Author Topic: What did you do to your bike today ?  (Read 3209013 times)
0 Members and 11 Guests are viewing this topic.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #7600 on: September 18, 2011, 06:58:06 PM »
That may just be debris from the pre-rebuild engine that's been knocked loose during the rebuild process and has floated to the pan by the new oil.  I say change the oil and run 'er another 100 miles then drop the pan again.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #7601 on: September 18, 2011, 07:02:56 PM »
Adam, Blitzburg, mother#$%*er, I am so pissed I am going to look at 99 VTR1000 superhawk tomorrow.  Not that I will sell the CB but, I am fed up with this thing right now...
That's it mate, buy the VTR, they're great bikes, and anyway, your 550 is probably fcuked, so why not? ;D
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
« Reply #7602 on: September 18, 2011, 07:15:59 PM »
Road mine to get Ice Cream and some coffee...
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
Offline CycleRanger
  • No comment about being an
« Reply #7603 on: September 18, 2011, 08:12:06 PM »
Bingo, that was my thought too.
Offline knox-cb
« Reply #7604 on: September 18, 2011, 08:31:27 PM »
Swapped the oil pan from a K parts bike to a '78 750F because the p.o. stripped the drain bolt and had it held in place with gasket maker.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #7605 on: September 18, 2011, 10:35:31 PM »
Snuck my now uninsured Tracy out for a quick boot around the corner and back ;D ;D ;D ;D ;D ;D 8)
Rode the #$%* out of the 1100E ;D
Offline fasturd
« Reply #7606 on: September 19, 2011, 05:15:56 AM »
Finished selling her... Project 13 will be going to a new owner shortly...
Time to get a 750 project going!
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
« Reply #7607 on: September 19, 2011, 06:14:05 AM »
Stepped on soldering iron with bare foot, quite an achievement  ;D
Sorted out and mocked up wiring for R6 controls on 70CB, it all works now.
Offline WarwickE36
« Reply #7608 on: September 19, 2011, 06:20:35 AM »
Quote from: OldSchool_IsCool on September 18, 2011, 08:58:06 pm
This is sounding promising but I am not going to keep my hopes too high.  I dont really care about the sealer in the pan, but the shavings of metal concern me.  I did find 1 cylinder was in pretty rough shape during my rebuild (really needed to be honed) I just wanted to get back on the road and was going to do rings and head work this winter....  I wonder since I neglected to pre-oil the cylinders for the initial startup maybe the ring was chewed up by the heavy grooves in the cylinder wall? My only other concern was that maybe in lining up the cases one of the main bearings came loose and didn't seat right and was chewed up. I did make sure to use build lube on all the crank and cam bearings, as well as cam lobs and rocker components.
Engine knock would increase in volume/frequency with RPMs would it not?
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #7609 on: September 19, 2011, 06:31:47 AM »
Did you check the debri with a magnet to determine if it was steel or aluminum?
Offline Rgconner
« Reply #7610 on: September 19, 2011, 06:40:12 AM »
The primary chain (new) was still just as snug and didnt appear to be hitting anything.  I removed all the tappet covers and there was oil on each valve.  The cam chain and tensioner + guide were replaced and tight.  .... pretty confused as to where this metal would be coming from.  I doubt the cam shaft has been destroyed to the point where I find metal shavings in the oil pan, but the bike still runs awesome.  Wondering if the clutch basket rivets are still contacting that shift bracket and creating metal shavings in the oil.
Hang in there mate!
I just wenth through a scare that I had broken a head bolt, turned out to be the cam chain jumped a tooth... A much easier fix.
Sometimes you have to walk away from the project to get some perspective...
I suggest knitting, for something completely different.  Maybe a nice baclava cor the winter riding season?
1975 CB550K aka "Grease Monkey"
« Reply #7611 on: September 19, 2011, 06:50:46 AM »
He does not need balaclava - look at his picture  :D
Offline WarwickE36
« Reply #7612 on: September 19, 2011, 07:02:17 AM »
I was so pissed at the time I didn't care about diagnostics.  I will go pull the paper towels out of the trash and test the bit and pieces.  What inside the motor is steel just gears?  what are the bearings made of?
2004 SV650s
« Reply #7613 on: September 19, 2011, 07:09:25 AM »
Tin, copper, antimony in general, not sure what's in Hondas.
http://www.marinediesels.info/2_stroke_engine_parts/Other_info/bearing_materials.htm
Typically main bearing debris is not magnetic.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #7614 on: September 19, 2011, 11:27:23 AM »
Did some tinkering today. Synced my carbs for the first time since I got my bike in May. Borrowed a Morgan Carbtune from site member VFRpilot Allan. Syncing these K3 carbs makes the bike run smoother than a babies (behind)  ;)  The biggest thing I noticed is the take off from a stop. Very smooth and responsive without a hint of a burp or gurgle or hesitation. I have never rode this bike to 8 grand so fast, feels like a different machine
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline longshanks
« Reply #7615 on: September 19, 2011, 11:48:07 AM »
Well it was yesterday actually. It was another beautiful sunny Spring morning, the sun was shining, the birds were singing, but the "Handbrake" was whining about the length of the grass (fair enough I suppose, I use my Kelpie as a guide to when I mow the lawn, when I can't see her any more is usually the trigger) so I dutifully mowed, weedwacked, blew etc until she was satisfied that the yard was up to her (rather high, methinks) standards.
Then I had a shower to remove the spiders and dog #$%* spray, fired up the beautiful gold K2, and rode. Man, what a ride, I stayed away from the freeways and had a ball defying the laws of the land, not to mention the laws of gravity, common sense, et al. Casey Stoner would have been proud of me, scraping my steel capped work boots around most corners, red lining it thru the gears, and chasing down young blokes on sports bikes. (and actually passing a few)
I stopped in at my local RSL (old Soldiers Club) on the way home and had a couple of ciders, while I won and then lost a small (very small) fortune on the slots, all the while avoiding the advances of the deperate housewives that infest these venues. All in all, a great start to Spring! Cheers, Terry. ;D
Beautiful bike! what kind of brake set up do you have there?
cb450 K5
Offline WhyNot2
  • I'm finally an
« Reply #7616 on: September 19, 2011, 11:59:52 AM »
And Front Fender too?
« Reply #7617 on: September 19, 2011, 12:05:29 PM »
RSL=Reserve Service Lodge?  =Retired Soldiers lodge?
Offline WhyNot2
  • I'm finally an
« Reply #7618 on: September 19, 2011, 12:28:22 PM »
That would be my pick.....................
I am retarded mil..........uuuuhhhh..........retired military.
« Reply #7619 on: September 19, 2011, 12:31:04 PM »
Standing too close to the cannon?   :D
(Appreciate your service)
Offline WhyNot2
  • I'm finally an
« Reply #7620 on: September 19, 2011, 12:31:51 PM »
 :o
(Your Wlecome......................)
« Reply #7621 on: September 19, 2011, 01:07:11 PM »
Returned and  services league
Offline WarwickE36
« Reply #7622 on: September 19, 2011, 03:40:38 PM »
Definitely heard a tapping/ticking on the way home...A noise that was there before the rebuild. Pulled the valve cover off the 550... perfectly lubed, no signs of any damage.  Broke the tach drive gear in the process.  Told the bike to catch a boat to #$%*_offity_land.  Grabbed a bear and started looking at craigslist for a GSXR or fz6R.  Rash decisions have been made on my account due to a few too many beers.  Hopefully tonight isn't one of those nights.
2004 SV650s
Offline Frankenkit
  • Industrial Strength
« Reply #7623 on: September 19, 2011, 03:52:40 PM »
Yeah, I usually try to stop drinking before I start grabbing bears.
All kidding aside, you may need to walk away for a little bit to clear your head before you make any decisions.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline WarwickE36
« Reply #7624 on: September 19, 2011, 03:55:39 PM »
I am on a roll with my unintended puns this week.   I put the bear back and grabbed a beer, seemed safer.
2004 SV650s
