Author Topic: What did you do to your bike today ?  (Read 3209688 times)
Offline Really?
« Reply #7250 on: August 14, 2011, 06:12:39 PM »
Injected some SOHC4 into a two stroke Yamaha.
I thought that was illegal in Texas....
Shhhh....don't tell anyone.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Pecantree
« Reply #7251 on: August 14, 2011, 07:28:29 PM »
Pouring rain in Cleveland today. Finished up the headlight bypass relay. Discovered the Hi/Lo wasn't switching. Dang. Disassembled the Hi/Lo switch.  I think I've saved it with some good epoxy. Everything works now! Have to do some shake out runs before heading back to Texas.
Offline Roach Carver
« Reply #7252 on: August 14, 2011, 07:31:00 PM »
rewired the tailight on one. put the headlight on another
« Reply #7253 on: August 14, 2011, 07:45:11 PM »
750 F1, I put on an 18 tooth sprocket with the 48 rear. Rode it around town. I haven't tried the highway yet. Liking it so far.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #7254 on: August 15, 2011, 12:25:47 AM »
Started the K8 for the first time..... started first try, no carb leaks/overflow !!.. 8)..... put a clutch cable on it after this vid. and sync'ed the carbs and rode it around in the laneway behind the house ... no brakes yet  :o
http://youtu.be/n4uTXAEGDdo
Special thanks to ; y2kcowboy (D.C.)  for the motor, madmtnmotors for the carb parts (FL) , mcouzo (NJ) for the oil tank and the P.O. for leaving the bike outside for 7 years  :o...
Little smokey but at least it ran, and could be worse.. could be 18 years.... There's a reason why 90% of my chrome is painted gloss black ;)
1975 CB750K
Project Back in Black
Offline JustinLonghorn
« Reply #7255 on: August 15, 2011, 06:58:11 AM »
Bought a new bike...
"So you had better do as you are told
You better listen to the radio"
My Super Sport Build
Offline cb550inct
  • I am really good at buying parts
« Reply #7256 on: August 15, 2011, 07:16:09 AM »
Recently had the same problem, found a faucet gasket at ace hardware that fit pefectly I'll find the part# for you
Messed around with the front blinkers.
It's interesting, I have two sets of front blinkers both from 750K5's.
One set has steel arms and the other set has aluminum arms. I don't know which set is newer.
The aluminum ones came on a K5 with a build date of 11/74 but I'm not sure they're original.
The aluminum arms are a couple of ounces lighter than the steel ones. I guess Honda was trying to shave some weight!
Then I contemplated my idiot lights.....
I have two sets, one with ok rubber but completely rusted.
The other set has usable sockets but the rubber is shot.
Of course the rubber is molded to the socket soooo what to do?
Hmmm, well we'll see.
« Last Edit: August 15, 2011, 07:18:44 AM by cb550inct »
1978 cb550k
1998 Harley Springer Softail
2004 Harley Heritage Softtail (sold)
2001 Vespa 150 (sold)
1980 Kawasaki Kx 80  (first Bike)
Offline Tews19
  • I am no
« Reply #7257 on: August 15, 2011, 08:21:39 AM »
Sweet looking bike! You get a deal?
1970 Honda CB750 survivor.
« Reply #7258 on: August 15, 2011, 08:23:50 AM »
$750.
Offline Tews19
  • I am no
« Reply #7259 on: August 15, 2011, 08:28:38 AM »
Get out of here! Does she run? Great find
« Reply #7260 on: August 15, 2011, 08:34:55 AM »
Runs great, needs new tires. Came with box full of parts, including the stock muffler.
Offline DJ_AX
« Reply #7261 on: August 15, 2011, 10:48:53 AM »
Changed the oil in the 750  8)
Whilst making lunch for the kids.
Both at the same time in less than 10 minutes! ...  ;D
"Honda 4" 4 stroke 10w40 ..
recommended by Honda...
can't go wrong with that right?
...and hot dogs.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7262 on: August 15, 2011, 10:51:46 AM »
Well done sir!  I hope that box o' parts came with a stock airbox ;)
Offline Really?
« Reply #7263 on: August 15, 2011, 10:57:14 AM »
Gave the YZ a nickname.
Offline mrbreeze
  • Not your average
« Reply #7264 on: August 15, 2011, 10:58:41 AM »
Let me guess...............you want us to guess what it is!!!
MEMBER # 257
Offline Really?
« Reply #7265 on: August 15, 2011, 10:59:34 AM »
Nope, it is in the sig.
Offline mrbreeze
  • Not your average
« Reply #7266 on: August 15, 2011, 11:01:56 AM »
Awwww yes............I see it.
MEMBER # 257
Offline Really?
« Reply #7267 on: August 15, 2011, 11:40:12 AM »
The poor old girl has had the piss ridden out of her, she is worn out and very loose.  Thought the name fit quite well.
« Last Edit: August 15, 2011, 11:47:38 AM by TipperT »
Offline mrbreeze
  • Not your average
« Reply #7268 on: August 15, 2011, 11:45:15 AM »
Gotcha!!!! 8) 8) 8)
MEMBER # 257
Offline MoMo
  • Ride like you're invisible
« Reply #7269 on: August 15, 2011, 01:38:18 PM »
$750.
Justin,, good to see you finally got a running 400-and at a great price..   Any headway on the other bike?...Larry
KingCustomCycles.com
« Reply #7270 on: August 15, 2011, 01:45:19 PM »
welded custom footpeg mounts to the Hondamatic rigid frame and sorted out the rear brake installation.
Offline Tews19
  • I am no
« Reply #7271 on: August 15, 2011, 02:05:47 PM »
Got new tires on my 550F, took the tank off the 550K adn it is currently soaking with evaporust in her.... WIll show before and after pics...
Offline CycleRanger
  • No comment about being an
« Reply #7272 on: August 15, 2011, 02:37:59 PM »
Yeah, I wish I could find out where Yamiya gets the BA9s sockets.  I'd like to build my own for less.
http://www.yamiya750.com/index.php?main_page=product_info&cPath=28_72&products_id=192
« Reply #7273 on: August 15, 2011, 03:16:08 PM »
$750.
Unfortunately I will have to sell off a lot of that project to fund this one.
Offline MoMo
« Reply #7274 on: August 15, 2011, 03:23:59 PM »
$750.
Yea, I saw your other for sale post-definitely keep the alloy rims.   Best of luck with the new bike...Larry
