Author Topic: What did you do to your bike today ?  (Read 3210110 times)
Offline fire113
« Reply #7000 on: July 26, 2011, 01:22:07 AM »
...sealed the new front fender.
Sealed with what?
...with body cavity sealing
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #7001 on: July 26, 2011, 06:23:39 AM »
Looked at my bike in the garage, decided at 6 AM and it's 81 degrees outside already with the windows fogged over from the coolness of the inside of the house to just take the climate controlled Chrysler to work instead. If this weather would just cool down a bit. Warmest summer here in Nebraska in 35 years!!! I could RIDE!!!!! UGGGGGGHHHHHHH  :P
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Online CycleRanger
  • No comment about being an
« Reply #7002 on: July 26, 2011, 06:50:15 AM »
You mean like Waxoyl or Cosmoline spray?
Offline thrutheframe
« Reply #7003 on: July 26, 2011, 07:16:31 AM »
Adjsuted the valves and test drove it.... oops.  Re-adjsuted valves, adjusted the points, set static timing, test drove it, mmmm not quite.  Adjusted carbs, reset idle, rode it around and listened to the joy.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline fire113
« Reply #7004 on: July 26, 2011, 09:05:03 AM »
...don't know Waxoyl or Cosmoline, I used stuff from Teroson.
Cleaned the old clamps and bought the last parts(hope so!) that I need to finish the K0.
« Last Edit: July 26, 2011, 09:07:00 AM by fire113 »
Offline tango911
« Reply #7005 on: July 26, 2011, 09:34:12 AM »
my 72 Honda CB175 shut off after a 30 min ride.   Looked it all over no electrical at all!!
the Fuse  blew but not in the middle or where you could see it.   I just pulled it out and figured to try another fuse eventhough it looked fine and sure enough,  boom  fired right back up and off i go!!
You just never know.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7006 on: July 26, 2011, 09:51:58 AM »
Popped in a 20 amp fuse and rode her to work...still have a very bad exhaust leak; I'm going back to the copper gaskets.
Offline coldwave007
« Reply #7007 on: July 26, 2011, 11:36:08 AM »
After letting the 650 sit for a week and "think about what she did - overflowing the carbs for no reason", I finally decided she'd sat in the corner long enough, pulled the rack and meticulously adjusted the floats one last time. Once back together I put the bike on the center stand, turned on the gas, and fired her up!  The idle was fair, so I borrowed my Dad's laser thermometer and used the temp readings to adjust the pilot jets until the pipes were within about 10F of each other.
Once she was dialed in, took her for a 5 mile test run. Soooo nice to be back on the road again!  Going to resync the carbs tonight.
« Last Edit: July 26, 2011, 11:38:46 AM by coldwave007 »
1980 Honda CB650C Custom, 1972 Yamaha LT-2 100
Offline Cevan
« Reply #7008 on: July 26, 2011, 12:16:48 PM »
I took my solenoid apart, cleaned it, reinstalled it, and now my starter motor cranks.
Offline fire113
« Reply #7009 on: July 26, 2011, 12:38:48 PM »
...took off the chrome ring and changed the reflector.
Offline Tews19
  • I am no
« Reply #7010 on: July 26, 2011, 03:43:28 PM »
Cleaned the gas tank, petcock replaced the fuel, bought a new fuse... Need more fuses which seem to be hard to get...
1970 Honda CB750 survivor.
Offline mrbreeze
  • Not your average
« Reply #7011 on: July 26, 2011, 04:42:11 PM »
Switch over to the new & improved blade type fuses. No law says you have to run old school fuses unless its a stocker build.
MEMBER # 257
Offline mjstone
  • I'm definitly not a
« Reply #7012 on: July 26, 2011, 06:38:26 PM »
Took it out for a quick run to make sure everything is still ok for the 2nd leg of the Michigan Rally.  Then tanked up and gave it a bath.  I'm mostly packed and ready to go.  140 miles to Kalamazoo to meet up for the start.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Roach Carver
« Reply #7013 on: July 26, 2011, 07:22:19 PM »
rebuilt one fork.
Offline Rgconner
« Reply #7014 on: July 26, 2011, 11:07:40 PM »
Tore down the oil pan and cleaned it and the mesh filter. Not in bad shape, but worth the effort.
Replaced the o-rings on the oil pump. Definite improvement in oil pressure and shifting. Also reduced some engine noises.
Gotcha: pinched a wire when replacing the shift/drive chain cover. Caused no end of problems when I took it for a test ride.
1975 CB550K aka "Grease Monkey"
Offline dodieninja
« Reply #7015 on: July 26, 2011, 11:48:07 PM »
finished pulling the wiring out along with the air box. going to go through all the wires and re-wrap it. then pulled the rear wheel and swing arm. all the bearings seem ok, so going to power wash the swing arm and give it some paint. also discovered one spoke on the rear wheel is bent, so i guess im getting new ones. then pulled the rear shocks apart so they can be cleaned and painted.
up next is pull the front end, clean the frame and give it some paint. hopefully by the end of summer ill have it all back together and be able to ride....
In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.
    Douglas Adams
Offline mjstone
« Reply #7016 on: July 27, 2011, 03:19:35 AM »
I'm putting on my riding leathers and hitting the road right NOW!
MJ
Offline motocyconomad
« Reply #7017 on: July 27, 2011, 05:17:36 AM »
test rode >:(
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7018 on: July 27, 2011, 05:19:58 AM »
Took a cup of coffee out to the garage this morning and stared at it longingly.  :'(
Offline bjatwood
  • 1973 CB750-K3
« Reply #7019 on: July 27, 2011, 07:50:31 AM »
Looked up NEW spokes for it, Man it's gonna cost some $$ to get them rims back to new! Probably could buy some 22" Bling rims for the SUV for the same dough for what I've come up with so far!
Brian
#24193
« Reply #7020 on: July 27, 2011, 09:15:11 AM »
I ran out of gas after I did yet another valve adjustment.  I parked it on reserve and figured I'd be ok.  I was test riding it in the neighborhood when it died.  The church folks were out knocking on doors and the nice lady asked, "where's yo helmet?"  "I usually wear one ma'am, I just did a valve adjustment and with the helmet on I can't hear the engine."  "so you're just testing it out right around here?" "yes ma'am I promised my mother I'd always wear it but..."  " Well I aint yo momma but I AM a mother and don't let me see you out without it again"  "yes ma'am"  I limped it home sputtering and surging, poured a little mower gas on it and went inside and got my helmet.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Rgconner
« Reply #7021 on: July 27, 2011, 09:38:23 AM »
Busted!
Offline Really?
« Reply #7022 on: July 27, 2011, 09:40:49 AM »
LMAO!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Really?
« Reply #7023 on: July 27, 2011, 09:42:37 AM »
Yanno, sometimes that makes for some great company!
Offline fire113
« Reply #7024 on: July 27, 2011, 10:18:54 AM »
...finished the K0 to 95%
