Author Topic: What did you do to your bike today ?  (Read 3338065 times)
0 Members and 8 Guests are viewing this topic.
Offline dhall57
« Reply #6550 on: June 16, 2011, 03:16:27 AM »
The KO has been sitting on a jack stand all week , so last night I made up my mind to get the fork seals, fork gators put on and to get forks and wheel put back on bike. I also had two new Dunlop 404's mounted several days ago. I run these on my 750K6 and like them.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline fire113
« Reply #6551 on: June 16, 2011, 01:07:07 PM »
...started to put the K0 back together.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6552 on: June 16, 2011, 01:48:33 PM »
I didn't do anyhting myself, but my sister very kindly took the rim, unmounted tire and new tube and rim strip to a local shop for mounting and balancing. Tomorrow I pick it up, reinstall the wheel and take it home. Hopefully this is the last time I need to use her garage for repairs this summer.
Offline WarwickE36
« Reply #6553 on: June 16, 2011, 02:58:10 PM »
Rode 120 miles up the Coast of Maine.  Did a stretch with some Canadians...discussed the Stanley Cup and went our separate ways.  Great day of riding.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6554 on: June 16, 2011, 05:51:15 PM »
Rode it to work.
Offline thrutheframe
« Reply #6555 on: June 16, 2011, 06:55:39 PM »
  Today I rode the KZ 750 around all morning just to keep her limbered up.  I was supposed to take Tara to bike night at Quaker Steak and Lube in Milford.  She had to work late and asked me to meet her for dinner early, so I decided to swap back to the 360.
  Before I took it out I took off the tach and speedo to replace the rubber shock mounts.  It looks like the tach was replaced at some point.  The rubber for the tach was all old but good.  The speedo rubber was all toast especially the internal that seperates it from the cup.  I put on what I had and ordered the rest.  I had to toss out the speedo rubber, yes I used e-tape and made a sweet hillbilly shock mount.
  Once the OEM pieces come in I'll take it all apart again and replace everything.  I scored 4 bulbs from NAPA to replace one that was burnt on the speedo.  I put two new 3.4 watt, 12 volt 1 candle power bulbs in the speedo.  The tach lights I'll replace when the rubber parts come in.
  Rode the 360 to QS&L... Totally lame, at 8:00pm there were maybe 6 bikes there, all generic HD's.  I turned around in the lot and headed to the house.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline bonhomechristopher
« Reply #6556 on: June 16, 2011, 07:15:11 PM »
Ran a compression test on all of my cylinders and found out that I need new rings and possibly a valve job.  This is going to be very educational if nothing else! ;)
Offline Frankenkit
  • Industrial Strength
« Reply #6557 on: June 16, 2011, 07:27:12 PM »
played garage monkey. yay!
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline kpier883
  • is quite the
« Reply #6558 on: June 16, 2011, 07:36:22 PM »
Rode the CBX about 120 miles.  It started skipping at idle.  Put in new spark plugs.  Cranked it and warming found that #4 has a dead skip at idle.  Rode around the block and found the header on all cylinders hot enough to sizzle water off a rag.  So, it sounds like I have an idle circuit issue on #4.  BAH.  Time to pull the carbs as soon as I have time.   I guess I need to roll the 750 out, but wait, it needs new sprocket and chain.  Grrr.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #6559 on: June 16, 2011, 07:38:42 PM »
 Made a new set of the clear style points cover for the Frankenbike.
your mother
Offline Tintop
« Reply #6560 on: June 16, 2011, 07:48:06 PM »
Another neat part. 8)  You need to put an LED ring inside there. ;)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline eideteker
« Reply #6561 on: June 16, 2011, 10:17:00 PM »
Finally rode it, it's only been down since last fall.  Gotta post some pics, it's ugly but it's a rip to ride now.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline Radam
  • taco racer
« Reply #6562 on: June 17, 2011, 05:32:09 AM »
Adjusted my valves and tightened my chain last night. Rode to work today. I'll be taking the bike out of town unless the wife decides to come with me. fingers crossed
Offline Greggo
  • Somebody's
« Reply #6563 on: June 17, 2011, 09:47:56 AM »
Yesterday, I re tightened my exhaust mounts to eliminate a leak at the ports after replacing my gaskets.  The muffler was sagging, and creating a gap at the head.
Today, I rode her to work with a big smile on my face.
Offline jawntybull
« Reply #6564 on: June 17, 2011, 10:13:28 AM »
Pulled the carbies (a hairdryer to pre-warm them makes it a cinch!), put a gasket kit through, reset the floats, pulled the pilot jets and cleared them, cleared the accelerator pump. Fun day!
Bandit 1250S, DR650, CB750K
Offline fire113
« Reply #6565 on: June 17, 2011, 11:57:23 AM »
...mounted the K0 fork and the gas tank.
Offline Greggo
  • Somebody's
« Reply #6566 on: June 17, 2011, 12:21:04 PM »
Going dual disc Georg?
mbspark
« Reply #6567 on: June 17, 2011, 01:11:59 PM »
I lit mine on fire.
Offline Greggo
  • Somebody's
« Reply #6568 on: June 17, 2011, 01:19:16 PM »
I lit mine on fire.
First time I've seen that one on here!  Hope she's not 'toast'
mbspark
« Reply #6569 on: June 17, 2011, 01:43:18 PM »
I lit mine on fire.
Electric panel and most wires are gone. Battery is probably done and the plastic section of the rear fender is shot.
Going to hit it with a hose after removing those parts and see what else is gone
Offline Bankerdanny
« Reply #6570 on: June 17, 2011, 01:46:38 PM »
I hope you were at home at least and not on the road
Offline Greggo
  • Somebody's
« Reply #6571 on: June 17, 2011, 03:07:49 PM »
Got my 650 cam in the mail  8)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6572 on: June 17, 2011, 03:38:49 PM »
I lit mine on fire.
ouch!
Offline Frankenkit
« Reply #6573 on: June 17, 2011, 05:37:03 PM »
don't we have pics of Spike's phoenix when it was more ashes than bike?
1973 CL350- Lola?
Stuff for sale
Offline MoMo
  • Ride like you're invisible
« Reply #6574 on: June 17, 2011, 05:56:28 PM »
I lit mine on fire.
Seaweb,   you have to explain that...Larry
