Bluezboy.  I couldn't have asked for a better way to spend a Sunday!
Forum member #9962
1992 GL1500 Interstate
Online CycleRanger
  • No comment about being an
« Reply #6528 on: June 12, 2011, 06:05:58 PM »
I replaced several crappy HF bullet connectors in the headlight that were installed by the PO.
Two of them basically fell off in my hand.
Installed new, correct connectors and added a dab of solder to each.
Now my LF blinker works again!
gsnorcal
CB466F First Start
« Reply #6529 on: June 12, 2011, 08:24:10 PM »
Offline grasscutter
  • Love the CB650.
« Reply #6530 on: June 12, 2011, 08:43:47 PM »
Posted vids on youtube of the CB650.
1982 Honda CB650 walk around[/url]
« Last Edit: June 12, 2011, 08:52:28 PM by grasscutter »
Come on!  We're burning daylight!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6531 on: June 12, 2011, 09:07:01 PM »
Pulled the rear wheel and removed the tire, cleaned the surface rust that had formed inside the wheel and applied some neutralizer. So now it's prepped to have a new tube installed and to get balanced.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6532 on: June 13, 2011, 06:15:11 PM »
Took the front wheel off, had the tire swapped/balanced at MotoTireGuy in SF for $20, Score! Put on my new wheel with fresh bearings, a drilled rotor I picked up from member Cleveland, and a really nice front fender I've been saving.
All with the very necessary assistance of Domer (Danny) -- Thank you again (he did most of the work).
« Last Edit: June 14, 2011, 10:08:29 AM by Greggo »
Offline dodieninja
« Reply #6533 on: June 13, 2011, 11:04:29 PM »
pulled the carbs off today and cleaned them. probably should have done a better job on the outsides but its the inside that counts. and also bench synced them. going to wait till i get an exhaust before doing a full sync on them. and also figured out why #2 was running lean, i was missing the clamp on the engine side of the boot (from carbs to engine.)
In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.
    Douglas Adams
Offline eideteker
« Reply #6534 on: June 13, 2011, 11:09:16 PM »
Ran wires through the clubmans, mounted controls and new throttle cables, cleaned up the bullet connectors and hit them with dielectric grease, hooked everything back up - busy day.  Still have to get my shocks mounted, but that'll be about it.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline Ryan66
« Reply #6535 on: June 14, 2011, 04:21:10 AM »
Care to elaborate on bench syncing?
1976 CB550k (cafe project)
Offline dulcimerbob
« Reply #6536 on: June 14, 2011, 07:14:44 AM »
Cursed it soundly for overflowing carbs that can't seem to be fixed :(
Offline greenjeans
  • 1972 CB750K2
« Reply #6537 on: June 14, 2011, 07:20:29 AM »
Spend about 20 minutes fishing out my keys from the gas tank.    Was just about to fill 'er up when the the keys slipped out of my hand and into the tank.
Luckily, I found a wire hanger in the parking lot and was able to fish it out after a good 20 minutes.    I could have just emptied the gas out but I'm way too cheap to waste $4.00 a gallon go juice.
Offline socalenduro
« Reply #6538 on: June 14, 2011, 07:28:12 AM »
Now that is some bad luck!
Offline thrutheframe
« Reply #6539 on: June 14, 2011, 08:22:33 AM »
Took the rear rim from my KZ750 and the rear rim that I won't be using from my KZ1000 to Cycle Specialists in Western Hills to have the tires swapped out.  I had a flat 2 Thursdays ago with a passenger on board.  Im going to pick it up in a bit and put everything back together.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline WhyNot2
  • I'm finally an
« Reply #6540 on: June 14, 2011, 11:17:56 AM »
Did an unlawful thing and put a plate from my 750K5 on the 350F, went to the gas station filled it up, (gas all over the tank while riding), bad gasket. Took $10.46 to fill it up. First time I've ridden it any distance since rebuilding the carbs. Runs like a charm. Had to pull the air filter though to get it to run. Really need a set of pipes and new air filter and she'll be ready for insurance and tags.
Is there anybody out there that has a set of pipes for this 1974 CB350F1? And won't cost me an arm and leg.
Prefer original, but will take 4-2.
« Last Edit: June 14, 2011, 04:15:19 PM by budlite282 »
Offline Greggo
  • Somebody's
« Reply #6541 on: June 14, 2011, 02:25:09 PM »
Swapped in my polished forks with Domer.
Offline longshanks
« Reply #6542 on: June 14, 2011, 02:47:34 PM »
Wow, what did you polish it with? the PO on my bike took a wire wheel to the forks and i don't know if I can get them to look like that!   :(
cb450 K5
Offline DJ_AX
« Reply #6543 on: June 14, 2011, 04:23:42 PM »
Rode it!  8)
Offline Tintop
« Reply #6544 on: June 14, 2011, 04:26:45 PM »
Beautiful sunny day today, so I took the 400SS the long to work.  Going to be the same all week, better fill the tank. ;) :)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Flying J
« Reply #6545 on: June 14, 2011, 06:57:48 PM »
Ride the 550! I want to see pics of it out and about.
Offline Tintop
« Reply #6546 on: June 14, 2011, 07:12:38 PM »
Just waiting for the jetting kit to arrive ffj, then off to the dyno.  After that it's street time, with still no baffels. ;) :)   In about 6 weeks in go a Megacycle cam, and a slotted cam sprocket & hardened rockers from MRieck.  Oh, and an other dyno run just to compare.
Besides the 400 does very nicely on its own attracting a crowd.  Seems even Harley guys like little red Hondas. 8)
77 CB550 Cafe build
« Reply #6547 on: June 15, 2011, 09:05:13 AM »
  Last night I cleaned up the rear wheel on my KZ750.  Later I rode my 360T to Bike Nite at the Comet.  I actually met at least one maybe two real live forum members.  Ready Steady Brown Bomber contacted me via sohc4.net PM and gave me the heads up about the event.  Thank you sir, it was my pleasure.  Rode back up into Clifton hit Macs and hung there abit,  I ended up riding around til dawn just enjoying the growling sound.   This morning I put the rear wheel back on my 750 but I havent gotten to test ride it yet, its raining like a b**tch here.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline RatRacer
« Reply #6548 on: June 15, 2011, 03:54:34 PM »
Yesterday I discovered that my bike has a top speed in the neighborhood of 115 mph.  I also discovered that at that speed a dragonfly strike has enough force to crack a turn-signal lens.
So I spent today tracking down and ordering a new lens.
  • 1979 CB 650 SOHC/4.  Currently undergoing surgery to replace reason with insanity!
  • 1999 Ram 2500 QCSB Cummins Diesel.  Headache Rack, Spray-on Bedliner, S.Steel Nerf Bars, Silencer Ring MIA, 4" TB Aero Exhaust, 1-Ton Suspension Upgrade, BHAF.
  • 2007 Mustang GT California Special.  Convertible Top, Bullitt Exhaust.
Offline mcpuffett
« Reply #6549 on: June 16, 2011, 02:09:26 AM »
Made a little bracket to fit my seat hook onto a k2 seat over the weekend and rode it to bike night last night met up with my mate George on his Ariel Square Four  8).
