Author Topic: What did you do to your bike today ?  (Read 3207827 times)
« Reply #8500 on: December 10, 2011, 06:23:12 AM »
You Aussie Guys are making me jealous out there riding your bikes and mowing grass,thinking about putting a Pod and a Yosh exhaust on my snowblower and see if I can toss that crap 100 feet--------- :-\   :'(
Offline sopo400f
« Reply #8501 on: December 10, 2011, 07:09:42 AM »
I was plagued with the infamous cracked and busted idiot light panel on my 400f.  Back during the Barber's festival, I saw a buddy had a 750 front end he was going to put in the swap meet area (we had a booth) that had a nice condition idiot light panel on it.  It's not the correct OEM black for the 400, but it bolts right up and to me looks great!  He kindly donated it for free! I put a little rubber restore on the gaskets, replaced the bulbs in it and the gauges, and installed a new 35w h4 bulb in my headlight since mine was 65w and would kill the battery (especially with the dyna ignition installed  ::) )
Went for a 90 mile ride to celebrate. Feels like a new bike now!  This is a happy 400 owner (as usual!)
You have any pics of headlight setup? What is that thing, its real shiny.
1975 cb400f blue
Offline Felix
« Reply #8502 on: December 10, 2011, 08:06:08 AM »
I took her for a walk to her new shelter!
Honda CB500F '72 in progress
Offline fire113
« Reply #8503 on: December 10, 2011, 11:38:06 AM »
...cleaned the valve cover of my K2.
Offline Kanticoy
  • Mad Science!
« Reply #8504 on: December 10, 2011, 12:39:48 PM »
[/quote]
[/quote]
 I think I do. It's the dime city Chrome headlight bucket....my stock one was busted up pretty bad.....
Here's one in motion. It's a 7" with the included h4 conversion. It was around $50 I think...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8505 on: December 10, 2011, 02:37:25 PM »
Charged the battery then used it to run some errands.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline sopo400f
« Reply #8506 on: December 10, 2011, 02:37:40 PM »
Cool. Thanks for the info.
1975 cb400f blue
Offline longshanks
« Reply #8507 on: December 10, 2011, 02:46:09 PM »
Rode the bike down to the local motorcycle shop so they could use their rivet tool to compress a link on my chain to get the retaining clip on all the way one(yes, it was halfway on  :o  )
Finally! I can ride now and man, this X-ring chain feels like butta!!   :D
cb450 K5
Offline Tree
  • CB750K5
« Reply #8508 on: December 10, 2011, 03:08:27 PM »
Tried to free some seized pistons.  (I think it's running a little rich  :))
« Reply #8509 on: December 10, 2011, 03:19:31 PM »
It is burning like a tree - no pun intended :)
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #8510 on: December 10, 2011, 03:20:30 PM »
removed the electrical do-dads, then sanded/prepped the elec panel and battery box for paint.  arrggg - nooks and crannies!   >:(
searching for a dr350se
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #8511 on: December 10, 2011, 03:29:53 PM »
Bought a transmission cover gasket for the 750 - $17 from the local shop (Charlie's Place).
Offline veloracermike
« Reply #8512 on: December 10, 2011, 03:31:45 PM »
Dropped the bike off at the shop to get the rear seat hoop and platform for my electrics welded up.
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #8513 on: December 10, 2011, 05:42:32 PM »
Took the battery out, applied bowling alley was to chrome and aluminum, drained the tank, sprayed wd40 into the carb drains and put marvel mystery oil on the spark plug holes kicked it over a few time and kissed her good winter.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
« Reply #8514 on: December 10, 2011, 06:06:39 PM »
Bowling alley wax? That's a new one. It may be better to keep the fuel tank full to keep it from rusting.
« Reply #8515 on: December 10, 2011, 06:27:54 PM »
She's lookin' dangerous mate.  8)
It took me nearly 8 hours to mow half of the block here last weekend and needs doing again already after the rain this week.
Me mate reckons that I should have a lawn sale and sell it for a dollar a foot.  ;D
The bikes looking magic Terry and it sounds as if she's roarin' like a loco at full song.
Thanks Mick, it's a bit cold and wet here today, so i think I've escaped the mowing until next weekend, which is fine by me, it gave me time to work out why the bike was running out of fuel on the way home.  I took the tank off and put it on the stand and turned the fuel on, nothing. Fair enough, it was looking pretty low, but there was still enough in there for reserve to work, so I switched it to reserve, but still nothing. OK, I removed the fuel tap (pet cock, s.......) and it was as clean as a whistle, but the fuel tube was a tight fit coming out of the tank, so I theorised that the POR15 job I did last Christmas was the culprit.
For reserve to work on a K tank there needs to be some clearance around the fuel tubes base so that fuel can flow past it and into the fuel tap, and mine was as tight as. I drained the tank, (3 litres of fuel came out, give or take) and then used a chainsaw file to file the surplus POR15 back to the metal so that the fuel tube in the fuel tap was a sloppy fit in the hole, then flushed the tank out so that any POR15 filings (now a grey powder-like substance) were washed into a bucket, rather than into my carbs.
I screwed the fuel tap back on to the tank and tried both the "on" and "reserve" positions, and the fuel flowed freely, so I shoved it back on the bike and hooked up the clear hoses, and was pleased to see fuel flowing again. I let it sit for a minute so that it'd fill the float bowls and then checked for leaks, (none) then hit the button and was rewarded with a healthy 'Varoom-a!".
I forgot to mention that on my ride yesterday the throttle jammed on @ around 6000 RPM and I had to force it back down, and with the tank off, the problem was obvious, the locknut on the return throttle cable had vibrated loose, so I fixed that, and tightened up a front blinker that had decided to rotate at 100MPH. All good now, and ready for another ride. Ah, life is good with the "Rainbow Warrior", ha ha! ;D
Offline Greggo
  • Somebody's
« Reply #8516 on: December 10, 2011, 06:37:53 PM »
I call that the technicolor dream bike Terry!
« Reply #8517 on: December 10, 2011, 06:54:13 PM »
Ha ha, thanks mate, as long as you don't call it the "Technicolor Yawn" (Aussie slang for vomit) bike, I'll be happy! ;D
Offline Greggo
  • Somebody's
« Reply #8518 on: December 10, 2011, 08:47:04 PM »
Naw, that bike looks like a screamer, not a puker!
Offline Greggo
  • Somebody's
« Reply #8519 on: December 10, 2011, 08:49:50 PM »
And the rear sets look great!  I got some Yoshimura sets for my 750, but they feel kinda wimpy.  Can you stand up on yours?
« Reply #8520 on: December 10, 2011, 10:51:05 PM »
Yep, they're Tarozzi's, and look pretty strong. I weigh around 300 pounds so I'm not gonna stand on 'em just in case, but I'm sure they could probably handle it. Cheers, Terry. ;D
Offline Radam
  • taco racer
« Reply #8521 on: December 11, 2011, 08:37:09 AM »
Terry, I'm moving to Melbourne towards the end of next month. I'll mow you're lawn for a year for the rainbow dream bike. ;) Seriously, I may need help finding a bike once I get there. We're still trying to find an apartment(flat) first. Do you know of any good sites for apartment hunting?
« Reply #8522 on: December 11, 2011, 10:11:04 AM »
Tested winter motorcycle pants this guy made for me 15 years ago - different bike, different continent and they still fit. Afaik it was the first time ever i used them.
Of course, my obnoxius youngest child said they will be too small for me, I get no respect.
Rode 50 miles.
« Reply #8523 on: December 11, 2011, 12:32:51 PM »
G'Day Mate, I'd almost go for that deal, I hate mowing my lawn, but I can't afford to build another bike, so we'll have to come up with another deal once you arrive. I do have almost enough parts lying around to build you a CB750 though, if you're interested? I'm just about to leave for work (Monday morning here) but when I get home I'll see if I can find you an on line real estate listing. Where abouts are you going to be working? PM me if you prefer. Cheers, Terry. ;D
Offline Really?
« Reply #8524 on: December 11, 2011, 12:50:03 PM »
Hey Tree, did it work?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
