Author Topic: What did you do to your bike today ?  (Read 3209795 times)
Offline MoMo
  • Ride like you're invisible
« Reply #7150 on: August 05, 2011, 11:10:45 AM »
Took in a 1973 750 lower end as partial payment(only 50 of the 600 owed) for the work done on 1966 Dream.  Power washed it and found the upper case had a fiberglass repair job from a thrown chain.  Still looking for a good lower end ::)...Larry
Offline socalenduro
« Reply #7151 on: August 05, 2011, 06:48:13 PM »
putting final coat of paint on the fork lowers
Offline Tintop
« Reply #7152 on: August 05, 2011, 06:57:21 PM »
Got the 550 back from having the jetting fine tuned.  Tuner took it around the block ( ::)) to do a final high end jet check.  1st time I've heard the pipes over 3500.  Pulled 8K+ a block away, and it sounded just like the videos of Honda race bikes. 8) 8)
However at well over 100+db, baffles are needed. :(  Bad news there was a major failure of the bolt that secures the remote adapter to the engine.  Luckily, it happened at the shop, after the blast.  Basically the oil pressure striped the bolt out. :o  Time to upgarde it to the mk2 version.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline mjstone
  • I'm definitly not a
« Reply #7153 on: August 05, 2011, 08:08:05 PM »
Rode it to work today.  Had to load my stuff back on the Bus, I've got a field trip on Sunday.  Found one of the main roads to work was closed to through traffic.  Went in a different way, but of course, on the way home I had to take my usual way.  Just had to find out what was up.  They're replacing a bridge over a creek.  So naturally I had to go 3 miles out of my way to get home. ;D ;D ;)
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
« Reply #7154 on: August 06, 2011, 12:09:40 AM »
showed it off at a little local bike show,spot the cb500,i won a $2- raffle and took home an $80 leather vest,i dont want it but my wife likes it so its hers.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7155 on: August 06, 2011, 05:02:29 AM »
Rolled her under the awning and out of the fog.
Offline Kinch
« Reply #7156 on: August 06, 2011, 10:24:14 AM »
Finally broke down and replaced the rabbit ears with bar-ends. Very happy with the look and visibility.
Also, both turn signals were flashing very slow when they worked at all, replaced the flasher replay to the tune of $10 aftermarket as opposed to $70 for the OEM part  :o.
« Last Edit: August 06, 2011, 10:57:33 AM by Kinch »
1975 CB750 K5
1980 GS850L
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #7157 on: August 06, 2011, 02:33:56 PM »
Pulled the plugs to look at em after I had redone the carbs. Adjusted the air/fuel a bit, adjusted the chain, and detailed it. Took it for a ride and to the grocery store for some liquid refreshments. Talked to the people looking at it in the grocery store parking lot for 10 minutes, rode home and am enjoying the liquid right now as a matter of fact. GREAT Day  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline lhgdale
« Reply #7158 on: August 06, 2011, 04:39:39 PM »
 74 CB350F: Began removing rust from gas tank using vinegar and salt (sitting overnight), adjusted tappet clearance, bench synched and cleaned carbs, set breaker point gaps and adjusted clutch. Plus alot of brake cleaner and rags.
Offline mjstone
« Reply #7159 on: August 06, 2011, 04:42:23 PM »
Rode it to the grocery store to buy my son a birthday cake.
MJ
Offline Bankerdanny
  • Endeavor to persevere
« Reply #7160 on: August 06, 2011, 07:45:46 PM »
Rode it up to Rockerbox in Milwaukee. Saw at least a dozen SOHC4's in various sizes and styles. I will post pic's soon.
Offline mrbreeze
  • Not your average
« Reply #7161 on: August 06, 2011, 09:29:03 PM »
I repaired my leaky petcock with some new seals from Service Honda and rode the hell outa it!!!. Summertime rules!!!!!
MEMBER # 257
Offline johnrdupree
« Reply #7162 on: August 07, 2011, 08:35:46 AM »
Made it legal:
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline WhyNot2
  • I'm finally an
« Reply #7163 on: August 07, 2011, 12:14:09 PM »
Made it legal:
Kewl.......I'm in Augusta too............Hope to make my 350 and 750 legal soon.
Offline Johnie
« Reply #7164 on: August 07, 2011, 12:59:07 PM »
Did a KO sync and test ride...the best part.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Bankerdanny
« Reply #7165 on: August 07, 2011, 04:52:27 PM »
Adjusted the cam chain tensioner, the drive chain, tightened the headset nut. Cleaned up the chrome.
« Reply #7166 on: August 07, 2011, 07:25:06 PM »
Rode the 836.
Too hot in the garage to work on the project bikes.
Offline Bankerdanny
« Reply #7167 on: August 07, 2011, 07:30:24 PM »
Put it up for sale on eBay.
My plan was always to sell it after the Relay Rally. I held onto it an extra couple months so I could ride the Michigan leg of the rally. Now that that's done. Time for the next project. I am targeting a 75-77 wire wheel Goldwing. However, I think I will look for a 750 this winter. All of you are just too much from.
Offline Roach Carver
« Reply #7168 on: August 07, 2011, 07:52:56 PM »
You cant stay here if you dont own a SOHC. You will need to cancel your membership, but everyone here is reasonable. When you buy another one you can come back.
Offline Bankerdanny
« Reply #7169 on: August 07, 2011, 09:39:42 PM »
Hah, talk to the guys over at the Royal Enfield forum. I sold my Enfield 3 years ago and I still drop by now and again.
There is always the "other bikes" thread for me here.
Offline RatRacer
« Reply #7170 on: August 08, 2011, 03:48:31 AM »
Or we could start a "Field Medic to the SOHC/4's" thread for ya!
  • 1979 CB 650 SOHC/4.  Currently undergoing surgery to replace reason with insanity!
  • 1999 Ram 2500 QCSB Cummins Diesel.  Headache Rack, Spray-on Bedliner, S.Steel Nerf Bars, Silencer Ring MIA, 4" TB Aero Exhaust, 1-Ton Suspension Upgrade, BHAF.
  • 2007 Mustang GT California Special.  Convertible Top, Bullitt Exhaust.
Offline WhyNot2
  • I'm finally an
« Reply #7171 on: August 08, 2011, 04:21:00 AM »
Reinstalled the oil tank.......damn thing is going back together very slowly.
Put the handlebar controls, tach, speedo and headlight bucket.
Guess I'll run the wire harness next, battery tray and acc. Hopefully get it to the point to fire it up by this weekend.
Offline thrutheframe
« Reply #7172 on: August 08, 2011, 04:27:08 AM »
Last night I picked up a CB750 K4.  I found it listed on craigslist for $1200.00, I gave the guy $100 to hold until yesterday and paid a total of $800.00 with a clear Indiana title. It needs a wiring harness and some TLC mainly.  He said the points burned up one day when he left the key on.  He showed me the old harness, it looked like a third grader had tried to repair it. He replaced the points and points plate but said he couldn't figure out the harness and gave up.
  I'm not going to get too crazy on trying to restore this bike until my other projects are complete.  I will however be getting it running and calling it a "wrench and ride".  Look for more picks in the project shop, I'll be starting a thread there.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Bankerdanny
« Reply #7173 on: August 08, 2011, 08:21:43 AM »
LOL, hopefully that won't be required again.
Offline Rgconner
« Reply #7174 on: August 08, 2011, 08:33:55 AM »
Started in on replacing the oil in the forks... ran into a problem. What was a simple job might be a front end tear down.
Appears the oil is OEM, came out like a grease, not an oil!
Had to pour some oil in it and agitate with the springs to get it to flow out on the left side. Right side drained after a few minutes.
Blech. Filled with trans oil and left it overnight. If it runs out reasonably clean I may just fill it back up and run it until springs/boots/seals show up.
1975 CB550K aka "Grease Monkey"
